I want to explain all I have done so far step by step:
1-) download latest image in here
image version :Colibri_iMX6_LinuxImageV2.5Beta3_20151215.tar.bz2
2-) Run the update.sh script with -o argument pointing to the mount point of above mentioned card.
3-)Plug sd cart on my iris board than update my image .
[upload|plroJ4Vxm8MYJva/Zhiu8KcPSXk=]
4-) download kernel source file with this commands
git clone -b toradex_imx_3.14.28_1.0.0_ga git://git.toradex.com/linux-toradex.git
5-) download gcc-linaro file with this commands
wget http://releases.linaro.org/14.11/components/toolchain/binaries/arm-linux-gnueabihf/gcc-linaro-4.9-2014.11-x86_64_arm-linux-gnueabihf.tar.xz
tar xvf gcc-linaro-4.9-2014.11-x86_64_arm-linux-gnueabihf.tar.xz
ln -s gcc-linaro-4.9-2014.11-x86_64_arm-linux-gnueabihf gcc-linaro
6-) Create export_compiler file with this command
echo "export ARCH=arm" >> ~/export_compiler
echo "export PATH=~/gcc-linaro/bin/:$PATH" >> ~/export_compiler
echo "export CROSS_COMPILE=arm-linux-gnueabihf-" >> ~/export_compiler
than run this command source ~/export_compiler
7-)install device tree compiler with this command
apt-get install device-tree-compiler
than run this command for take a version information dtc -v
now ı can take version : Version: DTC 1.4.0
8-)Now ı want to add
CONFIG_USB_SERIAL_CP210X=y
CONFIG_PPPOE=y
this two line on the colibri_imx6_defconfig so going the this path
cd linux-toradex/arch/arm/configs/
and found colibri_imx6_defconfig file and add this two line.
9-) Now I need to recompile this kernel files. run this command and go to main file of kernel files
cd linux-toradex
10-) than run this command :
make colibri_imx6_defconfig
and take this screen shot:
[upload|bou7sD8NkIX57o/ZebkeyUBRgtM=]
11-)Than run this command for compile the kernel & device tree:
make -j3 uImage LOADADDR=10008000 2>&1 | tee build.log
output of command in here :
[upload|hjvKKuvgZvNmo6iKvuHP9I9qfPQ=]
I take 2 errors in this step.
12-) Run this command successfully :
make imx6dl-colibri-eval-v3.dtb
13-)Now compile kernel modules successfuly at this command:
make -j3 modules
14-)deployed kernel modules at this command:
sudo -E make ../Desktop/Colibri_iMX6_LinuxImageV2.5/rootfs/modules_install
but ı take an error on this step.
[upload|HMl2EcYX/Dr4/etIkgrFB/nvuVE=]
how can ı fix step 11 and 14 errors ?
