I’m going to flash the module with new image.
I did these steps:
- Download image from website and
copied it on my host computer
desktop - Run
sudo tar xjvf Apalis_iMX6_LinuxImageV2.5Beta3_20151215.tar.bz2
- Run
cd ApalisiMX6_linuxImageV2.5
- Run
sh update.sh -o "SD card address"
- Put SD card on target.
setenv drive 2
- `setenv setupdate 'fatload mmc
- ${drive}:1 ${loadaddr}
flash_mmc.img; source ${loadaddr}'` saveenv
- Restart module and pressed a botton to avoid normal boot.
- Run
run setupdate
- run
run update_it
after these steps I’m getting this error:
mmc - MMC sub system
Usage:
mmc info - display info of the current MMC device
mmc read addr blk# cnt
mmc write addr blk# cnt
mmc erase blk# cnt
mmc rescan
mmc part - lists available partition on current mmc device
mmc dev [dev] [part] - show or set current mmc device [partition]
mmc list - lists available devices
mmc hwpartition [args...] - does hardware partitioning
arguments (sizes in 512-byte blocks):
[user [enh start cnt] [wrrel {on|off}]] - sets user data area attributes
[gp1|gp2|gp3|gp4 cnt [enh] [wrrel {on|off}]] - general purpose partition
[check|set|complete] - mode, complete set partitioning completed
WARNING: Partitioning is a write-once setting once it is set to complete.
Power cycling is required to initialize partitions after set to complete.
mmc setdsr <value> - set DSR register value
switch to partitions #1, OK
mmc0(part 1) is current device
MMC read: dev # 0, block # 8191, count 1 ... 1 blocks read: OK
Total of 3 byte(s) were the same
reading apalis_imx6/u-boot-it.imx
** Unable to read file apalis_imx6/u-boot-it.imx **
I checked the SD card and in apalis_imx6 folder I can see u-boot.imx-it and can not see u-boot-it.imx
Could you please help me solving this issue?
Thanks.
