Gstreamer rtmp plugin
Hi all,
I need to use the gstreamer plugin rtmp which provides in particular “rtmpsink” but I am unable to find it in any plugin package, of both gstreamer1.0 ad 0.10. it should be in “bad plugins” any advice for installing it on our Apalis T30 BSP2.6?
regards
The gstreamer bad plugin recipe in OpenEmbedded does not enable rtmp build by default. The recipe does however have a package configuration option available. See here. To enable it, add the following to ~oe-core/build/conf/local.conf
PACKAGECONFIG_append_pn-gst-plugins-bad = " rtmp"
Then build gst-plugins-bad as follows
MACHINE=apalis-t30 bitbake gst-plugins-bad
This should give rtmp ipk packages
[mas@linuxdev build]$ find ../deploy/ipk/ -name "*rtmp*"
../deploy/ipk/armv7ahf-neon/gst-plugins-bad-rtmp_0.10.23-r4_armv7ahf-neon.ipk
../deploy/ipk/armv7ahf-neon/gst-plugins-bad-rtmp-dev_0.10.23-r4_armv7ahf-neon.ipk
../deploy/ipk/armv7at2hf-neon/rtmpdump-dev_2.4-r0_armv7at2hf-neon.ipk
../deploy/ipk/armv7at2hf-neon/rtmpdump-doc_2.4-r0_armv7at2hf-neon.ipk
../deploy/ipk/armv7at2hf-neon/rtmpdump-staticdev_2.4-r0_armv7at2hf-neon.ipk
../deploy/ipk/armv7at2hf-neon/rtmpdump-dbg_2.4-r0_armv7at2hf-neon.ipk
../deploy/ipk/armv7at2hf-neon/rtmpdump_2.4-r0_armv7at2hf-neon.ipk
I tested the above build on our latest OE morty branch but the same should work with OE jethro. To add it to the image itself, add gst-plugins-bad-rtmp to the image recipe you are using.
It worked, thank you!
