I ran the GPIO Config Tool on an Apalis SoM connected to an Apalis eval board(v1.1), and proceeded to add in the initialization of GPIO_1 thru GPIO_6 in my code. However, found that the mouse and keyboard were now inoperable.
Upon further review via the eval board schematic, and the pinout designer, found that the SODIMM values reported by the config tool do not seem to agree with the SODIMM values that the pinout designer and silkscreen indicate.
See below:
Eval/Loc shows X4, ended up using X2, and removing X3 in between X2 and X4.
Is there an issue with what GPIO Config Tool reports and the Silkscreen data?
