I don"t understand the partition scheme of my Colibri iMX6 target:
This module boot from the eMMC.
root@colibri-imx6:~# df -h
Filesystem Size Used Available Use% Mounted on
/dev/root 266.0M 175.5M 76.4M 70% /
devtmpfs 88.7M 4.0K 88.7M 0% /dev
tmpfs 248.8M 0 248.8M 0% /dev/shm
tmpfs 248.8M 320.0K 248.5M 0% /run
tmpfs 248.8M 0 248.8M 0% /sys/fs/cgroup
tmpfs 248.8M 0 248.8M 0% /tmp
tmpfs 248.8M 0 248.8M 0% /var/volatile
/dev/mmcblk0p1 16.0M 4.8M 11.2M 30% /media/mmcblk0p1
tmpfs 49.8M 0 49.8M 0% /run/user/0
root@colibri-imx6:~# fdisk -l
Disk /dev/mmcblk0: 7818 MB, 7818182656 bytes
4 heads, 32 sectors/track, 119296 cylinders
Units = cylinders of 128 * 512 = 65536 bytes
Device Boot Start End Blocks Id System
/dev/mmcblk0p1 65 320 16384 c Win95 FAT32 (LBA)
/dev/mmcblk0p2 321 55680 3543040 83 Linux
Disk /dev/mmcblk0boot1: 4 MB, 4194304 bytes
4 heads, 16 sectors/track, 128 cylinders
Units = cylinders of 64 * 512 = 32768 bytes
Disk /dev/mmcblk0boot1 doesn't contain a valid partition table
Disk /dev/mmcblk0boot0: 4 MB, 4194304 bytes
Disk /dev/mmcblk0boot0 doesn't contain a valid partition table
the eMMC seem to have a size of 8 GB (but I expect a 4GB from datasheet). Why?
If I undertand correctly update.sh « imx6 « library « files « images « recipes - meta-toradex.git - oe-core BSP layer (obsolete), the size of /dev/root must be near 4GB. Why it is not the case? Where is the free space?
