Toradex Task Manager 1.8 hangs on iMX6DL with a CPU usage of 50%, and never appears on the screen. Colibri Monitor 1.7 runs but shows no Temperature or CPU diagnostics under the Performance Totals box.
Please advise on how to run the new Task Manager and display CPU diagnostics.
We are seeing the same behaviour with an iMX6Q V1.1A on a custom carrier board.
The message “Invalid Hardware!” is written to the debug Output when the ToradexTaskManager.exe is started.
We are checking the issue, in the meantime, you may use Colibri Monitor. The new tools has some additional features that are currently supported only on Tegra-based modules.
