I have an Apalis T30 plugged into an IXORA carrier board and everything is working fine except the USB port in host mode on the bottom part of X8 connector. I searched for USB issues on Toradex System/Computer on Modules - Linux BSP Release and I found issue #8342 interesting. The workaround ( booting with JP2 removed and only connecting JP2 after boot ) seems to solve the problem but when I reboot the device, the problem reappear and I get this message with dmesg :
[ 19.721106] usb 3-1: device descriptor read/64, error -110
[ 35.411146] usb 3-1: device not accepting address 2, error -110
[ 35.541177] usb 3-1: new high speed USB device number 3 using tegra-ehci
[ 51.121149] usb 3-1: device not accepting address 3, error -110
[ 51.251198] usb 3-1: new high speed USB device number 4 using tegra-ehci
[ 61.691048] usb 3-1: device not accepting address 4, error -110
[ 61.831192] usb 3-1: new high speed USB device number 5 using tegra-ehci
[ 72.271159] usb 3-1: device not accepting address 5, error -110
[ 72.277132] hub 3-0:1.0: unable to enumerate USB device on port 1
Sorry, I forgot to mention that I am using BSP V2.7b3 built with OpenEmbedded without any kernel modifications.
This problem happens with a USB 3.0 flash drive (Toshiba 16 Gb) and with a FTDI USB 2.0 to UART converter. I also tried with a USB 2.0 flash drive and for this one it seems that the bug does not happen.
As described in Apalais T30 datasheet, and IXORA datasheet, the module does not provide any signals on the USBH4 interface which is connected to the top of X8. I tried to connect the working USB 2.0 flash drive but of course nothing happens.
