hi sir, I connected DC power supply to Apalis iMX6 evaluation board and connected a VGA cable from it to the monitor. I am not able to get any output to the monitor.please help what to do. And i followed what the Toradex people said even thought i didn’t get ON the monitor…please any suggestion for that…
Hi
Please have a look here on how to setup the used display output and resolution.
Note that the Apalis iMX6 by default uses the HDMI port for display output.
So on the U-Boot command line one would change the vidargs variable, e.g. for a 1024x768M@60 resolution:
setenv vidargs 'video=mxcfb0:dev=vdac,1024x768M@60,if=RGB565 video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off fbmem=32M'
saveenv
Note that there is a reason why we ask with what version of things you are working…
Max
Please have a look at this answer to a question which is similar. I would suggest to search in community before posting, few of your issues/queries might got answered in other discussions, also I would suggest to read this.
sir,
for what reason VGA connected to the monitor not getting ON can you give me the reason please and can your send me the solution how to change the U-Boot for above mention commands and how to go…
Dear sir,
I am following this step [ Apalis evaluation board ] i mentioned the link below
Linux Terminal and Basic Usage - Getting Started with Toradex.
once i reached the step 9.i need to enter the login and user for me it’s not getting from user …plz help
Go through the steps 5-9 again but in step 6 also press ‘f’ to change Hardware flow control from Yes to No
thx sir i got .after that what i have to do.
i downloaded SDK in need change the permission in the same command prompt or new sir…
i opened new command prompt and i getting like this problem plz help for further .
with SDK we’re only targeting 64-bit host operating system. If you have a 64-bit machine you’ll need to install 64-bit linux distribution
i am really thx you sir i am using 32 bit …i will change that.and one more problem please help from this i am not getting the window i connected as per the step and i power on monitor not getting on
Dear sir,
as per the above picture i connected the vga cable to the monitor and i powered on the board but i am not getting the monitor to ON.
1.how to go U-boot command line and how i change the setenv vidargs variable.
1. setenv vidargs ‘video=mxcfb0:dev=vdac,1024x768M@60,if=RGB565 video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off fbmem=32M’
2.saveenv
You would need to enter that on the U-Boot serial debug console. Basically as you showed on your first picture above however instead of the Linux prompt you do want to power-cycle and do it immediately on the U-Boot prompt.
BTW: Did you run the Toradex Easy Installer already resp. at all? Or asked differently what exact hardware/software versions of things are we actually talking about?
There is no such thing as an Apalis iMX6 Evaluation Board. There is the Apalis Evaluation board plus an Apalis iMX6 module. However which exact flavour/version thereof you missed stating.
sir,
where can i get the U-boot console.
i am new to this. please help
here i need to type those commands or not
saveenv
Yes, exactly.
sir i got that monitor is on thank you sir
You are very welcome and thanks for letting us know.
sir,
Toradex easy installer is not installed in the module.i followed this step.
but i didn’t get the image
i tried like that its correct or wrong
its getting stuck and i tried many times its stop like
resetting…plz help from this.
And its giving like
Only starting with Apalis iMX6Q 2GB IT V1.1C modules will come with the Toradex Easy Installer pre-installed. So either you launch that one via recovery mode or refer to the legacy update procedure. As for the former it is again a 64-bit binary:
[user@host Apalis-iMX6_ToradexEasyInstaller_1.0-20170605]$ file recovery/imx_usb
recovery/imx_usb: ELF 64-bit LSB executable, x86-64, version 1 (GNU/Linux), statically linked, for GNU/Linux 2.6.32, BuildID[sha1]=249fe4f5fc19828573fe3a872076613a0175ead2, not stripped
