USB host on Aster carrier board
I have Aster carrier board with Colibry imx7s module and my USB keyboard (or mouse) connected to USB host port is not working. According to datasheet there is only one USB port on imx7s module. I tried to using both of the two USB ports (it should be the bottom one) on Aster board without luck. Unfortunetly there is no 5V between pin 1 and 4 on USB ports.
I am using default linux shipped with imx7s module: Colibri_iMX7_LinuxImageV2.6_20160630
Where is a problem?
dmesg and lsusb output:
root@colibri-imx7:~#
dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.1.15-v2.6b2+g0ff849d (linuxdev@linuxdev.toradex.int) (gcc version 5.2.1 20151005 (Linaro GCC 5.2-2015.11-2) ) #1 SMP Tue Jun 28 13:09:24 CEST 2016
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine model: Toradex Colibri iMX7S on Colibri Evaluation Board V3
[    0.000000] Reserved memory: failed to allocate memory for node 'linux,cma'
[    0.000000] cma: Reserved 128 MiB at 0x88000000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] On node 0 totalpages: 65536
[    0.000000] free_area_init_node: node 0, pgdat 808f94c0, node_mem_map 87dba000
[    0.000000]   Normal zone: 512 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 65536 pages, LIFO batch:15
[    0.000000] PERCPU: Embedded 12 pages/cpu @87d92000 s16960 r8192 d24000 u49152
[    0.000000] pcpu-alloc: s16960 r8192 d24000 u49152 alloc=12*4096
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 65024
[    0.000000] Kernel command line: ubi.mtd=ubi root=ubi0:rootfs rootfstype=ubifs ubi.fm_autoconvert=1 console=tty1 console=ttymxc0,115200n8 consoleblank=0 mtdparts=gpmi-nand:512k(mx7-bcb),3584k(u-boot)ro,512k(u-boot-env),-(ubi)
[    0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Memory: 118780K/262144K available (6413K kernel code, 288K rwdata, 2144K rodata, 312K init, 380K bss, 12292K reserved, 131072K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0x90800000 - 0xff000000   (1768 MB)
[    0.000000]     lowmem  : 0x80000000 - 0x90000000   ( 256 MB)
[    0.000000]     modules : 0x7f000000 - 0x80000000   (  16 MB)
[    0.000000]       .text : 0x80008000 - 0x808639c8   (8559 kB)
[    0.000000]       .init : 0x80864000 - 0x808b2000   ( 312 kB)
[    0.000000]       .data : 0x808b2000 - 0x808fa140   ( 289 kB)
[    0.000000]        .bss : 0x808fd000 - 0x8095c26c   ( 381 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] Architected cp15 timer(s) running at 8.00MHz (phys).
[    0.000000] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns
[    0.000007] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns
[    0.000019] Switching to timer-based delay loop, resolution 125ns
[    0.000430] mxc_clocksource_init 3000000
[    0.000443] Ignoring duplicate/late registration of read_current_timer delay
[    0.000459] clocksource mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
[    0.001523] Console: colour dummy device 80x30
[    0.002138] console [tty1] enabled
[    0.002164] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=80000)
[    0.002207] pid_max: default: 32768 minimum: 301
[    0.002317] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.002345] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.002953] Initializing cgroup subsys freezer
[    0.002991] Initializing cgroup subsys debug
[    0.003043] CPU: Testing write buffer coherency: ok
[    0.003350] Setting up static identity map for 0x80008280 - 0x800082d8
[    0.004480] Brought up 1 CPUs
[    0.004512] SMP: Total of 1 processors activated (16.00 BogoMIPS).
[    0.004535] CPU: All CPU(s) started in SVC mode.
[    0.005021] devtmpfs: initialized
[    0.010303] device-tree: Duplicate name in lcdif@30730000, renamed to "display#1"
[    0.015139] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.015520] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.020665] pinctrl core: initialized pinctrl subsystem
[    0.021206] regulator-dummy: no parameters
[    0.021928] NET: Registered protocol family 16
[    0.027535] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.028493] cpuidle: using governor ladder
[    0.028527] cpuidle: using governor menu
[    0.037756] vdd1p0d: 800 <--> 1200 mV at 1000 mV
[    0.038172] vdd1p2: 1100 <--> 1300 mV
[    0.041743] DDR type is DDR3!
[    0.047696] imx7d_enet_clk_sel: failed to get enet_out clock, assuming ext. clock source
[    0.047774] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.047809] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.048125] imx7d-pinctrl 30270000.lpsr-gpr: initialized IMX pinctrl driver
[    0.048331] imx7d-pinctrl 302c0000.iomuxc-lpsr: initialized IMX pinctrl driver
[    0.049592] imx7d-pinctrl 30330000.iomuxc: initialized IMX pinctrl driver
[    0.050466] imx-gpcv2 303a0000.gpc: Looking up mipi-phy-supply from device tree
[    0.050538] imx-gpcv2 303a0000.gpc: Looking up pcie-phy-supply from device tree
[    0.051080] MU is ready for cross core communication!
[    0.060685] mxs-dma 33000000.dma-apbh: initialized
[    0.061381] 3P3V: 3300 mV
[    0.061422] reg-fixed-voltage regulators:3p3v: 3P3V supplying 3300000uV
[    0.061659] usb_otg2_vbus: 5000 mV
[    0.061694] reg-fixed-voltage regulators:regulator@1: usb_otg2_vbus supplying 5000000uV
[    0.061899] vref-1v8: 1800 mV
[    0.061945] reg-fixed-voltage regulators:regulator@3: vref-1v8 supplying 1800000uV
[    0.062369] SCSI subsystem initialized
[    0.062709] usbcore: registered new interface driver usbfs
[    0.062801] usbcore: registered new interface driver hub
[    0.062937] usbcore: registered new device driver usb
[    0.063169] usb_phy_generic 30800000.aips-bus:usbphy_nop1: Looking up vcc-supply from device tree
[    0.063185] usb_phy_generic 30800000.aips-bus:usbphy_nop1: Looking up vcc-supply property in node /soc/aips-bus@30800000/usbphy_nop1 failed
[    0.063197] 30800000.aips-bus:usbphy_nop1 supply vcc not found, using dummy regulator
[    0.063341] usb_phy_generic 30800000.aips-bus:usbphy_nop3: Looking up vcc-supply from device tree
[    0.064411] i2c i2c-0: IMX I2C adapter registered
[    0.064446] i2c i2c-0: can't use DMA
[    0.064954] i2c i2c-3: IMX I2C adapter registered
[    0.064984] i2c i2c-3: can't use DMA
[    0.065098] Linux video capture interface: v2.00
[    0.065171] pps_core: LinuxPPS API ver. 1 registered
[    0.065193] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.065261] PTP clock support registered
[    0.065779] Advanced Linux Sound Architecture Driver Initialized.
[    0.067059] Switched to clocksource arch_sys_counter
[    0.077569] NET: Registered protocol family 2
[    0.078328] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[    0.078389] TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
[    0.078448] TCP: Hash tables configured (established 2048 bind 2048)
[    0.078519] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.078567] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.078761] NET: Registered protocol family 1
[    0.079034] RPC: Registered named UNIX socket transport module.
[    0.079062] RPC: Registered udp transport module.
[    0.079083] RPC: Registered tcp transport module.
[    0.079104] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.081038] virtio_rpmsg_bus virtio0: rpmsg host is online
[    0.081163] imx rpmsg driver is registered.
[    0.081965] Bus freq driver module loaded
[    0.082777] futex hash table entries: 256 (order: 2, 16384 bytes)
[    0.091241] VFS: Disk quotas dquot_6.6.0
[    0.091461] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.093272] NFS: Registering the id_resolver key type
[    0.093341] Key type id_resolver registered
[    0.093364] Key type id_legacy registered
[    0.093399] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.093930] ntfs: driver 2.1.32 [Flags: R/W].
[    0.094468] fuse init (API version 7.23)
[    0.098849] io scheduler noop registered
[    0.098885] io scheduler deadline registered
[    0.099095] io scheduler cfq registered (default)
[    0.100930] pwm-backlight backlight: Looking up power-supply from device tree
[    0.100946] pwm-backlight backlight: Looking up power-supply property in node /backlight failed
[    0.100959] backlight supply power not found, using dummy regulator
[    0.102934] mxsfb 30730000.lcdif: Looking up lcd-supply from device tree
[    0.102951] mxsfb 30730000.lcdif: Looking up lcd-supply property in node /soc/aips-bus@30400000/lcdif@30730000 failed
[    0.102962] 30730000.lcdif supply lcd not found, using dummy regulator
[    0.168571] mxsfb 30730000.lcdif: failed to find mxc display driver
[    0.177298] Console: switching to colour frame buffer device 80x30
[    0.194844] mxsfb 30730000.lcdif: initialized
[    0.197738] imx-sdma 30bd0000.sdma: no event needs to be remapped
[    0.199585] imx-sdma 30bd0000.sdma: loaded firmware 4.2
[    0.204435] imx-sdma 30bd0000.sdma: initialized
[    0.207359] 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 280, base_baud = 1500000) is a IMX
[    0.926001] console [ttymxc0] enabled
[    0.932070] 30890000.serial: ttymxc1 at MMIO 0x30890000 (irq = 281, base_baud = 1500000) is a IMX
[    0.945154] 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 282, base_baud = 5000000) is a IMX
[    0.964267] loop: module loaded
[    0.971118] DCDC1: 975 <--> 1125 mV at 1000 mV
[    0.972439] DCDC2: 975 <--> 1125 mV at 1100 mV
[    0.973767] DCDC3: 1775 <--> 1825 mV at 1800 mV
[    0.975095] DCDC4: 1325 <--> 1375 mV at 1350 mV
[    0.976403] LDO1: 1800 <--> 3300 mV at 3300 mV
[    0.977181] LDO2: 1775 <--> 3325 mV at 3300 mV
[    0.977964] LDO3: 3275 <--> 3325 mV at 3300 mV
[    0.978735] LDO4: 1775 <--> 1825 mV at 1800 mV
[    0.979508] LDO5: 1775 <--> 1825 mV at 3300 mV
[    0.980269] LDORTC1: at 3000 mV
[    0.981007] LDORTC2: at 900 mV
[    0.988559] nand: device found, Manufacturer ID: 0xc2, Chip ID: 0xdc
[    0.996838] nand: Macronix MX30LF4G28AB
[    1.002597] nand: 512 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 112
[    1.014476] gpmi-nand 33002000.gpmi-nand: enable the asynchronous EDO mode 5
[    1.023728] Bad block table found at page 262080, version 0x01
[    1.031798] Bad block table found at page 262016, version 0x01
[    1.039999] 4 cmdlinepart partitions found on MTD device gpmi-nand
[    1.048276] Creating 4 MTD partitions on "gpmi-nand":
[    1.055411] 0x000000000000-0x000000080000 : "mx7-bcb"
[    1.062937] 0x000000080000-0x000000400000 : "u-boot"
[    1.070257] 0x000000400000-0x000000480000 : "u-boot-env"
[    1.077843] 0x000000480000-0x000020000000 : "ubi"
[    1.085569] gpmi-nand 33002000.gpmi-nand: driver registered.
[    1.095023] spi_imx 30840000.ecspi: probed
[    1.102809] fec 30be0000.ethernet: Looking up phy-supply from device tree
[    1.103343] pps pps0: new PPS source ptp0
[    1.111233] libphy: fec_enet_mii_bus: probed
[    1.119076] fec 30be0000.ethernet eth0: registered PHC device 0
[    1.126965] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.135462] ehci-mxc: Freescale On-Chip EHCI Host driver
[    1.142893] usbcore: registered new interface driver usb-storage
[    1.150970] usbcore: registered new interface driver usbserial
[    1.158645] usbcore: registered new interface driver usbserial_generic
[    1.166888] usbserial: USB Serial support registered for generic
[    1.174686] usbcore: registered new interface driver ftdi_sio
[    1.182189] usbserial: USB Serial support registered for FTDI USB Serial Device
[    1.192889] usbcore: registered new interface driver pl2303
[    1.200233] usbserial: USB Serial support registered for pl2303
[    1.208950] usbmisc_imx 30b10200.usbmisc: Looking up vbus-wakeup-supply from device tree
[    1.208967] usbmisc_imx 30b10200.usbmisc: Looking up vbus-wakeup-supply property in node /soc/aips-bus@30800000/usbmisc@30b10200 failed
[    1.208987] 30b10200.usbmisc supply vbus-wakeup not found, using dummy regulator
[    1.219862] usbmisc_imx 30b30200.usbmisc: Looking up vbus-wakeup-supply from device tree
[    1.219877] usbmisc_imx 30b30200.usbmisc: Looking up vbus-wakeup-supply property in node /soc/aips-bus@30800000/usbmisc@30b30200 failed
[    1.219888] 30b30200.usbmisc supply vbus-wakeup not found, using dummy regulator
[    1.231504] imx_usb 30b10000.usb: Looking up vbus-supply from device tree
[    1.231519] imx_usb 30b10000.usb: Looking up vbus-supply property in node /soc/aips-bus@30800000/usb@30b10000 failed
[    1.231531] 30b10000.usb supply vbus not found, using dummy regulator
[    1.242645] ci_hdrc ci_hdrc.0: EHCI Host Controller
[    1.249454] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[    1.277114] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[    1.285401] hub 1-0:1.0: USB hub found
[    1.291185] hub 1-0:1.0: 1 port detected
[    1.297963] mousedev: PS/2 mouse device common for all mice
[    1.308162] input: AD7879 Touchscreen as /devices/platform/soc/30800000.aips-bus/30a20000.i2c/i2c-0/0-002c/input/input0
[    1.323638] rtc-ds1307: probe of 3-0068 failed with error -5
[    1.331977] snvs_rtc 30370000.snvs:snvs-rtc-lp: rtc core: registered 30370000.snvs:snvs- as rtc0
[    1.344941] i2c /dev entries driver
[    1.352811] imx2-wdt 30280000.wdog: timeout 60 sec (nowayout=0)
[    1.361202] sdhci: Secure Digital Host Controller Interface driver
[    1.369547] sdhci: Copyright(c) Pierre Ossman
[    1.376021] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.384610] /soc/aips-bus@30800000/usdhc@30b40000: voltage-ranges unspecified
[    1.393927] sdhci-esdhc-imx 30b40000.usdhc: Got CD GPIO
[    1.403912] sdhci-esdhc-imx 30b40000.usdhc: Looking up vmmc-supply from device tree
[    1.403936] sdhci-esdhc-imx 30b40000.usdhc: Looking up vmmc-supply property in node /soc/aips-bus@30800000/usdhc@30b40000 failed
[    1.403962] sdhci-esdhc-imx 30b40000.usdhc: Looking up vqmmc-supply from device tree
[    1.403975] sdhci-esdhc-imx 30b40000.usdhc: Looking up vqmmc-supply property in node /soc/aips-bus@30800000/usdhc@30b40000 failed
[    1.403988] sdhci-esdhc-imx 30b40000.usdhc: No vmmc regulator found
[    1.412414] sdhci-esdhc-imx 30b40000.usdhc: No vqmmc regulator found
[    1.467213] mmc0: SDHCI controller on 30b40000.usdhc [30b40000.usdhc] using ADMA
[    1.482892] caam 30900000.caam: Entropy delay = 3200
[    1.489911] caam 30900000.caam: Instantiated RNG4 SH0
[    1.549324] caam 30900000.caam: Instantiated RNG4 SH1
[    1.556230] caam 30900000.caam: device ID = 0x0a16030000000000 (Era -524)
[    1.564905] caam 30900000.caam: job rings = 3, qi = 0
[    1.580060] caam algorithms registered in /proc/crypto
[    1.590680] caam_jr 30901000.jr0: registering rng-caam
[    1.598727] hidraw: raw HID events driver (C) Jiri Kosina
[    1.606194] usbcore: registered new interface driver usbhid
[    1.613653] usbhid: USB HID core driver
[    1.619591] imx7d_adc 30610000.adc: Looking up vref-supply from device tree
[    1.620439] imx7d_adc 30620000.adc: Looking up vref-supply from device tree
[    1.623100] coresight-tmc 30086000.etr: TMC initialized
[    1.630692] coresight-tmc 30084000.etf: TMC initialized
[    1.637908] coresight-tpiu 30087000.tpiu: TPIU initialized
[    1.645374] coresight-funnel 30083000.funnel: FUNNEL initialized
[    1.653332] coresight-funnel 30041000.funnel: FUNNEL initialized
[    1.661281] coresight-replicator replicator: REPLICATOR initialized
[    1.669774] coresight-etm3x 3007c000.etm: ETM initialized
[    1.683810] imx-sgtl5000 sound: ASoC: CODEC DAI sgtl5000 not registered
[    1.692140] imx-sgtl5000 sound: snd_soc_register_card failed (-517)
[    1.700162] Netfilter messages via NETLINK v0.30.
[    1.706449] nfnl_acct: registering with nfnetlink.
[    1.712876] nf_conntrack version 0.5.0 (3903 buckets, 15612 max)
[    1.721059] nf_tables: (c) 2007-2009 Patrick McHardy <kaber@trash.net>
[    1.729702] ip_tables: (C) 2000-2006 Netfilter Core Team
[    1.737316] NET: Registered protocol family 10
[    1.744360] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    1.751442] sit: IPv6 over IPv4 tunneling driver
[    1.758421] NET: Registered protocol family 17
[    1.764559] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    1.780626] Bridge firewalling registered
[    1.786432] 8021q: 802.1Q VLAN Support v1.8
[    1.792390] Key type dns_resolver registered
[    1.798868] cpu cpu0: Looking up arm-supply from device tree
[    1.798954] cpu cpu0: dev_pm_opp_get_opp_count: device OPP not found (-19)
[    1.814068] Registering SWP/SWPB emulation handler
[    1.821329] registered taskstats version 1
[    1.832710] sgtl5000 0-000a: sgtl5000 revision 0x11
[    1.874857] 0-000a: 1200 mV normal
[    1.874892] sgtl5000 0-000a: Using internal LDO instead of VDDD
[    1.882302] sgtl5000 0-000a: Looking up VDDA-supply from device tree
[    1.882394] sgtl5000 0-000a: Looking up VDDIO-supply from device tree
[    1.882438] sgtl5000 0-000a: Looking up VDDD_LDO-supply from device tree
[    1.882450] sgtl5000 0-000a: Looking up VDDD_LDO-supply property in node /soc/aips-bus@30800000/i2c@30a20000/sgtl5000@0a failed
[    1.893621] imx-sgtl5000 sound: sgtl5000 <-> 308a0000.sai mapping ok
[    1.902804] ubi0: default fastmap pool size: 200
[    1.908956] ubi0: default fastmap WL pool size: 100
[    1.915290] ubi0: attaching mtd3
[    2.016302] ubi0: attached by fastmap
[    2.021418] ubi0: fastmap pool size: 200
[    2.026701] ubi0: fastmap WL pool size: 100
[    2.040003] ubi0: attached mtd3 (name "ubi", size 507 MiB)
[    2.046875] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[    2.055177] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[    2.063362] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[    2.071736] ubi0: good PEBs: 4056, bad PEBs: 4, corrupted PEBs: 0
[    2.079241] ubi0: user volume: 4, internal volumes: 1, max. volumes count: 128
[    2.089261] ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
[    2.100467] ubi0: available PEBs: 0, total reserved PEBs: 4056, PEBs reserved for bad PEB handling: 76
[    2.112768] ubi0: background thread "ubi_bgt0d" started, PID 137
[    2.123051] snvs_rtc 30370000.snvs:snvs-rtc-lp: setting system clock to 2017-08-14 10:04:57 UTC (1502705097)
[    2.153989] usb_otg2_vbus: disabling
[    2.160089] ALSA device list:
[    2.164570]   #0: imx7-colibri-sgtl5000
[    2.202713] UBIFS (ubi0:3): UBIFS: mounted UBI device 0, volume 3, name "rootfs", R/O mode
[    2.214081] UBIFS (ubi0:3): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[    2.227251] UBIFS (ubi0:3): FS size: 493428736 bytes (470 MiB, 3886 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs)
[    2.241412] UBIFS (ubi0:3): reserved for root: 0 bytes (0 KiB)
[    2.249084] UBIFS (ubi0:3): media format: w4/r0 (latest is w4/r0), UUID 95D36B06-3246-4BE6-BF17-C54888025346, small LPT model
[    2.264815] VFS: Mounted root (ubifs filesystem) readonly on device 0:13.
[    2.274290] devtmpfs: mounted
[    2.279410] Freeing unused kernel memory: 312K (80864000 - 808b2000)
[    2.373960] random: nonblocking pool is initialized
[    2.412343] systemd[1]: systemd 226 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD +IDN)
[    2.436844] systemd[1]: Detected architecture arm.
[    2.468279] systemd[1]: Set hostname to <colibri-imx7>.
[    2.786747] systemd[1]: Listening on networkd rtnetlink socket.
[    2.817848] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    2.847424] systemd[1]: Listening on Journal Socket (/dev/log).
[    2.878693] systemd[1]: Created slice System Slice.
[    2.907666] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    2.953930] systemd[1]: Listening on udev Kernel Socket.
[    2.977513] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    3.007272] systemd[1]: Reached target Paths.
[    3.027263] systemd[1]: Reached target Swap.
[    3.047570] systemd[1]: Created slice User and Session Slice.
[    3.077437] systemd[1]: Listening on udev Control Socket.
[    3.107438] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    3.137430] systemd[1]: Listening on Journal Socket.
[    3.171750] systemd[1]: Starting Load Kernel Modules...
[    3.198997] systemd[1]: Mounting Debug File System...
[    3.224092] systemd[1]: Starting File System Check on Root Device...
[    3.258768] systemd[1]: Starting (null)...
[    3.288547] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    3.338917] systemd[1]: Starting Journal Service...
[    3.360491] systemd[1]: Starting Setup Virtual Console...
[    3.397792] systemd[1]: Created slice system-getty.slice.
[    3.427984] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    3.470193] systemd[1]: Mounting Temporary Directory...
[    3.507331] systemd[1]: Reached target Slices.
[    3.530274] systemd[1]: Mounted Debug File System.
[    3.557309] systemd[1]: Mounted Temporary Directory.
[    3.578193] systemd[1]: Started Journal Service.
[    3.838269] UBIFS (ubi0:3): background thread "ubifs_bgt0_3" started, PID 174
[    4.217210] systemd-journald[160]: Received request to flush runtime journal from PID 1
[    5.518712] CAN device driver interface
[    5.567664] mcp251x spi2.0: Looking up vdd-supply from device tree
[    5.567685] mcp251x spi2.0: Looking up vdd-supply property in node /soc/aips-bus@30800000/spba-bus@30800000/ecspi@30840000/mcp258x@1 failed
[    5.567706] spi2.0 supply vdd not found, using dummy regulator
[    5.575021] mcp251x spi2.0: Looking up xceiver-supply from device tree
[    5.575034] mcp251x spi2.0: Looking up xceiver-supply property in node /soc/aips-bus@30800000/spba-bus@30800000/ecspi@30840000/mcp258x@1 failed
[    5.575043] spi2.0 supply xceiver not found, using dummy regulator
[    7.154213] using random self ethernet address
[    7.160193] using random host ethernet address
[    7.557332] fec 30be0000.ethernet eth0: Freescale FEC PHY driver [Micrel KSZ8041] (mii_bus:phy_addr=30be0000.etherne:00, irq=-1)
[    7.578562] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   11.557680] fec 30be0000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[   11.565632] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
root@colibri-imx7:~# lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
On the Colibri iMX7 module only one USB port is available (lower port at X9 and X10 connectors on Aster board).
This port has a dual role (Host/Client) and if +5V voltage is detected on the X10 connector it will be switched to device mode and +5V power to X9 will be disabled.
According to the log provided you have a cable connected to X10. If you want to use this port as a host - disconnect the USB cable from X10.
Hi
Note that on top of Alex’s answer, for the Colibri iMX7S you need this patch in order to switch on VBUS on an Aster carrier board.
I recommend updating to the latest and greatest image.
Max
I do not have connected cable to X10 connector and I am using lower conector on X9. I will try newest linux image…
Thanks.
so I updating to latest linux image “Colibri-iMX7_LXDE-Image_2.7b3±20170630.tar.bz2” using sdcard and uart console but imx7s module not wake up after reset. UART console and also VGA display are empty after reset. Device looks dead …
Colibri iMX7 # run setupdate
reading colibri_imx7/flash_blk.img
2681 bytes read in 19 ms (137.7 KiB/s)
## Executing script at 80800000
enter "run update" to update the entire module
Colibri iMX7 # run update
reading colibri_imx7/u-boot-nand.imx
606208 bytes read in 45 ms (12.8 MiB/s)
NAND erase.part: device 0 offset 0x80000, size 0x180000
Erasing at 0x80000 --   8% complete.Erasing at 0xa0000 --  16% complete.Erasing at 0xc0000 --  25% complete.Erasing at 0xe0000 --  33% complete.Erasing at 0x100000 --  41% complete.Erasing at 0x120000 --  50% complete.Erasing at 0x140000 --  58% complete.Erasing at 0x160000 --  66% complete.Erasing at 0x180000 --  75% complete.Erasing at 0x1a0000 --  83% complete.Erasing at 0x1c0000 --  91% complete.Erasing at 0x1e0000 -- 100% complete.
OK
NAND write: device 0 offset 0x80000, size 0x94000
 606208 bytes written: OK
NAND erase.part: device 0 offset 0x200000, size 0x180000
Erasing at 0x200000 --   8% complete.Erasing at 0x220000 --  16% complete.Erasing at 0x240000 --  25% complete.Erasing at 0x260000 --  33% complete.Erasing at 0x280000 --  41% complete.Erasing at 0x2a0000 --  50% complete.Erasing at 0x2c0000 --  58% complete.Erasing at 0x2e0000 --  66% complete.Erasing at 0x300000 --  75% complete.Erasing at 0x320000 --  83% complete.Erasing at 0x340000 --  91% complete.Erasing at 0x360000 -- 100% complete.
OK
NAND write: device 0 offset 0x200000, size 0x94000
ubi0: detaching mtd1
ubi0: mtd1 is detached
ubi0: attaching mtd1
ubi0: scanning is finished
ubi0: attached mtd1 (name "mtd=4", size 508 MiB)
ubi0: good PEBs: 4060, bad PEBs: 4, corrupted PEBs: 0
ubi0: user volume: 0, internal volumes: 1, max. volumes count: 128
ubi0: available PEBs: 3978, total reserved PEBs: 82, PEBs reserved for bad PEB handling: 76
Creating static volume kernel of size 8388608
Creating static volume dtb of size 131072
Creating static volume m4firmware of size 917504
No size specified -> Using max size (495333376)
Creating dynamic volume rootfs of size 495333376
reading colibri_imx7/zImage
5114048 bytes read in 242 ms (20.2 MiB/s)
5114048 bytes written to volume kernel
reading colibri_imx7/imx7s-colibri-eval-v3.dtb
42233 bytes read in 25 ms (1.6 MiB/s)
42233 bytes written to volume dtb
reading colibri_imx7/ubifs.img
172560384 bytes read in 7527 ms (21.9 MiB/s)
172560384 bytes written to volume rootfs
resetting ...
The first time i updated my IMX7D, it failed.
Try the method Flashing_from_Scratch
