I just successfully used the easy installer on a Colibri iMX6S, but I just tried it again on the iMX6DL and I got stuck right after starting the kernel for the easy installer. I put the device into recovery mode using the bmode usb command then ran the recovery script and ran into these errors:
Starting kernel ...
[ 0.417866] fec 2188000.ethernet (unnamed net_device) (uninitialized): Invalid MAC address: 00:000
[ 0.435831] imx_usb 2184000.usb: Can't register ci_hdrc platform device, err=-517
[ 0.723183] snvs-secvio 20cc000.caam-snvs: can't get snvs clock
Running /etc/rc.local...
/ # [ 2.348738] sd 0:0:0:0: [sda] No Caching mode page found
[ 2.354210] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 3.093672] blk_update_request: I/O error, dev sda, sector 16256
[ 3.193653] blk_update_request: I/O error, dev sda, sector 16256
[ 3.199699] Buffer I/O error on dev sda, logical block 2032, async page read
Added Details--------------------------------------------------------------------------
My issues are with the Colibri iMX6DL 512MB with a eDM-CB-Colibri Baseboard developed by DATA MODUL (version August 2015)
The software version is:
Angstrom v2014.12 - Kernel 3.10.17
Colibri_iMX6_LinuxImageV2.4_20150518
There was no usb or sd card inserted and the only things connected to the device are an ethernet, micro usb to host computer, and serial cable to host computer.
When it boots (successfully) into the older image off the eMMC, I noticed it keeps giving a similar error repeatedly before it finishes booting:
[ 13.438510] Read(10): 28 00 00 00 10 00 00 00 08 00
[ 13.542023] sd 0:0:0:0: [sda] Unhandled error code
[ 13.546864] sd 0:0:0:0: [sda]
[ 13.550026] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[ 13.555651] sd 0:0:0:0: [sda] CDB:
The only usb stick that I have been using with the device shows up as “sdb” not “sda”. I ran the usb commands and the only removable storage device is the easyTOUCH (touchscreen driver?) that came with this device. DATA MODUL is the company we bought our entire device from.
Colibri iMX6 # usb start
starting USB...
USB0: Port not available.
USB1: USB EHCI 1.00
scanning bus 1 for devices... 3 USB Device(s) found
scanning usb for storage devices... 1 Storage Device(s) found
scanning usb for ethernet devices... 0 Ethernet Device(s) found
Colibri iMX6 # usb tree
USB device tree:
1 Hub (480 Mb/s, 0mA)
| u-boot EHCI Host Controller
+-2 Hub (480 Mb/s, 2mA)
+-3 Mass Storage (12 Mb/s, 100mA)
DATA MODUL easyTOUCH 5Y061
Colibri iMX6 # usb storage
Device 0: Vendor: DM Rev: 1.00 Prod: easyTOUCH
Type: Removable Hard Disk
Capacity: 8.0 MB = 0.0 GB (16384 x 512)
Colibri iMX6 # usb part sda
Partition Map for USB device 0 -- Partition Type: DOS
