I cloned this commit that sanchayan.tx linked to me as well as all of its dependencies, and I have the environment ready to build the new image. But I got confused when it came to the files in buildconf. I know in this commit, there’s a directory called buildconf with the correct configuration files. The README file in that directory says how the conf files are hardlinked to build/conf, so do I only specify the machine in buildconf/local.conf and it will automatically overwrite whatever is in build/conf? Or should I just use the information in buildconf/local.conf and buildconf/bblayers.conf and copy paste it to build/conf/local.conf and build/conf/bblayers.conf?
If the information in meta-toradex-demos/buildconf does overwrite oe-core/build/conf, I want to make sure I have it in the right directory. I have all of the meta files including ‘meta-toradex-demos’ in the oe-core directory and just wanted to make sure that was the right place to put them. Also, buildconf/local.conf is read only so I can’t change the machine variable without jumping through some hoops with vi, I just wanted to make sure that it was supposed to be read only, unless I did something wrong.
I tried following that tutorial but I keep getting ‘permission denied’ when I try to run the curl command, even when I use sudo. My understanding is that all I need to do are those first few commands:
because right now when I try to source export using ‘. export’ it just says ‘no such file or directory’. Before, I just ran ‘source ./oe-init-build-env’.
@YogurtCrampz I don’t recommend using sudo for the curl command. What does ls -l ~/bin output? Ensure that ‘~/bin’ has suitable permissions for you to write a file in there. Once you obtain repo and execute the repo init & repo sync commands, then you can . export.
If you continue having issues and you are using ubuntu, you can obtain repo by installing the phablet-tools package: sudo apt-get install phablet-tools.
Thank you, that was the issue. I must have created ~/bin as sudo for some reason. I also must have used sudo when i cloned the commit. That’s likely why I was having read-only issues with local.conf.
In this link that max.tx sent, it says to repo init -u http://git.toradex.com/toradex-bsp-platform.git -b LinuxImageV2.7 but I was told to try using the morty-next branch of the meta-toradex-demos and building from that.
After cloning all the dependencies stated in the README, including openembedded-core, running . export gives bash: export: No such file or directory, so I found this page that gives a very basic method of using openembedded-core, but doesn’t include . export.
If you wouldn’t mind, could you please explain the difference between using source oe-init-build-env and . export, and possibly why . export isn’t working in my case?
use repo init ... and repo sync to setup the meta data for the latest release of 2.7
go to layer/meta-toradex-demos and use git to checkout whatever later version you need.
e.g.
cd layers/meta-toradex-demos
git merge morty-next
git branch my-branch
Note that all are -next branches are unstable and we often rebase them.
export is a wrapper to oe-init-build-env which sets the builddir directory name, is meant to be run from the oe-core/ directory and, on first invocation, copies an initial local.conf and bblayers.conf aimed at Toradex targets.
export is normaly copied to oe-core/ by the repo tool. Since you set up the layers manually you would have to this also manually, e.g. cd ..../oe-core; cp layers/meta-toradex-demos/buildconf/export . .
Have a look here for an explanation on the dot command.
In some shells, notably bash source is a synonym of . . So . export and source export are two ways to execute the file export in the current shell’s context.
