Can you tell if Devicetree supports the FT5X26 chip? link textI uploaded a clip out o the schematic. The hardware interface is I2C
The device tree is only a data structure, it will support anything… It is the kernel and drivers which either can do something with this data or not.
The kernel has a Documentation folder which documents all drivers which can read device tree bindings, and how they have to be formatted under Documentation/devicetree/bindings
. A quick search brought up this binding document: edt-ft5x06.txt. I am not sure whether this driver is compatible since the chip mentioned in the drivers have a slightly different type number.
