Hello all,
I’m trying to recover a colibri 1.1a which does not boot anymore due to an error updating uboot. I’ve solved a similar issue on a few other colibri 1.0 using a Colibri evaluation board 3.2 following the procedure explained in Txx Recovery Mode | Toradex Developer Center :
Connect USB Standard B or Micro B to the X29 or X30 respectively on the Eval board and USB A to your PC.
Power on the Eval board.
Press and keep pressed (or hold) the recovery mode button SW9 and immediately press and release the reset button SW8 on the Eval board.
After 2-5 seconds, release the recovery mode button SW9.
After this point with our colibri 1.0 we see an entry listed in lspci. Unfortunately we see no entry with our colibri 1.1a, hence it is not possible to use update.sh to recover.
Do we have to change the procedure to recover the newer version of the imx6 using a colibri evaluation board?
I understand that the link refers to tegra modules, unfortunately I did not found any help page for the imx6 based modules. Moreover the procedure worked fine with colibri imx6 1.0.
If I understand the problem correctly with colibri 1.1, once I complete the fourth point of the procedure appears this device in lsusb
Bus 003 Device 006: ID 1b67:400f
1b67 appears to be a vendor id which refers to toradex, and it is not one of the devices update.sh looks for during the restore procedure
Then you are most likely not in the recovery mode but rather the factory pre-installed Toradex Easy Installer is running. Either update the module by using the Toradex Easy Installer or make sure to actually enter the recovery mode but shortening resp. pad on the module as indicated in the data sheet or the bmode usb U-Boot command entered via serial debug console.
