So your module looks like being quite healthy just sitting in recovery mode. Please try either the legacy recovery procedure as described in the following article on our developer website or alternatively try our new Toradex Easy Installer recovery as mentioned here.
I was able to recover one of the modules using the procedure mentioned above. I have another module which is not in recovery mode i.e. lsusb does not show the module.
The module does not show up in lsusb output. There is no device with ID - 15a2:0061 on lsusb output.
The module is “Colibri imx6S 256MB V1.0A” with Iris Rev 1.1. I cannot recollection which version of Linux I was using. It is most likely greater than v2.5.
I will try to answer as many question as I can. Please let me know what additional information I can supply you with.
Well, if it does not enumerate as a USB device even after properly shorting the recovery mode pad and power-cycling then there is something entirely wrong with it. I suggest you doing an RMA so we may analyse it further.
