With the 2.1Beta2 it is possible to lower the temp quit a bit more then 1 °.
With the latest build it seems the EMC clk is set to 400 MHz. This generate a lot of heat.
Lower it to 266 MHz helps a lot and disabling cores also do help.
I have compared the board with low power consumption with the board with high power consumption.
I noticed that in the Colibri monitor certain settings are different.
CPU: 500MHz should be: 216MHz
SYS: 100MHz should be: 36MHz
AVP: 100MHz should be: 36MHz
AHB: 100MHz should be: 36MHz
APB: 25 MHz should be: 25 MHz
VID: 408 MHz should be: 408 MHz
EMC: 266MHz should be: 266MHz
Would be very nice if you can give me a guidance as I can change the settings accordingly.
Furthermore, it would be helpful for me to know what the lowest possible value is.
