I use the Colibri T20 and WinCE7 and have problems with the state some pins when Colibri goes sleep/wake up, also when the power is turned on.
There is in ConfigBlock this configuration:
[colibripin_107] altfn=-1 dir=out lvl=0 [colibripin_32] altfn=-1 dir=out lvl=1
After loading the operating system the state of these pins corresponds to the specified: Pin107-out low level, Pin32- out high level.
But in the process of loading, as well as when Colibri wakes up by timer, the state of the pins changes - I see the oscilloscope negative pulse 4ms on pin 39. Similarly, pin 107, but there the pulse is positive.
The fact that the state of the pins varies in the process of loading does not bother me, but it strongly hinders when the device wakes up - pins are GPIO and used to control other devices.
How to make sure that the pins do not change the state when Colibri wakes up by timer? Maybe I should use other pins (which ones)?
Code for enter suspend mode:
SYSTEMTIME st;
FILETIME ft;
static CE_USER_NOTIFICATION un = {0};
// add 30 seconds to the current time
GetLocalTime(&st);
SystemTimeToFileTime(&st, &ft);
(*((DWORD64*)&ft)) += 10000000 * 30; // 1 unit = 100ns
FileTimeToSystemTime(&ft, &st);
if(!CeSetUserNotification(NULL, L"", &st, &un))
//Error!!!!
return;
// enter suspend mode
DWORD R = SetSystemPowerState(NULL, POWER_STATE_SUSPEND, POWER_FORCE);
