I see there is a nice Automotive Cluster Display Demo on the Developer Center (here) but it is for Qt 4.8.4 with WinCE7.
I’d like to try it on VF61 module with WinCE6, but when I load into VS2008 I see the error message
"The project consists entirely of configurations that require support for platforms which are not
installed on this machine. The project can not be loaded"
Since I’m a beginner with Toradex module I don’t know if I should modify something either in VS2008 or in the project itself to have it working under WinCE6.
create a build folder somewhere next to the deflated sources.
open VS command line
Navigate to created build folder
type in C:\Qt\4.8.4\bin\qmake.exe <path to sources>
Open in Visual Studio 2008 the project file which got created
Open project settings and change under debugging and deployment all occurrences from %CSIDL_PROGRAM_FILES% to \flashdisk
make sure conmanclient2 and cmaccept are started on target(beware you need to connect to target in 2 minutes after starting cmaccept, otherwise you need to run it again)
Tools → Options… → Device Tools → Devices → Select Toradex_CE600 → Properties → Configure … → Use specific IP address and fill in your targets ip address. Click 2 x ok
Start debugging and see after a while the application on the screen of the Colibri VF61
Hint: Conmanclient2 was crashing when I tried to deploy the application a second time, files on flashdisk needed to be deleted before deploying again.
I followed your instructions step-by-step, but at step #10 I get the following output from qmake
Usage: C:\Qt\4.8.4\bin\qmake.exe [mode] [options] [files]
QMake has two modes, one mode for generating project files based on
some heuristics, and the other for generating makefiles. Normally you
shouldn't need to specify a mode, as makefile generation is the default
mode for qmake, but you may use this to test qmake on an existing project
Mode:
-project Put qmake into project file generation mode
In this mode qmake interprets files as files to
be built,
defaults to *.c; *.ui; *.y; *.l; *.ts; *.xlf; *.qrc; *.h; *.hpp; *.hh; *.hxx; *.cpp; *.cc; *.cxx
Note: The created .pro file probably will
need to be edited. For example add the QT variable to
specify what modules are required.
-makefile Put qmake into makefile generation mode (default)
In this mode qmake interprets files as project files to
be processed, if skipped qmake will try to find a project
file in your current working directory
Warnings Options:
-Wnone Turn off all warnings; specific ones may be re-enabled by
later -W options
-Wall Turn on all warnings
-Wparser Turn on parser warnings
-Wlogic Turn on logic warnings (on by default)
-Wdeprecated Turn on deprecation warnings (on by default)
Options:
* You can place any variable assignment in options and it will be *
* processed as if it was in [files]. These assignments will be parsed *
* before [files]. *
-o file Write output to file
-d Increase debug level
-t templ Overrides TEMPLATE as templ
-tp prefix Overrides TEMPLATE so that prefix is prefixed into the value
-help This help
-v Version information
-after All variable assignments after this will be
parsed after [files]
-norecursive Don't do a recursive search
-recursive Do a recursive search
-set <prop> <value> Set persistent property
-unset <prop> Unset persistent property
-query <prop> Query persistent property. Show all if <prop> is empty.
-cache file Use file as cache [makefile mode only]
-spec spec Use spec as QMAKESPEC [makefile mode only]
-nocache Don't use a cache file [makefile mode only]
-nodepend Don't generate dependencies [makefile mode only]
-nomoc Don't generate moc targets [makefile mode only]
-nopwd Don't look for files in pwd [project mode only]
Sorry for the late answer. Most likely you are using a space in your path, which might need wrapping into quotes or even better dont use paths with spaces.
This is not a problem Andy.
As a matter of fact you had already answered to my message on qmake error with your comment below your original answer.
You had already edited the original answer with the right step #10 command
