I am porting Windows Source for Windows CE 8 using Toradex Windows Embedded Compact 2013 SDK.
I understand that no privilege concept exists in windows CE.But if it is so , why are privilege related structures defined in the winnt.h. Also I could see NT Defined Privileges Macros in winnt.h header file.What is the use of those macros if no API is defined related to the privilege concept?
Thanks for your help in advance.
Regards, Kamaldeep
