I want to enter the bootloader menu in order to to enable the debug output. I followed the instruction provided on this website. I pressed the “space”-key but the boot process was not stopped to enter the bootloader menu.
Make sure you considered the following points:
- Press the “space”-key on the serial terminal, not on keyboard you have attached to your Toradex device.
- Some terminal Tools do not send the characters fast enough. We made good experience with TeraTerm.
- Make sure you have set up the correct baud rate.
