Following instructions from installing jetpack with l4t after “Flashing Linux Kernel and Root File System” step boot process stalls with such error:
Mount failed for selinuxfs on /sys/fs/selinux: No such file or directory
Starting NSM status monitor[fail]
Stopping NSM status monitor[ OK ]
The disk drive for / is not ready yet or not present.
keys:Continue to wait, or Press S to skip mounting or M for manual recovery
keys:
The disk drive for /tmp is not ready yet or not present.
keys: Continue to wait, or Press S to skip mounting or M for manual recovery
After pressing ‘M’ boot continues and bash terminal is available, but monitor is not working properly.
Seems that it is not correct behaviour. What could be the cause of such error, or maybe there are some tips to deal with this problem?
Note: SD card(Fat32) was used for storing boot files.
