I am able to build (bitabake) a kernel image (angstrom-lxde-image) as described in the link
I then added the PREFERRED_PROVIDER_virtual/kernel = “linux-toradex-rt” to my conf/local.conf as described in the link (Real-Time Linux | Toradex Developer Center)
bitabake fails with ERROR:angstrom-lxde-image-2.7b4-r0 do_rootfs()
I then removed the oe-core folder and started from scratch and tried to bitbake with the PREFERRED_PROVIDER_virtual/kernel = “linux-toradex-rt” added to my conf/local.conf i.e. a clean build.
However, the result is the same, bitbake fails with the same Error do_rootfs()
What am I missing? Is the real time not available on the 2.7b4-r0 branch? If yes, which branch do I need to go back to?
Collected errors:
* calculate_dependencies_for: Cannot satisfy the following dependencies for backports:
* backports-kernel-module-crc-ccitt *
* opkg_solver_install: Cannot install package backports.
With the 2.7b4 image we added through the linux backports project newer Wi-Fi drivers to the image recipes. To do this we needed to change among other things that the crc-ccitt functionality is no longer compiled as a kernel module but this change did not make it into the RT defconfigs.
To get around the error you could do one of the following:
If you do not use the Wi-Fi drivers you could remove ‘backports’ from IMAGE_INSTALL, e.g. delete it in ‘meta-toradex-demos/recipes-images/images/tdx-extra.inc’ or add 'IMAGE_INSTALL_remove = “backports” ’ to local.conf.
Cherry-pick commit 51947d7283925979581488970a0d048a02374987
‘linux-toradex-rt: follow changes needed for backports’ into meta-toradex-nxp to get the needed changes to the kernel’s defconfig.
Add ‘CONFIG_CRC_CCITT=y’ to meta-toradex-nxp/recipes-kernel/linux/linux-toradex-rt-4.1-2.0.x/colibri-imx6/defconfig.
