Hi guys,
I have connected EM358 Zigbee chip with the Colibri VF50 via UART.but there was colibri module unable to read the data from serial line.
Just Highlight what I did:
EM358<----UART-B/C(X14)------>Colibri Module(VF50,Iris Carrier Board)
I wrote the C code for the Opening file /dev/ttyLP2 and setting baud rate B115200.
I used write system call and wrote the data onto the UART line and there was I have already putted code in EM358 chip for loopback mechanism.whatever you send to uart line you will get back that data.
Read system call failed to read on UART line
so I am confused,where is exactly problem in that?
could you share helpful information regarding this issue.
C code snippet:
#include
#include
#include
#include
#include
#include
#include
#include
int main()
char snd_buff[20]= "^KANJI~";
char rcv_buff[30];
struct termios tty;
int fd;
int flags = O_RDWR | O_NOCTTY | O_NONBLOCK;
fd = open("/dev/ttyLP2", flags);
perror("fd");
tcgetattr(fd, &tty);
tty.c_cflag = (tty.c_cflag & ~CSIZE) | CS8;
tty.c_cflag |= B115200;
if (tcsetattr (fd, TCSANOW, &tty) != 0)
fprintf (stderr, "error %d from tcsetattr", errno);
return -1;
memset(rcv_buff,0x0,sizeof(rcv_buff));
while(1)
printf("**************Hi I am sending data to EM358\n");
printf("Write Bytes: %d \n and Write data: %s \n",write(fd,snd_buff,strlen(snd_buff)+1),snd_buff);
printf("Hi I am reading data from EM358***************\n");
printf("Read Bytes: %d \n Read data: %s \n", read(fd,rcv_buff,sizeof(rcv_buff)),rcv_buff);
sleep(2);
return 0;
Thank you
