I already read that article so many times but, it doesn’t work.
I connected Colibri iMX6 to my PC with RS232 and I can see boot log from the terminal software.
I turned on the board and hit the [space]key.
I tried excute “recovery -windows.bat” but, result was “no matching USB device found”.
- 1. Open a terminal on your host computer (115200 baud, 8 data bits, no parity, one stop, no hardware/software flow control).
- 2. Power cycle the board and immediately press [space] on the terminal
- 3. you should see a menu, in this case type 'X' to enter the bootloader console, then on the Eboot command line:
bootfrom usb
reboot
If a boot delay interval set to 0 it may be hard to get to menu on step 2. SO you should repeat step 2 until you get to boot menu.
It really seems that your Host computer is not enumerating the USB device.
Which Windows version are you using?
The device should appear under “Human Interface Device”. In properties, Details then “Bus reported device description” it should appear as “SE Blank RIGEL” (see also ).
There will be no need to install a driver. Windows can handle the device just fine. It should just appear. If it does not, the module is not in recovery mode or there is some connectivity issue.
Replace USB cables, and please make 100% sure to follow the documented steps, make sure to not use X30 while using X29 and remove any SD card.
