is it possible to change the duration of time that the splash screen is displayed ? i have tried to use the display on delay but that seems to be the amount of time the display is on before the splash screen comes on. ss.dispondelay: 100 (Display On Delay (ms))*
my end goal is to have the splash screen displayed until my application loads, is this possible?
Dear @deirich
The dispondelay does only affect the power sequencing of the DISP_ON signal, before the splash screen is shown.
The splash screen then is displayed until the display driver sees the first graphical operation.
Possibly the Windows Explorer (“Desktop”) gets visible before your application? You can disable the Explorer to avoid that. If you need it later, simply run explorer.exe.
Make sure your application does not output anything (even not automatically in the startup code) before you want the splash screen to disappear.
