I modified the Toradex SPI demo application today to test the SPI1 and SPI2 interface. I saw the SPI Clock signal for SPI1 on pin 88 of the colibri SOM, and observed the clock for SPI2 on pin 140 - I expected to see the SPI clock on pin 153 (see code below). Am I missing a step for configuring the clock pin? I am using the Toradex CE Library v2.1.
int WINAPI WinMain(HINSTANCE instance, HINSTANCE prevInstance, LPWSTR cmdLine, int cmdShow)
DWORD loopCount = 0;
DWORD clockSet = 0;
DWORD dataCount = 0;
DWORD spiData[20] = {1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20}; // Transmit buffer
DWORD rxBuffer[20] = {0}; ///< Receive buffer
HANDLE hSPI;
HANDLE hSPI2;
BOOL fSuccess = TRUE;
tVersion ver;
UNREFERENCED_PARAMETER(instance);
UNREFERENCED_PARAMETER(prevInstance);
UNREFERENCED_PARAMETER(cmdLine);
UNREFERENCED_PARAMETER(cmdShow);
Imx6Spi_GetVersion(&ver);
wprintf(L"Demo Application for the SPI Library V%d.%d.%d\r\n", ver.Major, ver.Minor, ver.Build);
hSPI = Imx6Spi_Init(L"SPI1");
hSPI2 = Imx6Spi_Init(L"SPI2");
if (hSPI == NULL)
wprintf(L"Error initializing the SPI Library\r\n");
fSuccess = FALSE;
else
// Set mode and baud rate
fSuccess = Imx6Spi_SetConfigInt(hSPI, L"SpiMode", 3, StoreVolatile);
fSuccess = Imx6Spi_SetConfigInt(hSPI, L"BitRateHz", 10*1000, StoreVolatile);
fSuccess = Imx6Spi_SetConfigInt(hSPI2, L"SpiMode", 3, StoreVolatile);
fSuccess = Imx6Spi_SetConfigInt(hSPI2, L"BitRateHz", 10 * 1000, StoreVolatile);
fSuccess = Imx6Spi_SetConfigInt(hSPI2, L"ioCLK", IOCOLIBRIPIN(153), StoreVolatile);
if (!Imx6Spi_Open(hSPI2))
wprintf(L"Failed to open SPI2\r\n");
fSuccess = FALSE;
if (!Imx6Spi_Open(hSPI))
wprintf(L"Failed to open SPI\r\n");
fSuccess = FALSE;
else
// If multiple chip selects are used, the following lines of code are required to ensure
// that all chip selects are properly configured (inac79tive) before the first use.
// The location of chip select pins for a particular SoM can be looked up in the .chm documentation file
// shipped with this library package.
fSuccess = Imx6Spi_SetConfigInt(hSPI, L"ioCS", IOCOLIBRIPIN(86), StoreVolatile); // Standard CS pin on Colibri
fSuccess = Imx6Spi_SetConfigInt(hSPI, L"ioCS", IOCOLIBRIPIN(97), StoreVolatile); // 2nd Chip select, on Vybrid
// write & read using 2 chip selects
for (loopCount = 0; loopCount < 10; loopCount++)
fSuccess = Imx6Spi_SetConfigInt(hSPI2, L"ioCS", IOCOLIBRIPIN(184), StoreVolatile);
dataCount = Imx6Spi_ReadWrite(hSPI, rxBuffer, spiData, 20);
dataCount = Imx6Spi_ReadWrite(hSPI2, rxBuffer, spiData, 20);
ASSERTMSG(L"Unexpected amount of received data\r\n" , (dataCount == 20));
// 2nd CS. Availability depends on the actual SoM used.
fSuccess = Imx6Spi_SetConfigInt(hSPI, L"ioCS", IOCOLIBRIPIN(79), StoreVolatile);
// print transmitted vs. received data
wprintf(L"Transmitted data : ");
for (loopCount = 0; loopCount < dataCount; loopCount++)
wprintf(L"%02x ", spiData[loopCount]);
wprintf(L"\r\nReceived data : ");
wprintf(L"%02x ", rxBuffer[loopCount]);
fSuccess = Imx6Spi_Close(hSPI);
fSuccess = Imx6Spi_Close(hSPI2);
fSuccess = Imx6Spi_Deinit(hSPI);
fSuccess = Imx6Spi_Deinit(hSPI2);
wprintf(L"\r\n\r\nPress ENTER to exit.");
getchar();
return fSuccess;
