I have added it to my local.conf as: IMAGE_INSTALL_append = " qtbase qtbase-plugins qtquickcontrols qtquickcontrols2 qtmultimedia cinematicexperience liberation-fonts".
I then clean my build: bitbake -c clean angstrom-lxde-image. Then bitbake -k angstrom-lxde-image.
I see the following errors:
ERROR: Task (/home/lynetta/projects/imx7D/oe_core/linuxImageV2.8/build/../layers/meta-toradex-demos/recipes-images/images/angstrom-lxde-image.bb:do_image_wic) failed with exit code '1'
ERROR: angstrom-lxde-image-2.8b1-r0 do_image_teziimg: imx7d-colibri-eval-v3.dtb does not exist.
ERROR: angstrom-lxde-image-2.8b1-r0 do_image_teziimg: Function failed: do_image_teziimg (log file is located at /home/lynetta/projects/imx7D/oe_core/linuxImageV2.8/build/tmp-glibc/work/colibri_imx7-angstrom-linux-gnueabi/angstrom-lxde-image/2.8b1-r0/temp/log.do_image_teziimg.17143)
ERROR: Logfile of failure stored in: /home/lynetta/projects/imx7D/oe_core/linuxImageV2.8/build/tmp-glibc/work/colibri_imx7-angstrom-linux-gnueabi/angstrom-lxde-image/2.8b1-r0/temp/log.do_image_teziimg.17143
ERROR: Task (/home/lynetta/projects/imx7D/oe_core/linuxImageV2.8/build/../layers/meta-toradex-demos/recipes-images/images/angstrom-lxde-image.bb:do_image_teziimg) failed with exit code '1'
NOTE: Tasks Summary: Attempted 7228 tasks of which 7190 didn't need to be rerun and 3 failed.
hi
can you send the log files “/home/lynetta/projects/imx7D/oe_core/linuxImageV2.8/build/tmp-glibc/work/colibri_imx7-angstrom-linux-gnueabi/angstrom-lxde-image/2.8b1-r0/temp/log.do_image***” which are in the file you attached before.
The attempt to clean virtual/bootloader and then run bitbake did not work.
I then attempted to clean angstrom-lxde-image, virtual/kernel, and virtual/bootloader and modified my local.conf to remove both qtquickcontrols and qtquickcontrols2 from my IMAGE_INSTALL_append. I ran that and still got errors.
Here is the console log: link text
