P.S. Are you sure that you successfully built an image with qtbase-fonts in IMAGE_INSTALL?
No this was a copy error from me. Sorry for that.
Thank you for your answer. I have now created a reproducible log for you.
My local.conf is:
WARN_QA_remove = "host-user-contaminated"
# meta-freescale otherwise defaults to wayland
DISTRO_FEATURES_remove = "x11 wayland"
IMAGE_INSTALL_remove = "eglinfo-x11"
ACCEPT_FSL_EULA = "1"
# This file is your local configuration file and is where all local user settings
# are placed. The comments in this file give some guide to the options a new user
# to the system might want to change but pretty much any configuration option can
# be set in this file. More adventurous users can look at local.conf.extended
# which contains other examples of configuration which can be placed in this file
# but new users likely won't need any of them initially.
# Lines starting with the '#' character are commented out and in some cases the
# default values are provided as comments to show people example syntax. Enabling
# the option is a question of removing the # character and making any change to the
# variable as required.
# Parallelism Options
# These two options control how much parallelism BitBake should use. The first
# option determines how many tasks bitbake should run in parallel:
#BB_NUMBER_THREADS ?= "4"
# Default to setting automatically based on cpu count
BB_NUMBER_THREADS ?= "${@oe.utils.cpu_count()}"
# The second option controls how many processes make should run in parallel when
# running compile tasks:
#PARALLEL_MAKE ?= "-j 4"
PARALLEL_MAKE ?= "-j ${@oe.utils.cpu_count()}"
# For a quad-core machine, BB_NUMBER_THREADS = "4", PARALLEL_MAKE = "-j 4" would
# be appropriate for example.
# Machine Selection
# You need to select a specific machine to target the build with. These are the
# machines which for the Toradex Colibri and Apalis computer on module families
MACHINE = "apalis-imx6"
#MACHINE ?= "apalis-t30"
#MACHINE ?= "apalis-tk1"
#MACHINE ?= "apalis-tk1-mainline"
#MACHINE ?= "colibri-imx6"
#MACHINE ?= "colibri-imx7"
#MACHINE ?= "colibri-t20"
#MACHINE ?= "colibri-t30"
#MACHINE ?= "colibri-vf"
# There are also a selection of emulated machines available which can boot and run
# in the QEMU emulator:
#MACHINE ?= "qemuarm"
#MACHINE ?= "qemumips"
#MACHINE ?= "qemuppc"
#MACHINE ?= "qemux86"
#MACHINE ?= "qemux86-64"
# Where to place downloads
# During a first build the system will download many different source code tarballs
# from various upstream projects. This can take a while, particularly if your network
# connection is slow. These are all stored in DL_DIR. When wiping and rebuilding you
# can preserve this directory to speed up this part of subsequent builds. This directory
# is safe to share between multiple builds on the same machine too.
# The default is a downloads directory under TOPDIR which is the build directory.
DL_DIR ?= "${TOPDIR}/downloads"
# Where to place shared-state files
# BitBake has the capability to accelerate builds based on previously built output.
# This is done using "shared state" files which can be thought of as cache objects
# and this option determines where those files are placed.
# You can wipe out TMPDIR leaving this directory intact and the build would regenerate
# from these files if no changes were made to the configuration. If changes were made
# to the configuration, only shared state files where the state was still valid would
# be used (done using checksums).
# The default is a sstate-cache directory under TOPDIR.
#SSTATE_DIR ?= "${TOPDIR}/sstate-cache"
# Where to place the build output
# This option specifies where the bulk of the building work should be done and
# where BitBake should place its temporary files and output. Keep in mind that
# this includes the extraction and compilation of many applications and the toolchain
# which can use Gigabytes of hard disk space.
# The default is a tmp directory under TOPDIR.
#TMPDIR = "${TOPDIR}/tmp"
# Where to place images and sw packages
# This places the build output in parallel to build and layers thus
# if you have several build directories you need to adjust deploy
# to something unique, e.g. "${TOPDIR}/../deploy_fb" "${TOPDIR}/../deploy_x11"
DEPLOY_DIR = "${TOPDIR}/../deploy"
# Package Management configuration
# This variable lists which packaging formats to enable. Multiple package backends
# can be enabled at once and the first item listed in the variable will be used
# to generate the root filesystems.
# Options are:
# - 'package_deb' for debian style deb files
# - 'package_ipk' for ipk files are used by opkg (a debian style embedded package manager)
# - 'package_rpm' for rpm style packages
# E.g.: PACKAGE_CLASSES ?= "package_rpm package_deb package_ipk"
# We default to ipk:
PACKAGE_CLASSES ?= "package_ipk"
# SDK/ADT target architecture
# This variable specifies the architecture to build SDK/ADT items for and means
# you can build the SDK packages for architectures other than the machine you are
# running the build on (i.e. building i686 packages on an x86_64 host).
# Supported values are i686 and x86_64
#SDKMACHINE ?= "i686"
# Extra image configuration defaults
# The EXTRA_IMAGE_FEATURES variable allows extra packages to be added to the generated
# images. Some of these options are added to certain image types automatically. The
# variable can contain the following options:
# "dbg-pkgs" - add -dbg packages for all installed packages
# (adds symbol information for debugging/profiling)
# "dev-pkgs" - add -dev packages for all installed packages
# (useful if you want to develop against libs in the image)
# "ptest-pkgs" - add -ptest packages for all ptest-enabled packages
# (useful if you want to run the package test suites)
# "tools-sdk" - add development tools (gcc, make, pkgconfig etc.)
# "tools-debug" - add debugging tools (gdb, strace)
# "eclipse-debug" - add Eclipse remote debugging support
# "tools-profile" - add profiling tools (oprofile, exmap, lttng, valgrind)
# "tools-testapps" - add useful testing tools (ts_print, aplay, arecord etc.)
# "debug-tweaks" - make an image suitable for development
# e.g. ssh root access has a blank password
# There are other application targets that can be used here too, see
# meta/classes/image.bbclass and meta/classes/core-image.bbclass for more details.
# We default to enabling the debugging tweaks.
# package-management deploys the package meta data of deployed packeges
EXTRA_IMAGE_FEATURES = "debug-tweaks package-management"
# Additional image features
# The following is a list of additional classes to use when building images which
# enable extra features. Some available options which can be included in this variable
# are:
# - 'buildstats' collect build statistics
# - 'image-mklibs' to reduce shared library files size for an image
# - 'image-prelink' in order to prelink the filesystem image
# - 'image-swab' to perform host system intrusion detection
# NOTE: if listing mklibs & prelink both, then make sure mklibs is before prelink
# NOTE: mklibs also needs to be explicitly enabled for a given image, see local.conf.extended
USER_CLASSES ?= "buildstats image-mklibs image-prelink"
# Runtime testing of images
# The build system can test booting virtual machine images under qemu (an emulator)
# after any root filesystems are created and run tests against those images. To
# enable this uncomment this line. See classes/testimage(-auto).bbclass for
# further details.
#TEST_IMAGE = "1"
# Interactive shell configuration
# Under certain circumstances the system may need input from you and to do this it
# can launch an interactive shell. It needs to do this since the build is
# multithreaded and needs to be able to handle the case where more than one parallel
# process may require the user's attention. The default is iterate over the available
# terminal types to find one that works.
# Examples of the occasions this may happen are when resolving patches which cannot
# be applied, to use the devshell or the kernel menuconfig
# Supported values are auto, gnome, xfce, rxvt, screen, konsole (KDE 3.x only), none
# Note: currently, Konsole support only works for KDE 3.x due to the way
# newer Konsole versions behave
#OE_TERMINAL = "auto"
# By default disable interactive patch resolution (tasks will just fail instead):
PATCHRESOLVE = "noop"
# Disk Space Monitoring during the build
# Monitor the disk space during the build. If there is less that 1GB of space or less
# than 100K inodes in any key build location (TMPDIR, DL_DIR, SSTATE_DIR), gracefully
# shutdown the build. If there is less that 100MB or 1K inodes, perform a hard abort
# of the build. The reason for this is that running completely out of space can corrupt
# files and damages the build in ways which may not be easily recoverable.
BB_DISKMON_DIRS = "\
STOPTASKS,${TMPDIR},1G,100K \
STOPTASKS,${DL_DIR},1G,100K \
STOPTASKS,${SSTATE_DIR},1G,100K \
ABORT,${TMPDIR},100M,1K \
ABORT,${DL_DIR},100M,1K \
ABORT,${SSTATE_DIR},100M,1K"
# Shared-state files from other locations
# As mentioned above, shared state files are prebuilt cache data objects which can
# used to accelerate build time. This variable can be used to configure the system
# to search other mirror locations for these objects before it builds the data itself.
# This can be a filesystem directory, or a remote url such as http or ftp. These
# would contain the sstate-cache results from previous builds (possibly from other
# machines). This variable works like fetcher MIRRORS/PREMIRRORS and points to the
# cache locations to check for the shared objects.
# NOTE: if the mirror uses the same structure as SSTATE_DIR, you need to add PATH
# at the end as shown in the examples below. This will be substituted with the
# correct path within the directory structure.
#SSTATE_MIRRORS ?= "\
#file://.* http://someserver.tld/share/sstate/PATH;downloadfilename=PATH \n \
#file://.* file:///some/local/dir/sstate/PATH"
# Qemu configuration
# By default qemu will build with a builtin VNC server where graphical output can be
# seen. The two lines below enable the SDL backend too. This assumes there is a
# libsdl library available on your build system.
PACKAGECONFIG_pn-qemu-native = "sdl"
ASSUME_PROVIDED += "libsdl-native"
# CONF_VERSION is increased each time build/conf/ changes incompatibly and is used to
# track the version of this file when it was generated. This can safely be ignored if
# this doesn't mean anything to you.
CONF_VERSION = "1"
# Delete the the source/object/binary files once a package is built to preserve disk space
INHERIT += "rm_work"
# Add Toradex source mirror
INHERIT += "toradex-mirrors"
# Use this distro (filename from meta-angstrom/conf/distro/xx.conf)
DISTRO = "angstrom"
# What image type(s) are to be built?
IMAGE_FSTYPES += "tar.bz2"
# Don't generate the mirror tarball for SCM repos, the snapshot is enough
# BB_GENERATE_MIRROR_TARBALLS = "0"
PREFERRED_PROVIDER_psplash-support = "psplash-angstrom"
IMAGE_INSTALL_append = " qtbase qtbase-plugins cinematicexperience liberation-fonts"
PACKAGECONFIG_FONTS_append_pn-qtbase = " fontconfig"
# This file does not need to exist, if it does it can be used to influence machine specific
# configurations without copying the machine file.
include conf/machine/include/${MACHINE}.inc
My is bblayers.conf:
# LAYER_CONF_VERSION is increased each time build/conf/bblayers.conf
# changes incompatibly
LCONF_VERSION = "7"
BBPATH = "${TOPDIR}"
BBFILES ?= ""
BBLAYERS ?= " \
${TOPDIR}/../layers/meta-angstrom \
${TOPDIR}/../layers/meta-toradex-nxp \
${TOPDIR}/../layers/meta-freescale \
${TOPDIR}/../layers/meta-freescale-3rdparty \
${TOPDIR}/../layers/meta-toradex-tegra \
${TOPDIR}/../layers/meta-jetson-tk1 \
${TOPDIR}/../layers/meta-toradex-bsp-common \
${TOPDIR}/../layers/meta-snappy \
${TOPDIR}/../layers/meta-openembedded/meta-oe \
${TOPDIR}/../layers/meta-openembedded/meta-filesystems \
${TOPDIR}/../layers/meta-openembedded/meta-gnome \
${TOPDIR}/../layers/meta-openembedded/meta-xfce \
${TOPDIR}/../layers/meta-openembedded/meta-initramfs \
${TOPDIR}/../layers/meta-openembedded/meta-networking \
${TOPDIR}/../layers/meta-openembedded/meta-multimedia \
${TOPDIR}/../layers/meta-openembedded/meta-python \
${TOPDIR}/../layers/meta-lxde \
${TOPDIR}/../layers/meta-browser \
${TOPDIR}/../layers/meta-qt4 \
${TOPDIR}/../layers/meta-qt5 \
${TOPDIR}/../layers/meta-freescale-distro \
${TOPDIR}/../layers/meta-toradex-demos \
${TOPDIR}/../layers/meta-imx6-sens \
${TOPDIR}/../layers/openembedded-core/meta \
The meta-imx6-sens looks like :
layers/meta-imx6-sens/
conf
layer.conf
recipes-kernel
linux
linux-toradex_4.9-1.0.x.bbappend
linux-toradex-4.9-1.0.x
Add_lvds_support.patch
The complete Build and create log is:
x@ubuntudragon:~$ sudo rm -fr oe-core/
[sudo] Passwort für x:
x@ubuntudragon:~$ mkdir oe-core
x@ubuntudragon:~$
x@ubuntudragon:~$
x@ubuntudragon:~$ cd oe-core/
x@ubuntudragon:~/oe-core$
x@ubuntudragon:~/oe-core$ repo init -u http://git.toradex.com/toradex-bsp-platform.git -b LinuxImageV2.8
Get https://gerrit.googlesource.com/git-repo/clone.bundle
... A new repo command ( 1.23) is available.
... You should upgrade soon:
cp /home/x/oe-core/.repo/repo/repo /usr/bin/repo
Get http://git.toradex.com/toradex-bsp-platform.git
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
curl: (22) The requested URL returned error: 404 Not Found
Server does not provide clone.bundle; ignoring.
Von http://git.toradex.com/toradex-bsp-platform
* [neuer Branch] LinuxImageV2.1 -> origin/LinuxImageV2.1
* [neuer Branch] LinuxImageV2.2 -> origin/LinuxImageV2.2
* [neuer Branch] LinuxImageV2.3 -> origin/LinuxImageV2.3
* [neuer Branch] LinuxImageV2.4 -> origin/LinuxImageV2.4
* [neuer Branch] LinuxImageV2.5 -> origin/LinuxImageV2.5
* [neuer Branch] LinuxImageV2.6 -> origin/LinuxImageV2.6
* [neuer Branch] LinuxImageV2.6-next -> origin/LinuxImageV2.6-next
* [neuer Branch] LinuxImageV2.6.1 -> origin/LinuxImageV2.6.1
* [neuer Branch] LinuxImageV2.7 -> origin/LinuxImageV2.7
* [neuer Branch] LinuxImageV2.7-integration -> origin/LinuxImageV2.7-integration
* [neuer Branch] LinuxImageV2.7-next -> origin/LinuxImageV2.7-next
* [neuer Branch] LinuxImageV2.8 -> origin/LinuxImageV2.8
* [neuer Branch] LinuxImageV2.8-integration -> origin/LinuxImageV2.8-integration
* [neuer Branch] LinuxImageV2.8-next -> origin/LinuxImageV2.8-next
* [neues Tag] Apalis-T30_LXDE-Image_2.7b2-20170410 -> Apalis-T30_LXDE-Image_2.7b2-20170410
* [neues Tag] Apalis-T30_LXDE-Image_2.7b3-20170630 -> Apalis-T30_LXDE-Image_2.7b3-20170630
* [neues Tag] Apalis-T30_LXDE-Image_2.7b4-20171005 -> Apalis-T30_LXDE-Image_2.7b4-20171005
* [neues Tag] Apalis-T30_LXDE-Image_2.8b1.64-20171229 -> Apalis-T30_LXDE-Image_2.8b1.64-20171229
* [neues Tag] Apalis-TK1-Mainline_LXDE-Image_2.7b4-20171005 -> Apalis-TK1-Mainline_LXDE-Image_2.7b4-20171005
* [neues Tag] Apalis-TK1-Mainline_LXDE-Image_2.8b1.64-20171229 -> Apalis-TK1-Mainline_LXDE-Image_2.8b1.64-20171229
* [neues Tag] Apalis-TK1_LXDE-Image_2.7b2-20170410 -> Apalis-TK1_LXDE-Image_2.7b2-20170410
* [neues Tag] Apalis-TK1_LXDE-Image_2.7b3-20170630 -> Apalis-TK1_LXDE-Image_2.7b3-20170630
* [neues Tag] Apalis-TK1_LXDE-Image_2.7b4-20171007 -> Apalis-TK1_LXDE-Image_2.7b4-20171007
* [neues Tag] Apalis-TK1_LXDE-Image_2.7b5-20171201 -> Apalis-TK1_LXDE-Image_2.7b5-20171201
* [neues Tag] Apalis-TK1_LXDE-Image_2.8b1.64-20171229 -> Apalis-TK1_LXDE-Image_2.8b1.64-20171229
* [neues Tag] Apalis-iMX6_LXDE-Image_2.7b2-20170410 -> Apalis-iMX6_LXDE-Image_2.7b2-20170410
* [neues Tag] Apalis-iMX6_LXDE-Image_2.7b3-20170630 -> Apalis-iMX6_LXDE-Image_2.7b3-20170630
* [neues Tag] Apalis-iMX6_LXDE-Image_2.7b4-20171005 -> Apalis-iMX6_LXDE-Image_2.7b4-20171005
* [neues Tag] Apalis-iMX6_LXDE-Image_2.8b1.64-20171229 -> Apalis-iMX6_LXDE-Image_2.8b1.64-20171229
* [neues Tag] Apalis_T30_LinuxImageV2.1Beta1_20131022 -> Apalis_T30_LinuxImageV2.1Beta1_20131022
* [neues Tag] Apalis_T30_LinuxImageV2.1Beta2_20140206 -> Apalis_T30_LinuxImageV2.1Beta2_20140206
* [neues Tag] Apalis_T30_LinuxImageV2.1Beta3_20140318 -> Apalis_T30_LinuxImageV2.1Beta3_20140318
* [neues Tag] Apalis_T30_LinuxImageV2.3Beta1_20140804 -> Apalis_T30_LinuxImageV2.3Beta1_20140804
* [neues Tag] Apalis_T30_LinuxImageV2.3Beta2_20140903 -> Apalis_T30_LinuxImageV2.3Beta2_20140903
* [neues Tag] Apalis_T30_LinuxImageV2.3Beta3_20141031 -> Apalis_T30_LinuxImageV2.3Beta3_20141031
* [neues Tag] Apalis_T30_LinuxImageV2.3Beta5_20141219 -> Apalis_T30_LinuxImageV2.3Beta5_20141219
* [neues Tag] Apalis_T30_LinuxImageV2.4Beta1_20150518 -> Apalis_T30_LinuxImageV2.4Beta1_20150518
* [neues Tag] Apalis_T30_LinuxImageV2.5Beta2_20151106 -> Apalis_T30_LinuxImageV2.5Beta2_20151106
* [neues Tag] Apalis_T30_LinuxImageV2.5Beta3_20151215 -> Apalis_T30_LinuxImageV2.5Beta3_20151215
* [neues Tag] Apalis_T30_LinuxImageV2.6.1Beta1_20160929 -> Apalis_T30_LinuxImageV2.6.1Beta1_20160929
* [neues Tag] Apalis_T30_LinuxImageV2.6Beta1_20160331 -> Apalis_T30_LinuxImageV2.6Beta1_20160331
* [neues Tag] Apalis_T30_LinuxImageV2.6Beta2_20160701 -> Apalis_T30_LinuxImageV2.6Beta2_20160701
* [neues Tag] Apalis_T30_LinuxImageV2.7Beta1_20170112 -> Apalis_T30_LinuxImageV2.7Beta1_20170112
* [neues Tag] Apalis_TK1_LinuxImageV2.6.1Beta1_20160929 -> Apalis_TK1_LinuxImageV2.6.1Beta1_20160929
* [neues Tag] Apalis_TK1_LinuxImageV2.6.1Beta2_20161122 -> Apalis_TK1_LinuxImageV2.6.1Beta2_20161122
* [neues Tag] Apalis_TK1_LinuxImageV2.6Beta2_20160701 -> Apalis_TK1_LinuxImageV2.6Beta2_20160701
* [neues Tag] Apalis_TK1_LinuxImageV2.7Beta1_20170112 -> Apalis_TK1_LinuxImageV2.7Beta1_20170112
* [neues Tag] Apalis_iMX6_LinuxImageV2.2Beta1_20140404 -> Apalis_iMX6_LinuxImageV2.2Beta1_20140404
* [neues Tag] Apalis_iMX6_LinuxImageV2.3Beta1_20140804 -> Apalis_iMX6_LinuxImageV2.3Beta1_20140804
* [neues Tag] Apalis_iMX6_LinuxImageV2.3Beta3_20141031 -> Apalis_iMX6_LinuxImageV2.3Beta3_20141031
* [neues Tag] Apalis_iMX6_LinuxImageV2.3Beta5_20141219 -> Apalis_iMX6_LinuxImageV2.3Beta5_20141219
* [neues Tag] Apalis_iMX6_LinuxImageV2.3Beta6_20150112 -> Apalis_iMX6_LinuxImageV2.3Beta6_20150112
* [neues Tag] Apalis_iMX6_LinuxImageV2.4Beta1_20150518 -> Apalis_iMX6_LinuxImageV2.4Beta1_20150518
* [neues Tag] Apalis_iMX6_LinuxImageV2.5Beta2_20151106 -> Apalis_iMX6_LinuxImageV2.5Beta2_20151106
* [neues Tag] Apalis_iMX6_LinuxImageV2.5Beta3_20151215 -> Apalis_iMX6_LinuxImageV2.5Beta3_20151215
* [neues Tag] Apalis_iMX6_LinuxImageV2.6.1Beta1_20160929 -> Apalis_iMX6_LinuxImageV2.6.1Beta1_20160929
* [neues Tag] Apalis_iMX6_LinuxImageV2.6Beta1_20160331 -> Apalis_iMX6_LinuxImageV2.6Beta1_20160331
* [neues Tag] Apalis_iMX6_LinuxImageV2.6Beta2_20160701 -> Apalis_iMX6_LinuxImageV2.6Beta2_20160701
* [neues Tag] Apalis_iMX6_LinuxImageV2.7Beta1_20170112 -> Apalis_iMX6_LinuxImageV2.7Beta1_20170112
* [neues Tag] Colibri-T20_LXDE-Image_2.7b2-20170410 -> Colibri-T20_LXDE-Image_2.7b2-20170410
* [neues Tag] Colibri-T20_LXDE-Image_2.7b3-20170630 -> Colibri-T20_LXDE-Image_2.7b3-20170630
* [neues Tag] Colibri-T20_LXDE-Image_2.7b4-20171005 -> Colibri-T20_LXDE-Image_2.7b4-20171005
* [neues Tag] Colibri-T20_LXDE-Image_2.8b1.64-20171229 -> Colibri-T20_LXDE-Image_2.8b1.64-20171229
* [neues Tag] Colibri-T30_LXDE-Image_2.7b2-20170410 -> Colibri-T30_LXDE-Image_2.7b2-20170410
* [neues Tag] Colibri-T30_LXDE-Image_2.7b3-20170630 -> Colibri-T30_LXDE-Image_2.7b3-20170630
* [neues Tag] Colibri-T30_LXDE-Image_2.7b4-20171005 -> Colibri-T30_LXDE-Image_2.7b4-20171005
* [neues Tag] Colibri-T30_LXDE-Image_2.8b1.64-20171229 -> Colibri-T30_LXDE-Image_2.8b1.64-20171229
* [neues Tag] Colibri-VF_LXDE-Image_2.7b2-20170410 -> Colibri-VF_LXDE-Image_2.7b2-20170410
* [neues Tag] Colibri-VF_LXDE-Image_2.7b3-20170630 -> Colibri-VF_LXDE-Image_2.7b3-20170630
* [neues Tag] Colibri-VF_LXDE-Image_2.7b4-20171005 -> Colibri-VF_LXDE-Image_2.7b4-20171005
* [neues Tag] Colibri-VF_LXDE-Image_2.8b1.64-20171229 -> Colibri-VF_LXDE-Image_2.8b1.64-20171229
* [neues Tag] Colibri-iMX6ULL_LXDE-Image_2.7b5-20171201 -> Colibri-iMX6ULL_LXDE-Image_2.7b5-20171201
* [neues Tag] Colibri-iMX6ULL_LXDE-Image_2.8b1.64-20171229 -> Colibri-iMX6ULL_LXDE-Image_2.8b1.64-20171229
* [neues Tag] Colibri-iMX6_LXDE-Image_2.7b2-20170410 -> Colibri-iMX6_LXDE-Image_2.7b2-20170410
* [neues Tag] Colibri-iMX6_LXDE-Image_2.7b3-20170630 -> Colibri-iMX6_LXDE-Image_2.7b3-20170630
* [neues Tag] Colibri-iMX6_LXDE-Image_2.7b4-20171005 -> Colibri-iMX6_LXDE-Image_2.7b4-20171005
* [neues Tag] Colibri-iMX6_LXDE-Image_2.8b1.64-20171229 -> Colibri-iMX6_LXDE-Image_2.8b1.64-20171229
* [neues Tag] Colibri-iMX7_LXDE-Image_2.7b2-20170410 -> Colibri-iMX7_LXDE-Image_2.7b2-20170410
* [neues Tag] Colibri-iMX7_LXDE-Image_2.7b3-20170630 -> Colibri-iMX7_LXDE-Image_2.7b3-20170630
* [neues Tag] Colibri-iMX7_LXDE-Image_2.7b4-20171005 -> Colibri-iMX7_LXDE-Image_2.7b4-20171005
* [neues Tag] Colibri-iMX7_LXDE-Image_2.8b1.64-20171229 -> Colibri-iMX7_LXDE-Image_2.8b1.64-20171229
* [neues Tag] Colibri_T20_LinuxImageV2.1Beta1_20131022 -> Colibri_T20_LinuxImageV2.1Beta1_20131022
* [neues Tag] Colibri_T20_LinuxImageV2.1Beta2_20140207 -> Colibri_T20_LinuxImageV2.1Beta2_20140207
* [neues Tag] Colibri_T20_LinuxImageV2.1Beta3_20140318 -> Colibri_T20_LinuxImageV2.1Beta3_20140318
* [neues Tag] Colibri_T20_LinuxImageV2.3Beta1_20140804 -> Colibri_T20_LinuxImageV2.3Beta1_20140804
* [neues Tag] Colibri_T20_LinuxImageV2.3Beta3_20141031 -> Colibri_T20_LinuxImageV2.3Beta3_20141031
* [neues Tag] Colibri_T20_LinuxImageV2.3Beta5_20141219 -> Colibri_T20_LinuxImageV2.3Beta5_20141219
* [neues Tag] Colibri_T20_LinuxImageV2.3Beta7_20150203 -> Colibri_T20_LinuxImageV2.3Beta7_20150203
* [neues Tag] Colibri_T20_LinuxImageV2.3_20150320 -> Colibri_T20_LinuxImageV2.3_20150320
* [neues Tag] Colibri_T20_LinuxImageV2.4Beta1_20150518 -> Colibri_T20_LinuxImageV2.4Beta1_20150518
* [neues Tag] Colibri_T20_LinuxImageV2.5Beta2_20151106 -> Colibri_T20_LinuxImageV2.5Beta2_20151106
* [neues Tag] Colibri_T20_LinuxImageV2.5Beta3_20151215 -> Colibri_T20_LinuxImageV2.5Beta3_20151215
* [neues Tag] Colibri_T20_LinuxImageV2.6.1Beta1_20160929 -> Colibri_T20_LinuxImageV2.6.1Beta1_20160929
* [neues Tag] Colibri_T20_LinuxImageV2.6Beta1_20160331 -> Colibri_T20_LinuxImageV2.6Beta1_20160331
* [neues Tag] Colibri_T20_LinuxImageV2.6Beta2_20160701 -> Colibri_T20_LinuxImageV2.6Beta2_20160701
* [neues Tag] Colibri_T20_LinuxImageV2.7Beta1_20170112 -> Colibri_T20_LinuxImageV2.7Beta1_20170112
* [neues Tag] Colibri_T30_LinuxImageV2.1Beta1_20131022 -> Colibri_T30_LinuxImageV2.1Beta1_20131022
* [neues Tag] Colibri_T30_LinuxImageV2.1Beta2_20140206 -> Colibri_T30_LinuxImageV2.1Beta2_20140206
* [neues Tag] Colibri_T30_LinuxImageV2.1Beta3_20140318 -> Colibri_T30_LinuxImageV2.1Beta3_20140318
* [neues Tag] Colibri_T30_LinuxImageV2.3Beta1_20140804 -> Colibri_T30_LinuxImageV2.3Beta1_20140804
* [neues Tag] Colibri_T30_LinuxImageV2.3Beta3_20141031 -> Colibri_T30_LinuxImageV2.3Beta3_20141031
* [neues Tag] Colibri_T30_LinuxImageV2.3Beta5_20141219 -> Colibri_T30_LinuxImageV2.3Beta5_20141219
* [neues Tag] Colibri_T30_LinuxImageV2.4Beta1_20150518 -> Colibri_T30_LinuxImageV2.4Beta1_20150518
* [neues Tag] Colibri_T30_LinuxImageV2.5Beta2_20151106 -> Colibri_T30_LinuxImageV2.5Beta2_20151106
* [neues Tag] Colibri_T30_LinuxImageV2.5Beta3_20151215 -> Colibri_T30_LinuxImageV2.5Beta3_20151215
* [neues Tag] Colibri_T30_LinuxImageV2.6.1Beta1_20160929 -> Colibri_T30_LinuxImageV2.6.1Beta1_20160929
* [neues Tag] Colibri_T30_LinuxImageV2.6Beta1_20160331 -> Colibri_T30_LinuxImageV2.6Beta1_20160331
* [neues Tag] Colibri_T30_LinuxImageV2.6Beta2_20160701 -> Colibri_T30_LinuxImageV2.6Beta2_20160701
* [neues Tag] Colibri_T30_LinuxImageV2.7Beta1_20170112 -> Colibri_T30_LinuxImageV2.7Beta1_20170112
* [neues Tag] Colibri_VF50_LinuxImageV2.1Beta1_20131022 -> Colibri_VF50_LinuxImageV2.1Beta1_20131022
* [neues Tag] Colibri_VF_LinuxImageV2.1Beta2_20131129 -> Colibri_VF_LinuxImageV2.1Beta2_20131129
* [neues Tag] Colibri_VF_LinuxImageV2.1Beta3_20140318 -> Colibri_VF_LinuxImageV2.1Beta3_20140318
* [neues Tag] Colibri_VF_LinuxImageV2.2Beta1_20140603 -> Colibri_VF_LinuxImageV2.2Beta1_20140603
* [neues Tag] Colibri_VF_LinuxImageV2.3Beta1_20140804 -> Colibri_VF_LinuxImageV2.3Beta1_20140804
* [neues Tag] Colibri_VF_LinuxImageV2.3Beta3_20141031 -> Colibri_VF_LinuxImageV2.3Beta3_20141031
* [neues Tag] Colibri_VF_LinuxImageV2.3Beta5_20141219 -> Colibri_VF_LinuxImageV2.3Beta5_20141219
* [neues Tag] Colibri_VF_LinuxImageV2.3Beta7_20150203 -> Colibri_VF_LinuxImageV2.3Beta7_20150203
* [neues Tag] Colibri_VF_LinuxImageV2.4Beta1_20150518 -> Colibri_VF_LinuxImageV2.4Beta1_20150518
* [neues Tag] Colibri_VF_LinuxImageV2.5Beta1_20150813 -> Colibri_VF_LinuxImageV2.5Beta1_20150813
* [neues Tag] Colibri_VF_LinuxImageV2.5Beta2_20151106 -> Colibri_VF_LinuxImageV2.5Beta2_20151106
* [neues Tag] Colibri_VF_LinuxImageV2.5Beta3_20151215 -> Colibri_VF_LinuxImageV2.5Beta3_20151215
* [neues Tag] Colibri_VF_LinuxImageV2.6.1Beta1_20161001 -> Colibri_VF_LinuxImageV2.6.1Beta1_20161001
* [neues Tag] Colibri_VF_LinuxImageV2.6Beta1_20160331 -> Colibri_VF_LinuxImageV2.6Beta1_20160331
* [neues Tag] Colibri_VF_LinuxImageV2.6Beta2_20160701 -> Colibri_VF_LinuxImageV2.6Beta2_20160701
* [neues Tag] Colibri_VF_LinuxImageV2.7Beta1_20170112 -> Colibri_VF_LinuxImageV2.7Beta1_20170112
* [neues Tag] Colibri_iMX6_LinuxImageV2.3Beta4_20141113 -> Colibri_iMX6_LinuxImageV2.3Beta4_20141113
* [neues Tag] Colibri_iMX6_LinuxImageV2.3Beta5_20141219 -> Colibri_iMX6_LinuxImageV2.3Beta5_20141219
* [neues Tag] Colibri_iMX6_LinuxImageV2.4Beta1_20150518 -> Colibri_iMX6_LinuxImageV2.4Beta1_20150518
* [neues Tag] Colibri_iMX6_LinuxImageV2.5Beta2_20151106 -> Colibri_iMX6_LinuxImageV2.5Beta2_20151106
* [neues Tag] Colibri_iMX6_LinuxImageV2.5Beta3_20151215 -> Colibri_iMX6_LinuxImageV2.5Beta3_20151215
* [neues Tag] Colibri_iMX6_LinuxImageV2.6.1Beta1_20160929 -> Colibri_iMX6_LinuxImageV2.6.1Beta1_20160929
* [neues Tag] Colibri_iMX6_LinuxImageV2.6Beta1_20160331 -> Colibri_iMX6_LinuxImageV2.6Beta1_20160331
* [neues Tag] Colibri_iMX6_LinuxImageV2.6Beta2_20160701 -> Colibri_iMX6_LinuxImageV2.6Beta2_20160701
* [neues Tag] Colibri_iMX6_LinuxImageV2.7Beta1_20170112 -> Colibri_iMX6_LinuxImageV2.7Beta1_20170112
* [neues Tag] Colibri_iMX7_LinuxImageV2.6.1Beta1_20160929 -> Colibri_iMX7_LinuxImageV2.6.1Beta1_20160929
* [neues Tag] Colibri_iMX7_LinuxImageV2.6Alpha1_20160315 -> Colibri_iMX7_LinuxImageV2.6Alpha1_20160315
* [neues Tag] Colibri_iMX7_LinuxImageV2.6Beta2_20160701 -> Colibri_iMX7_LinuxImageV2.6Beta2_20160701
* [neues Tag] Colibri_iMX7_LinuxImageV2.7Beta1_20170112 -> Colibri_iMX7_LinuxImageV2.7Beta1_20170112
Your identity is: Benjamin x <b.x@yahoo.de>
If you want to change this, please re-run 'repo init' with --config-name
repo has been initialized in /home/x/oe-core
x@ubuntudragon:~/oe-core$ repo sync
Fetching project meta-toradex-demos.git
Fetching project meta-freescale-3rdparty.git
Fetching project bitbake.git
Fetching project meta-toradex-bsp-common.git
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 % Total % Received % Xferd Average Speed Time Time Time Current
remote: Counting objects: 4409, done.
Von http://git.toradex.com/meta-toradex-bsp-common
* [neuer Branch] jethro -> repo/jethro
* [neuer Branch] master -> repo/master
* [neuer Branch] morty -> repo/morty
* [neuer Branch] morty-next -> repo/morty-next
* [neuer Branch] rocko -> repo/rocko
* [neuer Branch] rocko-next -> repo/rocko-next
* [neues Tag] meta-toradex_split -> meta-toradex_split
Fetching projects: 5% (1/17) Fetching project meta-freescale.git
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0Empfange Objekte: 56% (2470/4409), 524.01 KiB | 363.00 KiB/s
Von http://git.toradex.com/meta-toradex-demos
* [neuer Branch] jethro-next -> repo/jethro-next
Fetching projects: 11% (2/17) Fetching project openembedded-core.git
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0remote: Counting objects: 24143, done.
remote: Total 4409 (delta 0), reused 0 (delta 0), pack-reused 4409
Empfange Objekte: 100% (4409/4409), 2.29 MiB | 639.00 KiB/s, Fertig.
Löse Unterschiede auf: 100% (2509/2509), Fertig.
Von http://github.com/Freescale/meta-freescale-3rdparty
* [neuer Branch] daisy -> repo/daisy
* [neuer Branch] danny -> repo/danny
* [neuer Branch] denzil -> repo/denzil
* [neuer Branch] dizzy -> repo/dizzy
* [neuer Branch] dora -> repo/dora
* [neuer Branch] dylan -> repo/dylan
* [neuer Branch] fido -> repo/fido
* [neuer Branch] krogoth -> repo/krogoth
* [neuer Branch] master-next -> repo/master-next
* [neuer Branch] pyro -> repo/pyro
* [neues Tag] 1.2 -> 1.2
* [neues Tag] 1.2-rc1 -> 1.2-rc1
* [neues Tag] 1.3 -> 1.3
* [neues Tag] 1.4 -> 1.4
* [neues Tag] 1.5 -> 1.5
* [neues Tag] 1.6 -> 1.6
* [neues Tag] 1.7 -> 1.7
* [neues Tag] 1.8 -> 1.8
* [neues Tag] 2.0 -> 2.0
* [neues Tag] 2.1 -> 2.1
* [neues Tag] 2.2 -> 2.2
Fetching projects: 17% (3/17) Fetching project meta-angstrom.git
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0Empfange Objekte: 4% (966/24143)
remote: Counting objects: 49657, done. | 5.68 MiB/s --:--:-- 0Empfange Objekte: 46% (11106/24143), 676.01 KiB | 1.23 MiB/s
remote: Compressing objects: 100% (75/75), done.
remote: Counting objects: 309507, done.
remote: Compressing objects: 100% (527/527), done.
remote: Counting objects: 7040, done. iB | 7.33 MiB/s
remote: Compressing objects: 100% (6/6), done.
remote: Total 7040 (delta 2), reused 3 (delta 0), pack-reused 7033
Empfange Objekte: 100% (7040/7040), 2.38 MiB | 771.00 KiB/s, Fertig.
Löse Unterschiede auf: 100% (3280/3280), Fertig.
Von http://github.com/Angstrom-distribution/meta-angstrom/s
* [neuer Branch] angstrom-v2012.05-yocto1.2 -> repo/angstrom-v2012.05-yocto1.2
* [neuer Branch] angstrom-v2012.12-yocto1.3 -> repo/angstrom-v2012.12-yocto1.3
* [neuer Branch] angstrom-v2013.06-yocto1.4 -> repo/angstrom-v2013.06-yocto1.4
* [neuer Branch] angstrom-v2013.12-yocto1.5 -> repo/angstrom-v2013.12-yocto1.5
* [neuer Branch] angstrom-v2014.06-yocto1.6 -> repo/angstrom-v2014.06-yocto1.6
* [neuer Branch] angstrom-v2014.12-yocto1.7 -> repo/angstrom-v2014.12-yocto1.7
* [neuer Branch] angstrom-v2015.06-yocto1.8 -> repo/angstrom-v2015.06-yocto1.8
* [neuer Branch] angstrom-v2015.12-yocto2.0 -> repo/angstrom-v2015.12-yocto2.0
* [neuer Branch] angstrom-v2016.06-yocto2.1 -> repo/angstrom-v2016.06-yocto2.1
* [neuer Branch] angstrom-v2016.12-yocto2.2 -> repo/angstrom-v2016.12-yocto2.2
* [neuer Branch] angstrom-v2017.06-yocto2.3 -> repo/angstrom-v2017.06-yocto2.3
* [neuer Branch] angstrom-v2017.12-rocko -> repo/angstrom-v2017.12-rocko
* [neuer Branch] staging -> repo/staging
* [neuer Branch] work -> repo/work
Fetching projects: 23% (4/17) Fetching project meta-toradex-tegra.git
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0Empfange Objekte: 68% (33767/49657), 10.74 MiB | 2.83 MiB/s
remote: Total 49657 (delta 99), reused 99 (delta 82), pack-reused 49500
Empfange Objekte: 100% (49657/49657), 17.56 MiB | 3.09 MiB/s, Fertig.
Löse Unterschiede auf: 100% (34500/34500), Fertig.
Von http://git.toradex.com/meta-toradex-tegraMiB | 2.18 MiB/s
Fetching projects: 29% (5/17) Fetching project meta-browser.git
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0Von http://github.com/openembedded/bitbake
* [neuer Branch] 1.10 -> repo/1.10
* [neuer Branch] 1.12 -> repo/1.12
* [neuer Branch] 1.14 -> repo/1.14
* [neuer Branch] 1.16 -> repo/1.16
* [neuer Branch] 1.18 -> repo/1.18
* [neuer Branch] 1.20 -> repo/1.20
* [neuer Branch] 1.22 -> repo/1.22
* [neuer Branch] 1.24 -> repo/1.24
* [neuer Branch] 1.26 -> repo/1.26
* [neuer Branch] 1.28 -> repo/1.28
* [neuer Branch] 1.3 -> repo/1.3
* [neuer Branch] 1.30 -> repo/1.30
* [neuer Branch] 1.32 -> repo/1.32
* [neuer Branch] 1.34 -> repo/1.34
* [neuer Branch] 1.36 -> repo/1.36
* [neuer Branch] 1.4 -> repo/1.4
* [neuer Branch] 1.6 -> repo/1.6
* [neuer Branch] 1.8 -> repo/1.8
* [neuer Branch] master-poky -> repo/master-poky
* [neuer Branch] next -> repo/next
* [neuer Branch] pristine-tar -> repo/pristine-tar
* [neuer Branch] wmat -> repo/wmat
* [neuer Branch] wmat2 -> repo/wmat2
* [neues Tag] 1.0 -> 1.0
* [neues Tag] 1.1 -> 1.1
* [neues Tag] 1.10.0 -> 1.10.0
* [neues Tag] 1.10.1 -> 1.10.1
* [neues Tag] 1.10.2 -> 1.10.2
* [neues Tag] 1.12.0 -> 1.12.0
* [neues Tag] 1.13.1 -> 1.13.1
* [neues Tag] 1.13.2 -> 1.13.2
* [neues Tag] 1.13.3 -> 1.13.3
* [neues Tag] 1.14.0 -> 1.14.0
* [neues Tag] 1.15.1 -> 1.15.1
* [neues Tag] 1.15.2 -> 1.15.2
* [neues Tag] 1.15.3 -> 1.15.3
* [neues Tag] 1.16.0 -> 1.16.0
* [neues Tag] 1.17.0 -> 1.17.0
* [neues Tag] 1.2.1 -> 1.2.1
* [neues Tag] 1.26.0 -> 1.26.0
* [neues Tag] 1.3.0 -> 1.3.0
* [neues Tag] 1.3.1 -> 1.3.1
* [neues Tag] 1.3.2 -> 1.3.2
* [neues Tag] 1.3.3 -> 1.3.3
* [neues Tag] 1.4.2 -> 1.4.2
* [neues Tag] 1.4.4 -> 1.4.4
* [neues Tag] 1.6.0 -> 1.6.0
* [neues Tag] 1.6.2 -> 1.6.2
* [neues Tag] 1.6.4 -> 1.6.4
* [neues Tag] 1.6.6 -> 1.6.6
* [neues Tag] 1.6.8 -> 1.6.8
* [neues Tag] 1.7.2 -> 1.7.2
* [neues Tag] 1.8.0 -> 1.8.0
* [neues Tag] 1.8.10 -> 1.8.10
* [neues Tag] 1.8.12 -> 1.8.12
* [neues Tag] 1.8.14 -> 1.8.14
* [neues Tag] 1.8.16 -> 1.8.16
* [neues Tag] 1.8.18 -> 1.8.18
* [neues Tag] 1.8.19 -> 1.8.19
* [neues Tag] 1.8.2 -> 1.8.2
* [neues Tag] 1.8.4 -> 1.8.4
* [neues Tag] 1.8.6 -> 1.8.6
* [neues Tag] 1.8.8 -> 1.8.8
Fetching projects: 35% (6/17) Fetching project meta-snappy.git
remote: Total 24143 (delta 0), reused 0 (delta 0), pack-reused 24143
Empfange Objekte: 100% (24143/24143), 40.84 MiB | 3.79 MiB/s, Fertig.
Löse Unterschiede auf: 100% (12700/12700), Fertig.-:-- --:--:-- --:--:-- 0Löse Unterschiede auf: 4% (516/12700)
Von http://github.com/Freescale/meta-freescaleiB | 2.24 MiB/s
Fetching projects: 41% (7/17) Fetching project meta-jetson-tk1.git
remote: Counting objects: 3929, done. MiB | 2.29 MiB/s
remote: Counting objects: 388, done.
remote: Compressing objects: 100% (8/8), done.
remote: Total 388 (delta 1), reused 6 (delta 1), pack-reused 379
Empfange Objekte: 100% (388/388), 78.97 KiB | 0 bytes/s, Fertig.
Löse Unterschiede auf: 100% (149/149), Fertig.
Von http://github.com/morphis/meta-snappy
* [neuer Branch] f/2.25-for-morty -> repo/f/2.25-for-morty
* [neuer Branch] f/2.25-for-pyro -> repo/f/2.25-for-pyro
* [neuer Branch] f/support-for-pyro -> repo/f/support-for-pyro
* [neuer Branch] f/upgrade-to-2.23.6 -> repo/f/upgrade-to-2.23.6
* [neuer Branch] f/upgrade-to-2.24 -> repo/f/upgrade-to-2.24
* [neuer Branch] update-snapd-2.16 -> repo/update-snapd-2.16
* [neuer Branch] upgrade-to-2.21 -> repo/upgrade-to-2.21
* [neuer Branch] upgrade-to-2.23 -> repo/upgrade-to-2.23
Fetching projects: 47% (8/17) Fetching project meta-lxde.git
remote: Counting objects: 566, done.
remote: Total 3929 (delta 0), reused 2 (delta 0), pack-reused 3923
Empfange Objekte: 100% (3929/3929), 965.70 KiB | 1.50 MiB/s, Fertig.
ime Current % Received % Xferd Average Speed Time Time TLöse Unterschiede auf: 2% (53/2539)
Löse Unterschiede auf: 100% (2539/2539), Fertig.de auf: 4% (110/2539) 84/2539)
Von http://github.com/OSSystems/meta-browser
* [neuer Branch] jansa/master -> repo/jansa/master
remote: Total 566 (delta 0), reused 0 (delta 0), pack-reused 566
Empfange Objekte: 100% (566/566), 95.25 KiB | 0 bytes/s, Fertig.
Löse Unterschiede auf: 100% (222/222), Fertig.
Fetching projects: 52% (9/17) Fetching project meta-freescale-distro.git
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0Von http://github.com/watatuki/meta-jetson-tk1
* [neuer Branch] Morty -> repo/Morty
* [neues Tag] R21.1.0-stable -> R21.1.0-stable
* [neues Tag] R21.2.0-stable -> R21.2.0-stable
* [neues Tag] R21.3.0-stable -> R21.3.0-stable
* [neues Tag] R21.4.0-stable -> R21.4.0-stable
* [neues Tag] R21.4.0-unstable-krogoth -> R21.4.0-unstable-krogoth
Fetching projects: 58% (10/17) Fetching project meta-qt5.git
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0Von http://git.toradex.com/meta-lxde
* [neuer Branch] krogoth-next -> repo/krogoth-next
Fetching projects: 64% (11/17) Fetching project meta-qt4
0 0 0 0 0 0 0 0 --:--:-- 0:00:01 --:--:-- 0
remote: Counting objects: 1376, done.
remote: Counting objects: 8510, done. MiB | 2.83 MiB/s
remote: Compressing objects: 100% (107/107), done.
remote: Total 1376 (delta 0), reused 0 (delta 0), pack-reused 1376
Empfange Objekte: 100% (1376/1376), 311.23 KiB | 0 bytes/s, Fertig.
Löse Unterschiede auf: 100% (772/772), Fertig.
Von http://github.com/Freescale/meta-freescale-distro83 MiB/s
Fetching projects: 70% (12/17) Fetching project meta-toradex-nxp.git
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0Empfange Objekte: 13% (1107/8510)
remote: Total 8510 (delta 23), reused 16 (delta 2), pack-reused 8401
Empfange Objekte: 100% (8510/8510), 2.45 MiB | 3.70 MiB/s, Fertig.
Löse Unterschiede auf: 100% (5322/5322), Fertig.
Von http://github.com/meta-qt5/meta-qt533.80 MiB | 3.01 MiB/s
* [neuer Branch] dora-next -> repo/dora-next
* [neuer Branch] fido-next -> repo/fido-next
* [neuer Branch] jansa/daisy -> repo/jansa/daisy
* [neuer Branch] jansa/dizzy -> repo/jansa/dizzy
* [neuer Branch] jansa/fido -> repo/jansa/fido
* [neuer Branch] jansa/jethro -> repo/jansa/jethro
* [neuer Branch] jansa/krogoth -> repo/jansa/krogoth
* [neuer Branch] jansa/morty -> repo/jansa/morty
* [neuer Branch] jansa/pyro -> repo/jansa/pyro
* [neuer Branch] jansa/rocko -> repo/jansa/rocko
* [neuer Branch] otavio/master -> repo/otavio/master
* [neuer Branch] pyro-next -> repo/pyro-next
* [neues Tag] 5.2.1+origin/release -> 5.2.1+origin/release
* [neues Tag] jansa/test-2013-10-08 -> jansa/test-2013-10-08
* [neues Tag] master-next-2014-02-19 -> master-next-2014-02-19
Fetching projects: 76% (13/17) Fetching project meta-openembedded.git
remote: Counting objects: 310, done.
remote: Compressing objects: 100% (244/244), done.
remote: Total 310 (delta 141), reused 228 (delta 59)
Empfange Objekte: 100% (310/310), 105.66 KiB | 98.00 KiB/s, Fertig.
Löse Unterschiede auf: 100% (141/141), Fertig.
Von https://git.yoctoproject.org/git/meta-qt4
* [neues Tag] 2.1_M1 -> 2.1_M1
* [neues Tag] 2.2_M1 -> 2.2_M1
* [neues Tag] 2.2_M2 -> 2.2_M2
* [neues Tag] 2.2_M3 -> 2.2_M3
* [neues Tag] 2.3_M1 -> 2.3_M1
* [neues Tag] 2.3_M2 -> 2.3_M2
* [neues Tag] 2.3_M3 -> 2.3_M3
* [neues Tag] 2.4_M1 -> 2.4_M1
* [neues Tag] 2.4_M2 -> 2.4_M2
* [neues Tag] 2.4_M3 -> 2.4_M3
* [neues Tag] 2.5_M1 -> 2.5_M1
* [neues Tag] krogoth-15.0.0 -> krogoth-15.0.0
* [neues Tag] krogoth-15.0.1 -> krogoth-15.0.1
* [neues Tag] krogoth-15.0.2 -> krogoth-15.0.2
* [neues Tag] krogoth-15.0.3 -> krogoth-15.0.3
* [neues Tag] morty-16.0.0 -> morty-16.0.0
* [neues Tag] morty-16.0.1 -> morty-16.0.1
* [neues Tag] morty-16.0.2 -> morty-16.0.2
* [neues Tag] pyro-17.0.0 -> pyro-17.0.0
* [neues Tag] pyro-17.0.1 -> pyro-17.0.1
* [neues Tag] pyro-17.0.3 -> pyro-17.0.3
* [neues Tag] rocko-18.0.0 -> rocko-18.0.0
* [neues Tag] rocko-18.0.1 -> rocko-18.0.1
* [neues Tag] yocto-2.1 -> yocto-2.1
* [neues Tag] yocto-2.1.1 -> yocto-2.1.1
* [neues Tag] yocto-2.1.2 -> yocto-2.1.2
* [neues Tag] yocto-2.1.3 -> yocto-2.1.3
* [neues Tag] yocto-2.2 -> yocto-2.2
* [neues Tag] yocto-2.2.1 -> yocto-2.2.1
* [neues Tag] yocto-2.2.2 -> yocto-2.2.2
* [neues Tag] yocto-2.3 -> yocto-2.3
* [neues Tag] yocto-2.3.1 -> yocto-2.3.1
* [neues Tag] yocto-2.3.3 -> yocto-2.3.3
* [neues Tag] yocto-2.4 -> yocto-2.4
* [neues Tag] yocto-2.4.1 -> yocto-2.4.1
remote: Counting objects: 87326, done. iB | 3.34 MiB/s 09507), 38.80 MiB | 3.26 MiB/s
remote: Compressing objects: 100% (5/5), done.
Von http://git.toradex.com/meta-toradex-nxp5 MiB | 3.49 MiB/s
remote: Total 87326 (delta 5), reused 4 (delta 4), pack-reused 87317
Empfange Objekte: 100% (87326/87326), 32.24 MiB | 4.93 MiB/s, Fertig.
Löse Unterschiede auf: 100% (49937/49937), Fertig.| 4.25 MiB/s
Von http://github.com/openembedded/meta-openembedded4.51 MiB/s
* [neuer Branch] daisy-next -> repo/daisy-next
* [neuer Branch] danny-next -> repo/danny-next
* [neuer Branch] denzil-next -> repo/denzil-next
* [neuer Branch] dizzy-next -> repo/dizzy-next
* [neuer Branch] dylan-next -> repo/dylan-next
remote: Total 309507 (delta 599), reused 916 (delta 553), pack-reused 308401 4.51 MiB/s
Empfange Objekte: 100% (309507/309507), 118.72 MiB | 7.39 MiB/s, Fertig.
Löse Unterschiede auf: 100% (212893/212893), Fertig.
Von http://github.com/openembedded/openembedded-core
* [neuer Branch] 2011-1 -> repo/2011-1
* [neuer Branch] master-next-1.9 -> repo/master-next-1.9
* [neuer Branch] master-next-2.5 -> repo/master-next-2.5
* [neuer Branch] master-next2 -> repo/master-next2
* [neues Tag] 2011-1 -> 2011-1
* [neues Tag] 2015-4 -> 2015-4
* [neues Tag] 2016-10 -> 2016-10
* [neues Tag] 2016-4 -> 2016-4
* [neues Tag] 2017-10 -> 2017-10
* [neues Tag] uninative-1.0 -> uninative-1.0
* [neues Tag] uninative-1.3 -> uninative-1.3
* [neues Tag] uninative-1.4 -> uninative-1.4
* [neues Tag] uninative-1.5 -> uninative-1.5
* [neues Tag] uninative-1.6 -> uninative-1.6
* [neues Tag] uninative-1.7 -> uninative-1.7
Fetching projects: 100% (17/17), done.
Syncing work tree: 100% (17/17), done.
x@ubuntudragon:~/oe-core$ . export
You had no conf/local.conf file. This configuration file has therefore been
created for you with some default values. You may wish to edit it to, for
example, select a different MACHINE (target hardware). See conf/local.conf
for more information as common configuration options are commented.
You had no conf/bblayers.conf file. This configuration file has therefore been
created for you with some default values. To add additional metadata layers
into your configuration please add entries to conf/bblayers.conf.
The Yocto Project has extensive documentation about OE including a reference
manual which can be found at:
http://yoctoproject.org/documentation
For more information about OpenEmbedded see their website:
http://www.openembedded.org/
### Shell environment set up for builds. ###
You can now run 'bitbake <target>'
Common targets are:
core-image-minimal
core-image-sato
meta-toolchain
meta-ide-support
You can also run generated qemu images with a command like 'runqemu qemux86'
Toradex targets are:
angstrom-lxde-image
console-tdx-image
angstrom-qt-x11-image
A sample conf/local.conf file has been created
Check and edit the file to adapt to your local needs
The following likely need your attention:
BB_NUMBER_THREADS, PARALLEL_MAKE, DL_DIR
x@ubuntudragon:~/oe-core/build$
x@ubuntudragon:~/oe-core/build$ gedit conf/bblayers.conf
x@ubuntudragon:~/oe-core/build$ gedit conf/local.conf
x@ubuntudragon:~/oe-core/build$ more conf/bblayers.conf
LCONF_VERSION = "7"
BBFILES ?= ""
BBLAYERS ?= " \
x@ubuntudragon:~/oe-core/build$ more conf/local.conf
# Machine Selection
# Options are:
# are:
# further details.
#TEST_IMAGE = "1"
CONF_VERSION = "1"
DISTRO = "angstrom"
IMAGE_INSTALL_append = " qtbase qtbase-fonts qtbase-plugins cinematicexperience"
x@ubuntudragon:~/oe-core/build$ bitbake console-tdx-image
WARNING: /home/x/oe-core/build/../layers/meta-jetson-tk1/recipes-kernel/linux/linux-L4T_3.10.bb: QA Issue: PN: linux-L4T is upper case, this can result in unexpected behavior. [uppercase-pn]00:21
Parsing recipes: 100% |######################################################################################################################################################################| Time: 0:00:49
Parsing of 2633 .bb files complete (0 cached, 2633 parsed). 3479 targets, 459 skipped, 0 masked, 0 errors.
WARNING: No recipes available for:
/home/x/oe-core/build/../layers/meta-freescale/dynamic-layers/browser-layer/recipes-browser/chromium/chromium-wayland_48.0.2548.0.bbappend
/home/x/oe-core/build/../layers/meta-freescale/dynamic-layers/browser-layer/recipes-browser/chromium/chromium_52.0.2743.76.bbappend
/home/x/oe-core/build/../layers/meta-jetson-tk1/recipes-graphics/mesa/mesa_11.1.1.bbappend
/home/x/oe-core/build/../layers/meta-angstrom/recipes-tweaks/opkg/opkg_0.3.4.bbappend
/home/x/oe-core/build/../layers/meta-toradex-demos/recipes-support/icu/icu_57%.bbappend
/home/x/oe-core/build/../layers/meta-toradex-demos/recipes-support/opencv/opencv_2.4.bbappend
Build Configuration:
BB_VERSION = "1.36.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "ubuntu-16.04"
TARGET_SYS = "arm-angstrom-linux-gnueabi"
DISTRO = "angstrom"
DISTRO_VERSION = "v2017.12"
TUNE_FEATURES = "arm armv7a vfp thumb neon callconvention-hard"
TARGET_FPU = "hard"
meta-angstrom = "HEAD:2a246b9f26126a662caef79a99845ff8379145b9"
meta-toradex-nxp = "HEAD:53fdf58e0a31c94ef446fe7c9e20585dad763099"
meta-freescale = "HEAD:bf7fd9cfe0788fe2f819a4ae2cc7db8327fe161a"
meta-freescale-3rdparty = "HEAD:37c79046d13d10ab16561dddc764c0164ee5deaa"
meta-toradex-tegra = "HEAD:4931a667e17a72819331265ca8b3b0f176ef6293"
meta-jetson-tk1 = "HEAD:e8b87fe8da7c6fcffa37ab245f50082953cc1ee1"
meta-toradex-bsp-common = "HEAD:eb87aec937ab520da8162c89e69d33faf9bc29a2"
meta-snappy = "HEAD:a0432dcff49e35af9175c5bdd57d6b5871062ecf"
meta-oe
meta-filesystems
meta-gnome
meta-xfce
meta-initramfs
meta-networking
meta-multimedia
meta-python = "HEAD:6e3fc5b8d904d06e3aa77e9ec9968ab37a798188"
meta-lxde = "HEAD:dbcbbfd9539a9a017bb6c9b7fd67c3ca22c4cacf"
meta-browser = "HEAD:8cc24caa56f254e09ccb2311b59d054d1f016014"
meta-qt4 = "HEAD:f313dbee2ac3d5fcc9801407947d3cb6cfb90b5d"
meta-qt5 = "HEAD:d87335a50a9dd35d890786edbd79b8953fdaa11a"
meta-freescale-distro = "HEAD:3f958b6a9a4c4120f241e431fec8e5ba616fcc73"
meta-toradex-demos = "HEAD:51cb154f4219a918590994bcbe0e14f9545120cc"
meta-imx6-sens = "<unknown>:<unknown>"
meta = "HEAD:39fc1150e74173fc6d73c464c141dba0b7ac2930"
Initialising tasks: 100% |###################################################################################################################################################################| Time: 0:00:06
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
WARNING: libpng-native-1.6.31-r0 do_fetch: Failed to fetch URL http://downloads.sourceforge.net/project/libpng/libpng16/1.6.31/libpng-1.6.31.tar.xz, attempting MIRRORS if available
WARNING: libpng-native-1.6.31-r0 do_fetch: Invalid mirror data http://www.freescale.com/lgfiles/NMG/MAD/YOCTO/ http://download.ossystems.com.br/bsp/freescale/source/ \n http://git.freescale.com/source/ http://download.ossystems.com.br/bsp/freescale/source/ \n http://ftp.debian.org/debian/pool http://snapshot.debian.org/archive/debian-archive/20120328T092752Z/debian/pool \n http://ftp.debian.org/debian/pool http://snapshot.debian.org/archive/debian-archive/20110127T084257Z/debian/pool \n http://ftp.debian.org/debian/pool http://snapshot.debian.org/archive/debian-archive/20090802T004153Z/debian/pool \n http://ftp.debian.org/debian/pool http://ftp.de.debian.org/debian/pool \n http://ftp.debian.org/debian/pool http://ftp.au.debian.org/debian/pool \n http://ftp.debian.org/debian/pool http://ftp.cl.debian.org/debian/pool \n http://ftp.debian.org/debian/pool http://ftp.hr.debian.org/debian/pool \n http://ftp.debian.org/debian/pool http://ftp.fi.debian.org/debian/pool \n http://ftp.debian.org/debian/pool http://ftp.hk.debian.org/debian/pool \n http://ftp.debian.org/debian/pool http://ftp.hu.debian.org/debian/pool \n http://ftp.debian.org/debian/pool http://ftp.ie.debian.org/debian/pool \n http://ftp.debian.org/debian/pool http://ftp.it.debian.org/debian/pool \n http://ftp.debian.org/debian/pool http://ftp.jp.debian.org/debian/pool \n http://ftp.debian.org/debian/pool http://ftp.no.debian.org/debian/pool \n http://ftp.debian.org/debian/pool http://ftp.pl.debian.org/debian/pool \n http://ftp.debian.org/debian/pool http://ftp.ro.debian.org/debian/pool \n http://ftp.debian.org/debian/pool http://ftp.si.debian.org/debian/pool \n http://ftp.debian.org/debian/pool http://ftp.es.debian.org/debian/pool \n http://ftp.debian.org/debian/pool http://ftp.se.debian.org/debian/pool \n http://ftp.debian.org/debian/pool http://ftp.tr.debian.org/debian/pool \n http://ftp.gnu.org/gnu https://mirrors.kernel.org/gnu \n http://cdn.kernel.org/pub http://www.kernel.org/pub \n https://www.gnupg.org/ftp/gcrypt ftp://ftp.gnupg.org/gcrypt \n https://www.gnupg.org/ftp/gcrypt ftp://ftp.franken.de/pub/crypt/mirror/ftp.gnupg.org/gcrypt \n https://www.gnupg.org/ftp/gcrypt ftp://mirrors.dotsrc.org/gcrypt \n ftp://dante.ctan.org/tex-archive ftp://ftp.fu-berlin.de/tex/CTAN \n ftp://dante.ctan.org/tex-archive http://sunsite.sut.ac.jp/pub/archives/ctan/ \n ftp://dante.ctan.org/tex-archive http://ctan.unsw.edu.au/ \n ftp://ftp.gnutls.org/gcrypt/gnutls https://www.gnupg.org/ftp/gcrypt/gnutls \n http://ftp.info-zip.org/pub/infozip/src/ http://mirror.switch.ch/ftp/mirror/infozip/src/ \n http://ftp.info-zip.org/pub/infozip/src/ ftp://sunsite.icm.edu.pl/pub/unix/archiving/info-zip/src/ \n http://www.mirrorservice.org/sites/lsof.itap.purdue.edu/pub/tools/unix/lsof/ http://www.mirrorservice.org/sites/lsof.itap.purdue.edu/pub/tools/unix/lsof/OLD/ \n http://archive.apache.org/dist http://www.us.apache.org/dist \n http://archive.apache.org/dist http://archive.apache.org/dist \n http://downloads.sourceforge.net/watchdog/ http://fossies.org/linux/misc/ \n http://download.savannah.gnu.org/releases http://download-mirror.savannah.gnu.org/releases \n http://download.savannah.nongnu.org/releases http://download-mirror.savannah.nongnu.org/releases \n ftp://sourceware.org/pub http://mirrors.kernel.org/sourceware \n ftp://sourceware.org/pub http://gd.tuwien.ac.at/gnu/sourceware \n ftp://sourceware.org/pub http://ftp.gwdg.de/pub/linux/sources.redhat.com/sourceware \n cvs://.*/.* http://downloads.yoctoproject.org/mirror/sources/ \n svn://.*/.* http://downloads.yoctoproject.org/mirror/sources/ \n git://.*/.* http://downloads.yoctoproject.org/mirror/sources/ \n hg://.*/.* http://downloads.yoctoproject.org/mirror/sources/ \n bzr://.*/.* http://downloads.yoctoproject.org/mirror/sources/ \n p4://.*/.* http://downloads.yoctoproject.org/mirror/sources/ \n osc://.*/.* http://downloads.yoctoproject.org/mirror/sources/ \n https?$://.*/.* http://downloads.yoctoproject.org/mirror/sources/ \n ftp://.*/.* http://downloads.yoctoproject.org/mirror/sources/ \n npm://.*/?.* http://downloads.yoctoproject.org/mirror/sources/ \n cvs://.*/.* http://sources.openembedded.org/ \n svn://.*/.* http://sources.openembedded.org/ \n git://.*/.* http://sources.openembedded.org/ \n hg://.*/.* http://sources.openembedded.org/ \n bzr://.*/.* http://sources.openembedded.org/ \n p4://.*/.* http://sources.openembedded.org/ \n osc://.*/.* http://sources.openembedded.org/ \n https?$://.*/.* http://sources.openembedded.org/ \n ftp://.*/.* http://sources.openembedded.org/ \n npm://.*/?.* http://sources.openembedded.org/ \n http://search.cpan.org/CPAN http://cpan.metacpan.org/ \n http://search.cpan.org/CPAN http://search.cpan.org/CPAN/ \n git://anonscm.debian.org/.* git://anonscm.debian.org/git/PATH;protocol=https \n git://git.gnome.org/.* git://git.gnome.org/browse/PATH;protocol=https \n git://git.savannah.gnu.org/.* git://git.savannah.gnu.org/git/PATH;protocol=https \n git://git.yoctoproject.org/.* git://git.yoctoproject.org/git/PATH;protocol=https \n git://.*/.* git://HOST/PATH;protocol=https \n http://downloads.sourceforge.net/project/libpng/libpng16/1.6.31/ http://downloads.sourceforge.net/project/libpng/libpng16/older-releases/1.6.31/ftp://.*/.* http://sources.angstrom-distribution.org/v2017.12/
https?$://.*/.* http://sources.angstrom-distribution.org/v2017.12/
, should have paired members.
NOTE: Tasks Summary: Attempted 4670 tasks of which 6 didn't need to be rerun and all succeeded.
NOTE: Writing buildhistory
Summary: There were 4 WARNING messages shown.
I think I do everything like your OpenEmbedded wiki. But I still get the 0x300b error every time:
U-Boot 2016.11-2.8.1+g30a1208 (Feb 10 2018 - 14:21:00 +0100)
CPU: Freescale i.MX6Q rev1.5 at 792 MHz
Reset cause: POR
I2C: ready
DRAM: 2 GiB
PMIC: device id: 0x10, revision id: 0x21, programmed
auto-detected panel vga-rgb
Display: vga-rgb (640x480)
In: serial
Out: serial
Err: serial
Model: Toradex Apalis iMX6 Quad 2GB IT V1.1C, Serial# 05103931
Net: using PHY at 7
FEC [PRIME]
Apalis iMX6 #
Apalis iMX6 #
Apalis iMX6 #
Apalis iMX6 # run setupdate
reading flash_blk.img
710 bytes read in 24 ms (28.3 KiB/s)
710 bytes read in 13 ms (52.7 KiB/s)
## Executing script at 12000000
reading apalis_imx6/flash_blk.img
4261 bytes read in 18 ms (230.5 KiB/s)
enter "run update" to update the entire module
Apalis iMX6 # run update
switch to partitions #1, OK
mmc0(part 1) is current device
MMC read: dev # 0, block # 138, count 1 ... 1 blocks read: OK
reading apalis_imx6/u-boot.imx-spl
370240 bytes read in 39 ms (9.1 MiB/s)
MMC write: dev # 0, block # 138, count 724 ... 724 blocks written: OK
Fuse 0, 5: 5072
Fast boot mode already fused, no need to fuse
reading apalis_imx6/mbr.bin
512 bytes read in 15 ms (33.2 KiB/s)
switch to partitions #0, OK
MMC write: dev # 0, block # 0, count 1 ... 1 blocks written: OK
reading apalis_imx6/boot.vfat
16777216 bytes read in 809 ms (19.8 MiB/s)
MMC write: dev # 0, block # 8192, count 32768 ... 32768 blocks written: OK
reading apalis_imx6/uImage
5362936 bytes read in 271 ms (18.9 MiB/s)
writing uImage
5362936 bytes written
reading apalis_imx6/imx6q-apalis-eval.dtb
54409 bytes read in 26 ms (2 MiB/s)
writing imx6q-apalis-eval.dtb
54409 bytes written
reading apalis_imx6/root.ext4-100
67108864 bytes read in 3176 ms (20.2 MiB/s)
MMC write: dev # 0, block # 40960, count 131072 ... 131072 blocks written: OK
reading apalis_imx6/root.ext4-101
67108864 bytes read in 3174 ms (20.2 MiB/s)
MMC write: dev # 0, block # 172032, count 131072 ... 131072 blocks written: OK
reading apalis_imx6/root.ext4-102
67108864 bytes read in 3177 ms (20.1 MiB/s)
MMC write: dev # 0, block # 303104, count 131072 ... 131072 blocks written: OK
reading apalis_imx6/root.ext4-103
MMC write: dev # 0, block # 434176, count 131072 ... 131072 blocks written: OK
reading apalis_imx6/root.ext4-104
MMC write: dev # 0, block # 565248, count 131072 ... 131072 blocks written: OK
reading apalis_imx6/root.ext4-105
MMC write: dev # 0, block # 696320, count 131072 ... 131072 blocks written: OK
reading apalis_imx6/root.ext4-106
MMC write: dev # 0, block # 827392, count 131072 ... 131072 blocks written: OK
reading apalis_imx6/root.ext4-107
67108864 bytes read in 3173 ms (20.2 MiB/s)
MMC write: dev # 0, block # 958464, count 131072 ... 131072 blocks written: OK
reading apalis_imx6/root.ext4-108
MMC write: dev # 0, block # 1089536, count 131072 ... 131072 blocks written: OK
reading apalis_imx6/root.ext4-109
67108864 bytes read in 3180 ms (20.1 MiB/s)
MMC write: dev # 0, block # 1220608, count 131072 ... 131072 blocks written: OK
reading apalis_imx6/root.ext4-110
44040192 bytes read in 2095 ms (20 MiB/s)
MMC write: dev # 0, block # 1351680, count 86016 ... 86016 blocks written: OK
resetting ...
U-Boot 2016.11-2.8.1+g30a1208 (Feb 16 2018 - 01:17:47 +0100)
Reset cause: WDOG
I2C: ready
DRAM: 2 GiB
In: serial
Out: serial
Err: serial
Net: using PHY at 7
FEC [PRIME]
Booting from internal eMMC chip...
reading imx6q-apalis-eval.dtb
54409 bytes read in 18 ms (2.9 MiB/s)
reading uImage
5362936 bytes read in 160 ms (32 MiB/s)
## Booting kernel from Legacy Image at 11000000 ...
Image Name: Linux-4.9.67-+g1db9f06
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 5362872 Bytes = 5.1 MiB
Load Address: 10008000
Entry Point: 10008000
Verifying Checksum ... OK
## Flattened Device Tree blob at 12000000
Booting using the fdt blob at 0x12000000
Loading Kernel Image ... OK
Using Device Tree in place at 12000000, end 12010488
Starting kernel ...
[ 0.000000] Linux version 4.9.67-+g1db9f06 (oe-user@oe-host) (gcc version 7.2.0 (GCC) ) #1 SMP Fri Feb 16 01:16:09 CET 2018
[ 0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt:Machine model: Toradex Apalis iMX6Q/D Module on Apalis Evaluation Board
[ 0.000000] Reserved memory: created CMA memory pool at 0x7c000000, size 320 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] percpu: Embedded 14 pages/cpu @e5797000 s25612 r8192 d23540 u57344
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 521008
[ 0.000000] Kernel command line: vmalloc=400M user_debug=30 ip=off root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait fec_mac=00:14:2d:4d:e1:3b consoleblank=0 no_console_suspend=1 console=tty1 console=ttymxc0,115200n8 video=mxcfb0:dev=ldb video=mxcfb1:dev=lcd,EDT-480x272,if=RGB24 video=mxcfb2:ldb video=mxcfb3:off fbmem=512M
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 262144 (order: 8, 1048576 bytes)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Memory: 1739068K/2097152K available (8192K kernel code, 279K rwdata, 1924K rodata, 1024K init, 439K bss, 30404K reserved, 327680K cma-reserved, 90112K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xe7000000 - 0xff800000 ( 392 MB)
[ 0.000000] lowmem : 0x80000000 - 0xe6800000 (1640 MB)
[ 0.000000] pkmap : 0x7fe00000 - 0x80000000 ( 2 MB)
[ 0.000000] modules : 0x7f000000 - 0x7fe00000 ( 14 MB)
[ 0.000000] .text : 0x80008000 - 0x80900000 (9184 kB)
[ 0.000000] .init : 0x80b00000 - 0x80c00000 (1024 kB)
[ 0.000000] .data : 0x80c00000 - 0x80c45e60 ( 280 kB)
[ 0.000000] .bss : 0x80c45e60 - 0x80cb3d8c ( 440 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] L2C-310 errata 752271 769419 enabled
[ 0.000000] L2C-310 enabling early BRESP for Cortex-A9
[ 0.000000] L2C-310 full line of zeros enabled for Cortex-A9
[ 0.000000] L2C-310 ID prefetch enabled, offset 16 lines
[ 0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
[ 0.000000] L2C-310 cache controller enabled, 16 ways, 1024 kB
[ 0.000000] L2C-310: CACHE_ID 0x410000c7, AUX_CTRL 0x76470001
[ 0.000000] Switching to timer-based delay loop, resolution 333ns
[ 0.000007] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 715827882841ns
[ 0.000025] clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
[ 0.001539] Console: colour dummy device 80x30
[ 0.002153] console [tty1] enabled
[ 0.002187] Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
[ 0.002229] pid_max: default: 32768 minimum: 301
[ 0.002337] Mount-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.002365] Mountpoint-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.003007] CPU: Testing write buffer coherency: ok
[ 0.003374] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.003451] Setting up static identity map for 0x10100000 - 0x10100058
[ 0.005339] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.006124] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.006892] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.006984] Brought up 4 CPUs
[ 0.007071] SMP: Total of 4 processors activated (24.00 BogoMIPS).
[ 0.007094] CPU: All CPU(s) started in SVC mode.
[ 0.007911] devtmpfs: initialized
[ 0.021612] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 0.021942] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.021997] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.039125] pinctrl core: initialized pinctrl subsystem
[ 0.040332] NET: Registered protocol family 16
[ 0.047259] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.069577] cpuidle: using governor menu
[ 0.069876] CPU identified as i.MX6Q, silicon rev 1.5
[ 0.095019] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[ 0.095070] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.096118] imx6q-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
[ 0.097821] imx-gpc 20dc000.gpc: no fsl,ldo-bypass found!
[ 0.097967] imx-gpc 20dc000.gpc: Registered imx-gpc
[ 0.119550] usb_host_vbus: supplied by usb_host_vbus_hub
[ 0.120070] vgaarb: loaded
[ 0.120813] SCSI subsystem initialized
[ 0.121280] usbcore: registered new interface driver usbfs
[ 0.121366] usbcore: registered new interface driver hub
[ 0.121475] usbcore: registered new device driver usb
[ 0.122156] i2c-gpio i2c@0: using pins 80 (SDA) and 62 (SCL)
[ 0.123129] i2c i2c-1: IMX I2C adapter registered
[ 0.123169] i2c i2c-1: can't use DMA, using PIO instead.
[ 0.130235] stmpe-i2c 2-0041: stmpe811 detected, chip id: 0x811
[ 0.220530] i2c i2c-2: IMX I2C adapter registered
[ 0.220567] i2c i2c-2: can't use DMA, using PIO instead.
[ 0.221290] i2c i2c-3: IMX I2C adapter registered
[ 0.221327] i2c i2c-3: can't use DMA, using PIO instead.
[ 0.221498] Linux video capture interface: v2.00
[ 0.221566] pps_core: LinuxPPS API ver. 1 registered
[ 0.221591] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.221644] PTP clock support registered
[ 0.249642] imx-ipuv3 2400000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
[ 0.279637] imx-ipuv3 2800000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
[ 0.280569] mxc_mipi_csi2 21dc000.mipi_csi: i.MX MIPI CSI2 driver probed ipu0 csi1
[ 0.280616] mxc_mipi_csi2 21dc000.mipi_csi: i.MX MIPI CSI2 dphy version is 0x3130302a
[ 0.280734] MIPI CSI2 driver module loaded
[ 0.280939] Advanced Linux Sound Architecture Driver Initialized.
[ 0.282739] clocksource: Switched to clocksource mxc_timer1
[ 0.282872] VFS: Disk quotas dquot_6.6.0
[ 0.282949] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.293133] NET: Registered protocol family 2
[ 0.293748] TCP established hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.293919] TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.294189] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.294288] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.294387] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.294625] NET: Registered protocol family 1
[ 0.295087] RPC: Registered named UNIX socket transport module.
[ 0.295118] RPC: Registered udp transport module.
[ 0.295141] RPC: Registered tcp transport module.
[ 0.295163] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.295953] hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
[ 0.297645] Bus freq driver module loaded
[ 0.299497] workingset: timestamp_bits=30 max_order=19 bucket_order=0
[ 0.305955] NFS: Registering the id_resolver key type
[ 0.306009] Key type id_resolver registered
[ 0.306032] Key type id_legacy registered
[ 0.306064] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.306637] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.306978] fuse init (API version 7.26)
[ 0.313136] bounce: pool size: 64 pages
[ 0.313171] io scheduler noop registered
[ 0.313193] io scheduler deadline registered
[ 0.313364] io scheduler cfq registered (default)
[ 0.315673] OF: PCI: host bridge /soc/pcie@0x01000000 ranges:
[ 0.315714] OF: PCI: No bus range found for /soc/pcie@0x01000000, using [bus 00-ff]
[ 0.315767] OF: PCI: IO 0x01f80000..0x01f8ffff -> 0x00000000
[ 0.315799] OF: PCI: MEM 0x01000000..0x01efffff -> 0x01000000
[ 0.565451] imx6q-pcie 1ffc000.pcie: phy link never came up
[ 0.565490] imx6q-pcie 1ffc000.pcie: Link never came up
[ 0.568578] imx6q-pcie 1ffc000.pcie: failed to initialize host
[ 0.568679] imx6q-pcie: probe of 1ffc000.pcie failed with error -110
[ 0.569709] backlight supply power not found, using dummy regulator
[ 0.571613] ldb 2000000.aips-bus:ldb@020e0008: dual mode
[ 0.571932] ldb 2000000.aips-bus:ldb@020e0008: split mode or dual mode, ignoring second output
[ 0.572606] 20e0000.hdmi_video supply HDMI not found, using dummy regulator
[ 0.574531] mxc_sdc_fb fb@0: registered mxc display driver ldb
[ 0.581003] mxc_sdc_fb fb@0: 1280x320 h_sync,r,l: 10,72,20 v_sync,l,u: 10,20,70 pixclock=36001000 Hz
[ 0.602820] imx-ipuv3 2800000.ipu: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
[ 0.648077] mxc_sdc_fb fb@0: 1280x320 h_sync,r,l: 10,72,20 v_sync,l,u: 10,20,70 pixclock=36001000 Hz
[ 0.682408] Console: switching to colour frame buffer device 160x40
[ 0.734914] mxc_sdc_fb fb@1: registered mxc display driver lcd
[ 0.739899] mxc_sdc_fb fb@1: 480x272 h_sync,r,l: 41,2,2 v_sync,l,u: 10,2,2 pixclock=9000000 Hz
[ 0.770482] mxc_hdmi 20e0000.hdmi_video: Detected HDMI controller 0x13:0xa:0xa0:0xc1
[ 0.773475] mxc_sdc_fb fb@2: registered mxc display driver hdmi
[ 0.779648] mxc_sdc_fb fb@2: 640x480 h_sync,r,l: 96,16,48 v_sync,l,u: 2,10,33 pixclock=25174000 Hz
[ 0.806140] mxc_sdc_fb fb@3: mxcfb3 is turned off!
[ 0.810853] imx-sdma 20ec000.sdma: no iram assigned, using external mem
[ 0.814444] imx-sdma 20ec000.sdma: loaded firmware 3.3
[ 0.822081] pfuze100-regulator 2-0008: Full layer: 2, Metal layer: 1
[ 0.825900] pfuze100-regulator 2-0008: FAB: 0, FIN: 0
[ 0.828911] pfuze100-regulator 2-0008: pfuze100 found.
[ 0.849238] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 30, base_baud = 5000000) is a IMX
[ 1.770966] console [ttymxc0] enabled
[ 1.778640] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 80, base_baud = 5000000) is a IMX
[ 1.791026] 21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 81, base_baud = 5000000) is a IMX
[ 1.803325] 21f4000.serial: ttymxc4 at MMIO 0x21f4000 (irq = 82, base_baud = 5000000) is a IMX
[ 1.815988] [drm] Initialized
[ 1.822453] [drm] Initialized vivante 1.0.0 20120216 on minor 0
[ 1.841774] brd: module loaded
[ 1.854319] loop: module loaded
[ 1.861737] ahci-imx 2200000.sata: fsl,transmit-level-mV not specified, using 00000024
[ 1.872843] ahci-imx 2200000.sata: fsl,transmit-boost-mdB not specified, using 00000480
[ 1.883957] ahci-imx 2200000.sata: fsl,transmit-atten-16ths not specified, using 00002000
[ 1.895186] ahci-imx 2200000.sata: fsl,receive-eq-mdB not specified, using 05000000
[ 1.909791] ahci-imx 2200000.sata: SSS flag set, parallel bus scan disabled
[ 1.919825] ahci-imx 2200000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[ 1.931634] ahci-imx 2200000.sata: flags: ncq sntf stag pm led clo only pmp pio slum part ccc apst
[ 1.945079] scsi host0: ahci-imx
[ 1.951485] ata1: SATA max UDMA/133 mmio [mem 0x02200000-0x02203fff] port 0x100 irq 89
[ 1.964732] spi_imx 2008000.ecspi: probed
[ 1.972765] spi_imx 200c000.ecspi: probed
[ 1.980362] libphy: Fixed MDIO Bus: probed
[ 1.987591] vcan: Virtual CAN interface driver
[ 1.994737] CAN device driver interface
[ 2.001485] 2090000.flexcan supply xceiver not found, using dummy regulator
[ 2.011945] flexcan 2090000.flexcan: device registered (reg_base=e76f4000, irq=39)
[ 2.022397] 2094000.flexcan supply xceiver not found, using dummy regulator
[ 2.032844] flexcan 2094000.flexcan: device registered (reg_base=e76fc000, irq=40)
[ 2.044357] 2188000.ethernet supply phy not found, using dummy regulator
[ 2.065432] pps pps0: new PPS source ptp0
[ 2.073455] libphy: fec_enet_mii_bus: probed
[ 2.082236] fec 2188000.ethernet eth0: registered PHC device 0
[ 2.091234] usbcore: registered new interface driver asix
[ 2.099430] usbcore: registered new interface driver ax88179_178a
[ 2.108281] usbcore: registered new interface driver cdc_ether
[ 2.116874] usbcore: registered new interface driver net1080
[ 2.125183] usbcore: registered new interface driver cdc_subset
[ 2.133726] usbcore: registered new interface driver zaurus
[ 2.141870] usbcore: registered new interface driver cdc_ncm
[ 2.149988] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.158958] ehci-pci: EHCI PCI platform driver
[ 2.165945] ehci-mxc: Freescale On-Chip EHCI Host driver
[ 2.173942] usbcore: registered new interface driver usb-storage
[ 2.182546] usbcore: registered new interface driver usbserial
[ 2.190863] usbcore: registered new interface driver usbserial_generic
[ 2.199848] usbserial: USB Serial support registered for generic
[ 2.208267] usbcore: registered new interface driver ftdi_sio
[ 2.216371] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.226038] usbcore: registered new interface driver pl2303
[ 2.233917] usbserial: USB Serial support registered for pl2303
[ 2.243455] 2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 2.264896] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 2.272241] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
[ 2.294268] ata1: SATA link down (SStatus 0 SControl 300)
[ 2.302165] ahci-imx 2200000.sata: no device found, disabling link.
[ 2.302775] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 2.318725] ahci-imx 2200000.sata: pass ahci_imx..hotplug=1 to enable hotplug
[ 2.328708] hub 1-0:1.0: USB hub found
[ 2.334833] hub 1-0:1.0: 1 port detected
[ 2.342088] mousedev: PS/2 mouse device common for all mice
[ 2.360435] input: stmpe-ts as /devices/soc0/soc/2100000.aips-bus/21a4000.i2c/i2c-2/2-0041/stmpe-ts/input/input0
[ 2.376734] rtc-ds1307 1-0068: oscillator failed, set time!
[ 2.387738] rtc-ds1307 1-0068: rtc core: registered m41t0 as rtc0
[ 2.397031] snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-r as rtc1
[ 2.408595] i2c /dev entries driver
[ 2.416141] mxc_v4l2_output v4l2_out: V4L2 device registered as video16
[ 2.425738] mxc_v4l2_output v4l2_out: V4L2 device registered as video17
[ 2.435336] mxc_v4l2_output v4l2_out: V4L2 device registered as video18
[ 2.445006] mxc_v4l2_output v4l2_out: V4L2 device registered as video19
[ 2.454516] mxc_v4l2_output v4l2_out: V4L2 device registered as video20
[ 2.465238] imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0)
[ 2.474405] sdhci: Secure Digital Host Controller Interface driver
[ 2.483280] sdhci: Copyright(c) Pierre Ossman
[ 2.490321] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.499882] sdhci-esdhc-imx 2190000.usdhc: could not get ultra high speed state, work on normal mode
[ 2.511960] sdhci-esdhc-imx 2190000.usdhc: Got CD GPIO
[ 2.582903] mmc1: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
[ 2.593586] sdhci-esdhc-imx 2194000.usdhc: could not get ultra high speed state, work on normal mode
[ 2.605761] sdhci-esdhc-imx 2194000.usdhc: Got CD GPIO
[ 2.671698] mmc1: host does not support reading read-only switch, assuming write-enable
[ 2.682891] mmc2: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
[ 2.696143] usb 1-1: new high-speed USB device number 2 using ci_hdrc
[ 2.706593] mmc1: new high speed SDHC card at address e624
[ 2.715169] random: fast init done
[ 2.715718] sdhci-esdhc-imx 2198000.usdhc: could not get ultra high speed state, work on normal mode
[ 2.717907] mmcblk1: mmc1:e624 SL16G 14.8 GiB
[ 2.741123] mmcblk1: p1
[ 2.772795] mmc0: SDHCI controller on 2198000.usdhc [2198000.usdhc] using ADMA
[ 2.784512] mxc_vpu 2040000.vpu_fsl: VPU initialized
[ 2.793204] mxc_vdoa 21e4000.vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
[ 2.810389] caam 2100000.caam: ERA source: CAAMVID.
[ 2.818331] caam 2100000.caam: AXI pipeline throttling enabled.
[ 2.828108] caam 2100000.caam: Entropy delay = 3200
[ 2.896693] caam 2100000.caam: Instantiated RNG4 SH0
[ 2.923863] hub 1-1:1.0: USB hub found
[ 2.930430] hub 1-1:1.0: 4 ports detected
[ 2.957456] caam 2100000.caam: Instantiated RNG4 SH1
[ 2.965288] caam 2100000.caam: device ID = 0x0a16010000000000 (Era 4)
[ 2.974662] caam 2100000.caam: job rings = 2, qi = 0
[ 2.988883] caam algorithms registered in /proc/crypto
[ 3.005530] caam_jr 2101000.jr0: registering rng-caam
[ 3.014366] snvs-secvio 20cc000.caam-snvs: can't get snvs clock
[ 3.023261] snvs-secvio 20cc000.caam-snvs: violation handlers armed - non-secure state
[ 3.034374] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.042881] usbcore: registered new interface driver usbhid
[ 3.051326] usbhid: USB HID core driver
[ 3.057301] mmc0: new DDR MMC card at address 0001
[ 3.057810] mmcblk0: mmc0:0001 Q2J54A 3.59 GiB
[ 3.058045] mmcblk0boot0: mmc0:0001 Q2J54A partition 1 16.0 MiB
[ 3.058233] mmcblk0boot1: mmc0:0001 Q2J54A partition 2 16.0 MiB
[ 3.066539] mmcblk0: p1 p2
[ 3.101477] stmpe-adc stmpe-adc: Initialized
[ 3.110662] sgtl5000 2-000a: sgtl5000 revision 0x11
[ 3.147099] fsl-ssi-dai 2028000.ssi: No cache defaults, reading back from HW
[ 3.288480] imx-sgtl5000 sound: sgtl5000 <-> 2028000.ssi mapping ok
[ 3.299750] imx-spdif sound-spdif: snd-soc-dummy-dai <-> 2004000.spdif mapping ok
[ 3.312759] imx-audio-hdmi sound-hdmi: hdmi-hifi.0 <-> soc:hdmi_audio@00120000 mapping ok
[ 3.324873] NET: Registered protocol family 10
[ 3.332808] NET: Registered protocol family 17
[ 3.339683] can: controller area network core (rev 20120528 abi 9)
[ 3.348393] NET: Registered protocol family 29
[ 3.355283] can: raw protocol (rev 20120528)
[ 3.361953] can: broadcast manager protocol (rev 20161123 t)
[ 3.370074] can: netlink gateway (rev 20130117) max_hops=1
[ 3.378347] Key type dns_resolver registered
[ 3.387308] cpu cpu0: Registered imx6q-cpufreq
[ 3.394336] Registering SWP/SWPB emulation handler
[ 3.413590] imx_thermal 2000000.aips-bus:tempmon: Industrial CPU temperature grade - max:105C critical:100C passive:95C
[ 3.428393] input: gpio-keys as /devices/soc0/gpio-keys/input/input1
[ 3.439271] rtc-ds1307 1-0068: hctosys: unable to read the hardware clock
[ 3.449575] usb_otg_vbus: disabling
[ 3.455834] ALSA device list:
[ 3.461454] #0: imx6q-apalis-sgtl5000
[ 3.467903] #1: imx-spdif
[ 3.473257] #2: imx-hdmi-soc
[ 3.492333] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.503216] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 3.514532] devtmpfs: mounted
[ 3.521206] Freeing unused kernel memory: 1024K
[ 3.651904] systemd[1]: System time before build time, advancing clock.
[ 3.691486] systemd[1]: systemd 234 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS -ACL -XZ +LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 +IDN default-hierarchy=hybrid)
[ 3.718924] systemd[1]: Detected architecture arm.
Welcome to The Ångström Distribution v2017.12!
[ 3.753256] systemd[1]: Set hostname to <apalis-imx6>.
[ 3.765347] systemd[1]: Initializing machine ID from random generator.
[ 3.775042] systemd[1]: Installed transient /etc/machine-id file.
[ 4.024787] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 4.062962] systemd[1]: Reached target Host and Network Name Lookups.
[ OK ] Reached target Host and Network Name Lookups.
[ 4.103073] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 4.143144] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ 4.199123] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ OK ] Listening on udev Kernel Socket.
[ OK ] Created slice System Slice.
Mounting Kernel Debug File System...
[ OK ] Created slice system-getty.slice.
[ OK ] Created slice User and Session Slice.
[ OK ] Listening on Journal Socket (/dev/log).
[ OK ] Reached target Slices.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ OK ] Reached target Paths.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
Starting Create list of required st…ce nodes for the current kernel...
Starting Journal Service...
[ OK ] Created slice system-serial\x2dgetty.slice.
Starting Load Kernel Modules...
[ 4.662327] galcore: loading out-of-tree module taints kernel.
[ 4.678779] Galcore version 6.2.2.93313
Starting File System Check on Root Device...
[ OK ] Listening on Network Service Netlink Socket.
Starting Export GPIOs to user space...
[ OK ] Reached target Swap.
Mounting Temporary Directory (/tmp)...
[ OK ] Mounted Kernel Debug File System.
[ OK ] Started Journal Service.
[ OK ] Started Create list of required sta…vice nodes for the current kernel.
[ OK ] Mounted Temporary Directory (/tmp).
[ OK ] Started Export GPIOs to user space.
[ OK ] Started File System Check on Root Device.
Starting Remount Root and Kernel File Systems...
[ 5.074532] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ OK ] Started Remount Root and Kernel File Systems.
Starting Rebuild Hardware Database...
Starting Create System Users...
Starting Flush Journal to Persistent Storage...
[ OK ] Started Create System Users.
Starting Create Static Device Nodes in /dev...
[ OK ] Started Create Static Device Nodes in /dev.
[ 5.373891] mmc2: Switching to 3.3V signalling voltage failed
[ 5.395287] systemd-journald[229]: Received request to flush runtime journal from PID 1
[ OK ] Reached target Local File Systems (Pre).
Mounting /var/volatile...
Starting udev Kernel Device Manager...
[ OK ] Mounted /var/volatile.
[ OK ] Started Load Kernel Modules.
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started udev Kernel Device Manager.
Mounting FUSE Control File System...
Starting Apply Kernel Variables...
Mounting Kernel Configuration File System...
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Rebuild Dynamic Linker Cache...
Starting Create Volatile Files and Directories...
Starting Commit a transient machine-id on disk...
Starting Rebuild Journal Catalog...
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Mounted FUSE Control File System.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Create Volatile Files and Directories.
[ OK ] Started Commit a transient machine-id on disk.
[ OK ] Started Rebuild Journal Catalog.
Starting Update UTMP about System Boot/Shutdown...
Starting Opkg first boot configure...
Starting Run pending postinsts...
Starting Network Time Synchronization...
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started Run pending postinsts.
[ OK ] Started Rebuild Dynamic Linker Cache.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Time Synchronized.
[ OK ] Started Opkg first boot configure.
[ OK ] Started Rebuild Hardware Database.
Starting udev Coldplug all Devices...
Starting Update is Completed...
[ OK ] Started Update is Completed.
[ OK ] Created slice system-systemd\x2dbacklight.slice.
Starting Load/Save Screen Backlight…ightness of backlight:backlight...
[ OK ] Started udev Coldplug all Devices.
[ OK ] Started Load/Save Screen Backlight Brightness of backlight:backlight.
[ OK ] Found device /dev/ttymxc0.
[ OK ] Reached target System Initialization.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ 8.230209] max9526 3-0020: Device seems not to be a MAX9526
Starting sshd.socket.
[ 8.265777] adv7280 3-0021: chip found @ 0x42 (21a8000.i2c)
[ 8.280198] adv7280 3-0021: no sensor pwdn pin available
[ 8.323310] adv7280 3-0021: adv7280_probe:Analog Device adv7280 not detected -6!
[ 8.349211] ov564x_mipi 3-003c: found pwm2, period=0
[ OK ] Listening on sshd.socket.
[ OK ] Reached target Sound Card.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ OK ] Started Timestamping service.
[ OK ] Started D-Bus System Message Bus.
[ 8.623254] ov5640_read_reg:write reg error:reg=300a
[ 8.632012] camera ov5640_mipi is not found
[ 8.913970] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
[ 8.916965] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
[ 8.928475] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
Starting Connection service...
Starting Avahi mDNS/DNS-SD Stack...
[ OK ] Started start resize script to incr…ootfs to its partitions full size.
Starting Load default USB gadget schema g1.schema...
Starting Save/Restore Sound Card State...
[ 9.116990] using random self ethernet address
[ 9.125384] using random host ethernet address
Starting Login Service...
Starting RPC Bind Service...
Starting Telephony service...
[ OK ] Reached target Containers.
[ OK ] Started Save/R[ 9.265191] Loading modules backported from Linux version v4.14-0-gbebc608
[ 9.268777] Micrel KSZ9031 Gigabit PHY 2188000.ethernet-1:07: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=2188000.ethernet-1:07, irq=122)
[ 9.268985] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.305736] Backport generated by backports.git v4.14-rc2-1-34-g1d8cc15
[ OK ] Started RPC Bind Service.
[ 9.345126] Bluetooth: Core ver 2.22
[ 9.351936] NET: Registered protocol family 31
[ 9.359247] Bluetooth: HCI device and connection manager initialized
[ 9.368706] Bluetooth: HCI socket layer initialized
[ 9.376516] Bluetooth: L2CAP socket layer initialized
[ 9.384479] Bluetooth: SCO socket layer initialized
[FAILED] Failed to start Load default USB gadget schema g1.schema.
See 'systemctl status usbg.service' for details.
[ OK ] Started Connection service.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started Telephony service.
[ OK ] Started Login Service.
Starting Hostname Service...
Starting WPA supplicant...
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Starting Network Service...
[ OK ] Started WPA supplicant.
[ OK ] Started Network Service.
[ OK ] Reached target Network.
Starting Permit User Sessions...
[ OK ] Started NFS status monitor for NFSv2/3 locking..
[ OK ] Started Permit User Sessions.
[ OK ] Started Hostname Service.
[ OK ] Started Serial Getty on ttymxc0.
[ OK ] Started Getty on tty1.
[ OK ] Reached target Login Prompts.
[ OK ] Reached target Multi-User System.
[ OK ] Reached target Graphical Interface.
Starting Update UTMP about System Runlevel Changes...
[ OK ] Started Update UTMP about System Runlevel Changes.
.---O---.
| | .-. o o
| | | __ | ---'| '--.| .-'| | |
The Angstrom Distribution apalis-imx6 ttymxc0
Angstrom v2017.12 - Kernel
Apalis-iMX6_Console-Image 2.8b1 20180215
apalis-imx6 login: [ 14.190145] EXT4-fs (mmcblk0p2): resizing filesystem from 174592 to 184064 blocks
[ 14.198925] EXT4-fs (mmcblk0p2): resized filesystem to 184064
[ 15.298446] EXT4-fs (mmcblk0p2): resizing filesystem from 184064 to 200448 blocks
[ 15.307634] EXT4-fs (mmcblk0p2): resized filesystem to 200448
[ 16.389917] EXT4-fs (mmcblk0p2): resizing filesystem from 200448 to 216832 blocks
[ 16.399161] EXT4-fs (mmcblk0p2): resized filesystem to 216832
[ 17.498157] EXT4-fs (mmcblk0p2): resizing filesystem from 216832 to 233216 blocks
[ 17.526135] EXT4-fs (mmcblk0p2): resized filesystem to 233216
[ 18.644676] EXT4-fs (mmcblk0p2): resizing filesystem from 233216 to 249600 blocks
[ 18.654093] EXT4-fs (mmcblk0p2): resized filesystem to 249600
[ 19.729033] EXT4-fs (mmcblk0p2): resizing filesystem from 249600 to 265984 blocks
[ 19.738217] EXT4-fs (mmcblk0p2): resized filesystem to 265984
[ 20.814776] EXT4-fs (mmcblk0p2): resizing filesystem from 265984 to 282368 blocks
[ 20.823829] EXT4-fs (mmcblk0p2): resized filesystem to 282368
[ 21.901005] EXT4-fs (mmcblk0p2): resizing filesystem from 282368 to 298752 blocks
[ 21.924789] EXT4-fs (mmcblk0p2): resized filesystem to 298752
[ 23.038951] EXT4-fs (mmcblk0p2): resizing filesystem from 298752 to 315136 blocks
[ 23.048125] EXT4-fs (mmcblk0p2): resized filesystem to 315136
[ 24.126403] EXT4-fs (mmcblk0p2): resizing filesystem from 315136 to 331520 blocks
[ 24.135479] EXT4-fs (mmcblk0p2): resized filesystem to 331520
[ 25.214099] EXT4-fs (mmcblk0p2): resizing filesystem from 331520 to 347904 blocks
[ 25.223359] EXT4-fs (mmcblk0p2): resized filesystem to 347904
[ 26.307901] EXT4-fs (mmcblk0p2): resizing filesystem from 347904 to 364288 blocks
[ 26.317059] EXT4-fs (mmcblk0p2): resized filesystem to 364288
[ 27.408045] EXT4-fs (mmcblk0p2): resizing filesystem from 364288 to 380672 blocks
[ 27.423725] EXT4-fs (mmcblk0p2): resized filesystem to 380672
[ 28.510221] EXT4-fs (mmcblk0p2): resizing filesystem from 380672 to 397056 blocks
[ 28.525243] EXT4-fs (mmcblk0p2): resized filesystem to 397056
[ 29.613969] EXT4-fs (mmcblk0p2): resizing filesystem from 397056 to 413440 blocks
[ 29.629086] EXT4-fs (mmcblk0p2): resized filesystem to 413440
[ 30.714075] EXT4-fs (mmcblk0p2): resizing filesystem from 413440 to 429824 blocks
[ 30.729275] EXT4-fs (mmcblk0p2): resized filesystem to 429824
[ 31.824828] EXT4-fs (mmcblk0p2): resizing filesystem from 429824 to 446208 blocks
[ 31.840285] EXT4-fs (mmcblk0p2): resized filesystem to 446208
[ 32.919984] EXT4-fs (mmcblk0p2): resizing filesystem from 446208 to 462592 blocks
[ 32.943575] EXT4-fs (mmcblk0p2): resized filesystem to 462592
[ 34.032355] EXT4-fs (mmcblk0p2): resizing filesystem from 462592 to 478976 blocks
[ 34.047984] EXT4-fs (mmcblk0p2): resized filesystem to 478976
[ 35.133952] EXT4-fs (mmcblk0p2): resizing filesystem from 478976 to 495360 blocks
[ 35.150001] EXT4-fs (mmcblk0p2): resized filesystem to 495360
[ 36.233142] EXT4-fs (mmcblk0p2): resizing filesystem from 495360 to 511744 blocks
[ 36.248496] EXT4-fs (mmcblk0p2): resized filesystem to 511744
[ 37.340489] EXT4-fs (mmcblk0p2): resizing filesystem from 511744 to 528128 blocks
[ 37.354643] EXT4-fs (mmcblk0p2): resized filesystem to 528128
[ 38.444271] EXT4-fs (mmcblk0p2): resizing filesystem from 528128 to 544512 blocks
[ 38.459508] EXT4-fs (mmcblk0p2): resized filesystem to 544512
[ 39.535603] EXT4-fs (mmcblk0p2): resizing filesystem from 544512 to 560896 blocks
[ 39.550904] EXT4-fs (mmcblk0p2): resized filesystem to 560896
[ 40.642462] EXT4-fs (mmcblk0p2): resizing filesystem from 560896 to 577280 blocks
[ 40.657888] EXT4-fs (mmcblk0p2): resized filesystem to 577280
[ 41.744530] EXT4-fs (mmcblk0p2): resizing filesystem from 577280 to 593664 blocks
[ 41.760761] EXT4-fs (mmcblk0p2): resized filesystem to 593664
[ 42.854319] EXT4-fs (mmcblk0p2): resizing filesystem from 593664 to 610048 blocks
[ 42.869742] EXT4-fs (mmcblk0p2): resized filesystem to 610048
[ 43.949278] EXT4-fs (mmcblk0p2): resizing filesystem from 610048 to 626432 blocks
[ 43.964619] EXT4-fs (mmcblk0p2): resized filesystem to 626432
[ 45.053625] EXT4-fs (mmcblk0p2): resizing filesystem from 626432 to 642816 blocks
[ 45.069006] EXT4-fs (mmcblk0p2): resized filesystem to 642816
[ 46.154102] EXT4-fs (mmcblk0p2): resizing filesystem from 642816 to 659200 blocks
[ 46.169951] EXT4-fs (mmcblk0p2): resized filesystem to 659200
[ 47.254277] EXT4-fs (mmcblk0p2): resizing filesystem from 659200 to 675584 blocks
[ 47.273518] EXT4-fs (mmcblk0p2): resized filesystem to 675584
[ 48.353883] EXT4-fs (mmcblk0p2): resizing filesystem from 675584 to 691968 blocks
[ 48.369395] EXT4-fs (mmcblk0p2): resized filesystem to 691968
[ 49.456269] EXT4-fs (mmcblk0p2): resizing filesystem from 691968 to 708352 blocks
[ 49.471729] EXT4-fs (mmcblk0p2): resized filesystem to 708352
[ 50.558482] EXT4-fs (mmcblk0p2): resizing filesystem from 708352 to 724736 blocks
[ 50.583534] EXT4-fs (mmcblk0p2): resized filesystem to 724736
[ 51.669322] EXT4-fs (mmcblk0p2): resizing filesystem from 724736 to 741120 blocks
[ 51.684804] EXT4-fs (mmcblk0p2): resized filesystem to 741120
[ 52.761934] EXT4-fs (mmcblk0p2): resizing filesystem from 741120 to 757504 blocks
[ 52.783553] EXT4-fs (mmcblk0p2): resized filesystem to 757504
[ 53.867168] EXT4-fs (mmcblk0p2): resizing filesystem from 757504 to 773888 blocks
[ 53.882655] EXT4-fs (mmcblk0p2): resized filesystem to 773888
[ 54.962514] EXT4-fs (mmcblk0p2): resizing filesystem from 773888 to 790272 blocks
[ 54.983736] EXT4-fs (mmcblk0p2): resized filesystem to 790272
[ 56.067272] EXT4-fs (mmcblk0p2): resizing filesystem from 790272 to 806656 blocks
[ 56.083493] EXT4-fs (mmcblk0p2): resized filesystem to 806656
[ 57.170464] EXT4-fs (mmcblk0p2): resizing filesystem from 806656 to 823040 blocks
[ 57.203891] EXT4-fs (mmcblk0p2): resized filesystem to 823040
[ 58.319668] EXT4-fs (mmcblk0p2): resizing filesystem from 823040 to 839424 blocks
[ 58.343605] EXT4-fs (mmcblk0p2): resized filesystem to 839424
[ 59.418883] EXT4-fs (mmcblk0p2): resizing filesystem from 839424 to 855808 blocks
[ 59.443522] EXT4-fs (mmcblk0p2): resized filesystem to 855808
[ 60.562296] EXT4-fs (mmcblk0p2): resizing filesystem from 855808 to 872192 blocks
[ 60.577176] EXT4-fs (mmcblk0p2): resized filesystem to 872192
[ 61.642605] EXT4-fs (mmcblk0p2): resizing filesystem from 872192 to 885760 blocks
[ 61.682501] EXT4-fs (mmcblk0p2): resized filesystem to 885760
.---O---.
| | .-. o o
apalis-imx6 login: root
root@apalis-imx6:~#
root@apalis-imx6:~#
root@apalis-imx6:~#
root@apalis-imx6:~# Qt5_CinematicExperience -platform eglfs
QEglFSVivIntegration will set environment variable FB_MULTI_BUFFER=2 to enable double buffering and vsync.
If this is not desired, you can override this via: export QT_EGLFS_IMX6_NO_FB_MULTI_BUFFER=1
[ 164.237055] mxc_sdc_fb fb@0: 1280x320 h_sync,r,l: 10,72,20 v_sync,l,u: 10,20,70 pixclock=36001000 Hz
Unable to query physical screen size, defaulting to 100 dpi.
To override, set QT_QPA_EGLFS_PHYSICAL_WIDTH and QT_QPA_EGLFS_PHYSICAL_HEIGHT (in millimeters).
libpng warning: iCCP: known incorrect sRGB profile
EGL Error : Could not create the egl surface: error = 0x300b
Aborted (core dumped)
root@apalis-imx6:~#
The error is with LinuxImageV2.8 and the above local.conf reproducable every time.
How can I fix it ? What is my problem ?
Do you have a local.conf that is tested with QT eglfs ?
The LinuxImageV2.7 does not have that problem.
Please help me.
