Can Colibri iMX6 SPI ports operate at up to 52 Mbps ?
There is a description of “30 Mbps” in the Colibri iMX6 Datasheet,
but There is a description of “52 Mbps (50Mbps)” in the freescale documentation and toradex-linux device tree.
(1)Colibri iMX6 Datasheet
5.12 SPI
The SPI ports operate at up to 30 Mbps …
(2)i.MX 6Solo/6DualLite Applications Processors for Industrial Products
http://cache.nxp.com/files/32bit/doc/data_sheet/IMX6SDLIEC.pdf?fpsp=1&WT_TYPE=Data%20Sheets&WT_VENDOR=FREESCALE&WT_FILE_FORMAT=pdf&WT_ASSET=Documentation&fileExt=.pdf
Table 2. i.MX 6Solo/6DualLite Modules List (continued)
Full-duplex enhanced Synchronous Serial Interface, with data rate up to 52 Mbit/s.
(3)device tree
linux-toradex/arch/arm/boot/dts/imx6dl-colibri-eval-v3.dts
/* Colibri SPI */
&ecspi4 {
status = “okay”;
spidev0: spidev@1 {
compatible = "spidev";
reg = <0>;
spi-max-frequency = <50000000>;
