> abc@ubuntu:~/oe-core$ bitbake -k angstrom-qt-x11-image
Loading cache: 100% |############################################| Time: 0:00:07
Loaded 3479 entries from dependency cache.
WARNING: No recipes available for:
/home/abc/oe-core/build/../layers/meta-freescale/dynamic-layers/browser-layer/recipes-browser/chromium/chromium-wayland_48.0.2548.0.bbappend
/home/abc/oe-core/build/../layers/meta-freescale/dynamic-layers/browser-layer/recipes-browser/chromium/chromium_52.0.2743.76.bbappend
/home/abc/oe-core/build/../layers/meta-jetson-tk1/recipes-graphics/mesa/mesa_11.1.1.bbappend
/home/abc/oe-core/build/../layers/meta-angstrom/recipes-tweaks/opkg/opkg_0.3.4.bbappend
/home/abc/oe-core/build/../layers/meta-toradex-demos/recipes-support/icu/icu_57%.bbappend
/home/abc/oe-core/build/../layers/meta-toradex-demos/recipes-support/opencv/opencv_2.4.bbappend
Build Configuration:
BB_VERSION = "1.36.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "ubuntu-17.10"
TARGET_SYS = "arm-angstrom-linux-gnueabi"
MACHINE = "colibri-t20"
DISTRO = "angstrom"
DISTRO_VERSION = "v2017.12"
TUNE_FEATURES = "arm armv7a vfp thumb callconvention-hard"
TARGET_FPU = "hard"
meta-angstrom = "HEAD:2a246b9f26126a662caef79a99845ff8379145b9"
meta-toradex-nxp = "HEAD:53fdf58e0a31c94ef446fe7c9e20585dad763099"
meta-freescale = "HEAD:bf7fd9cfe0788fe2f819a4ae2cc7db8327fe161a"
meta-freescale-3rdparty = "HEAD:37c79046d13d10ab16561dddc764c0164ee5deaa"
meta-toradex-tegra = "HEAD:4931a667e17a72819331265ca8b3b0f176ef6293"
meta-jetson-tk1 = "HEAD:e8b87fe8da7c6fcffa37ab245f50082953cc1ee1"
meta-toradex-bsp-common = "HEAD:eb87aec937ab520da8162c89e69d33faf9bc29a2"
meta-snappy = "HEAD:a0432dcff49e35af9175c5bdd57d6b5871062ecf"
meta-oe
meta-filesystems
meta-gnome
meta-xfce
meta-initramfs
meta-networking
meta-multimedia
meta-python = "HEAD:6e3fc5b8d904d06e3aa77e9ec9968ab37a798188"
meta-lxde = "HEAD:dbcbbfd9539a9a017bb6c9b7fd67c3ca22c4cacf"
meta-browser = "HEAD:8cc24caa56f254e09ccb2311b59d054d1f016014"
meta-qt4 = "HEAD:f313dbee2ac3d5fcc9801407947d3cb6cfb90b5d"
meta-qt5 = "HEAD:d87335a50a9dd35d890786edbd79b8953fdaa11a"
meta-freescale-distro = "HEAD:3f958b6a9a4c4120f241e431fec8e5ba616fcc73"
meta-toradex-demos = "HEAD:51cb154f4219a918590994bcbe0e14f9545120cc"
meta = "HEAD:39fc1150e74173fc6d73c464c141dba0b7ac2930"
Initialising tasks: 100% |#######################################| Time: 0:00:31
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: mtd-utils-native-2.0.0-r0 do_compile: oe_runmake failed
ERROR: mtd-utils-native-2.0.0-r0 do_compile: Function failed: do_compile (log file is located at /home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/mtd-utils-native/2.0.0-r0/temp/log.do_compile.38792)
ERROR: Logfile of failure stored in: /home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/mtd-utils-native/2.0.0-r0/temp/log.do_compile.38792
Log data follows:
| DEBUG: Executing shell function do_compile
| NOTE: make CC=gcc RANLIB=ranlib AR=ar CFLAGS=-isystem/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/mtd-utils-native/2.0.0-r0/recipe-sysroot-native/usr/include -O2 -pipe -I/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/mtd-utils-native/2.0.0-r0/git//include -DWITHOUT_XATTR -m32 BUILDDIR=/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/mtd-utils-native/2.0.0-r0/git/
| gcc -DHAVE_CONFIG_H -I. -I../git -I./include -D_GNU_SOURCE -I../git/include -DWITHOUT_XATTR -DHAVE_EXECINFO -isystem/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/mtd-utils-native/2.0.0-r0/recipe-sysroot-native/usr/include -isystem/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/mtd-utils-native/2.0.0-r0/recipe-sysroot-native/usr/include -O2 -pipe -I/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/mtd-utils-native/2.0.0-r0/git//include -DWITHOUT_XATTR -m32 -c -o lib/libmtd.o ../git/lib/libmtd.c
| In file included from /usr/include/bits/errno.h:26:0,
| from /usr/include/errno.h:28,
| from ../git/lib/libmtd.c:27:
| /usr/include/linux/errno.h:1:10: fatal error: asm/errno.h: No such file or directory
| #include
| compilation terminated.
| ERROR: oe_runmake failed
| Makefile:2610: recipe for target 'lib/libmtd.o' failed
| make: *** [lib/libmtd.o] Error 1
| WARNING: /home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/mtd-utils-native/2.0.0-r0/temp/run.do_compile.38792:1 exit 1 from 'exit 1'
| ERROR: Function failed: do_compile (log file is located at /home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/mtd-utils-native/2.0.0-r0/temp/log.do_compile.38792)
ERROR: Task (virtual:native:/home/abc/oe-core/build/../layers/openembedded-core/meta/recipes-devtools/mtd/mtd-utils_git.bb:do_compile) failed with exit code '1'
ERROR: cbootimage-native-1.7-r0 do_compile: oe_runmake failed
ERROR: cbootimage-native-1.7-r0 do_compile: Function failed: do_compile (log file is located at /home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/cbootimage-native/1.7-r0/temp/log.do_compile.38793)
ERROR: Logfile of failure stored in: /home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/cbootimage-native/1.7-r0/temp/log.do_compile.38793
Log data follows:
| NOTE: make -j 4 CC=gcc RANLIB=ranlib AR=ar CFLAGS=-isystem/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/cbootimage-native/1.7-r0/recipe-sysroot-native/usr/include -O2 -pipe -I/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/cbootimage-native/1.7-r0/git/include -m32 BUILDDIR=/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/cbootimage-native/1.7-r0/git
| make all-recursive
| make[1]: Entering directory '/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/cbootimage-native/1.7-r0/build'
| Making all in src
| make[2]: Entering directory '/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/cbootimage-native/1.7-r0/build/src'
| gcc -DHAVE_CONFIG_H -I. -I../../git/src -I.. -isystem/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/cbootimage-native/1.7-r0/recipe-sysroot-native/usr/include -Wall -std=c99 -isystem/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/cbootimage-native/1.7-r0/recipe-sysroot-native/usr/include -O2 -pipe -I/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/cbootimage-native/1.7-r0/git/include -m32 -c -o cbootimage.o ../../git/src/cbootimage.c
| gcc -DHAVE_CONFIG_H -I. -I../../git/src -I.. -isystem/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/cbootimage-native/1.7-r0/recipe-sysroot-native/usr/include -Wall -std=c99 -isystem/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/cbootimage-native/1.7-r0/recipe-sysroot-native/usr/include -O2 -pipe -I/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/cbootimage-native/1.7-r0/git/include -m32 -c -o data_layout.o ../../git/src/data_layout.c
| gcc -DHAVE_CONFIG_H -I. -I../../git/src -I.. -isystem/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/cbootimage-native/1.7-r0/recipe-sysroot-native/usr/include -Wall -std=c99 -isystem/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/cbootimage-native/1.7-r0/recipe-sysroot-native/usr/include -O2 -pipe -I/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/cbootimage-native/1.7-r0/git/include -m32 -c -o set.o ../../git/src/set.c
| gcc -DHAVE_CONFIG_H -I. -I../../git/src -I.. -isystem/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/cbootimage-native/1.7-r0/recipe-sysroot-native/usr/include -Wall -std=c99 -isystem/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/cbootimage-native/1.7-r0/recipe-sysroot-native/usr/include -O2 -pipe -I/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/cbootimage-native/1.7-r0/git/include -m32 -c -o crypto.o ../../git/src/crypto.c
| from ../../git/src/cbootimage.h:31,
| from ../../git/src/cbootimage.c:25:
| #include
| Makefile:567: recipe for target 'cbootimage.o' failed
| make[2]: *** [cbootimage.o] Error 1
| make[2]: *** Waiting for unfinished jobs....
| from ../../git/src/set.h:27,
| from ../../git/src/set.c:24:
| #include
| Makefile:567: recipe for target 'set.o' failed
| make[2]: *** [set.o] Error 1
| from ../../git/src/crypto.h:27,
| from ../../git/src/crypto.c:23:
| #include
| Makefile:567: recipe for target 'crypto.o' failed
| make[2]: *** [crypto.o] Error 1
| from ../../git/src/data_layout.h:27,
| from ../../git/src/data_layout.c:25:
| #include
| Makefile:567: recipe for target 'data_layout.o' failed
| make[2]: *** [data_layout.o] Error 1
| make[2]: Leaving directory '/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/cbootimage-native/1.7-r0/build/src'
| Makefile:351: recipe for target 'all-recursive' failed
| make[1]: *** [all-recursive] Error 1
| make[1]: Leaving directory '/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/cbootimage-native/1.7-r0/build'
| Makefile:292: recipe for target 'all' failed
| make: *** [all] Error 2
| WARNING: /home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/cbootimage-native/1.7-r0/temp/run.do_compile.38793:1 exit 1 from 'exit 1'
| ERROR: Function failed: do_compile (log file is located at /home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/cbootimage-native/1.7-r0/temp/log.do_compile.38793)
ERROR: Task (virtual:native:/home/abc/oe-core/build/../layers/meta-toradex-tegra/recipes-bsp/cbootimage/cbootimage.bb:do_compile) failed with exit code '1'
ERROR: libcryptopp-native-5.6.4-r1 do_compile: oe_runmake failed
ERROR: libcryptopp-native-5.6.4-r1 do_compile: Function failed: do_compile (log file is located at /home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/libcryptopp-native/5.6.4-r1/temp/log.do_compile.38791)
ERROR: Logfile of failure stored in: /home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/libcryptopp-native/5.6.4-r1/temp/log.do_compile.38791
Log data follows:
| NOTE: make -j 4 CC=gcc -m32 CXX=g++ -m32 all
| g++ -m32 -isystem/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/libcryptopp-native/5.6.4-r1/recipe-sysroot-native/usr/include -O2 -pipe -DNDEBUG -fPIC -c cryptlib.cpp
| g++ -m32 -isystem/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/libcryptopp-native/5.6.4-r1/recipe-sysroot-native/usr/include -O2 -pipe -DNDEBUG -fPIC -c cpu.cpp
| g++ -m32 -isystem/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/libcryptopp-native/5.6.4-r1/recipe-sysroot-native/usr/include -O2 -pipe -DNDEBUG -fPIC -c integer.cpp
| g++ -m32 -isystem/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/libcryptopp-native/5.6.4-r1/recipe-sysroot-native/usr/include -O2 -pipe -DNDEBUG -fPIC -c dh.cpp
| from /usr/include/c++/7/cerrno:42,
| from /usr/include/c++/7/ext/string_conversions.h:44,
| from /usr/include/c++/7/bits/basic_string.h:6349,
| from /usr/include/c++/7/string:52,
| from stdcpp.h:9,
| from cryptlib.h:87,
| from cryptlib.cpp:18:
| #include
| GNUmakefile:763: recipe for target 'cryptlib.o' failed
| make: *** [cryptlib.o] Error 1
| make: *** Waiting for unfinished jobs....
| from stdcpp.h:9,
| from cryptlib.h:87,
| from integer.h:15,
| from integer.cpp:18:
| #include
| from stdcpp.h:9,
| from cryptlib.h:87,
| from dh.h:9,
| from dh.cpp:7:
| #include
| GNUmakefile:763: recipe for target 'integer.o' failed
| make: *** [integer.o] Error 1
| from stdcpp.h:9,
| from cryptlib.h:87,
| from misc.h:22,
| from cpu.cpp:13:
| #include
| GNUmakefile:763: recipe for target 'dh.o' failed
| make: *** [dh.o] Error 1
| GNUmakefile:763: recipe for target 'cpu.o' failed
| make: *** [cpu.o] Error 1
| WARNING: /home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/libcryptopp-native/5.6.4-r1/temp/run.do_compile.38791:1 exit 1 from 'exit 1'
| ERROR: Function failed: do_compile (log file is located at /home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/libcryptopp-native/5.6.4-r1/temp/log.do_compile.38791)
ERROR: Task (virtual:native:/home/abc/oe-core/build/../layers/meta-toradex-tegra/recipes-support/libcryptopp/libcryptopp_5.6.4.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 6899 tasks of which 6896 didn't need to be rerun and 3 failed.
NOTE: Writing buildhistory
Summary: 3 tasks failed:
Summary: There was 1 WARNING message shown.
Summary: There were 6 ERROR messages shown, returning a non-zero exit code.
I have re run the Bitbake and following screen shows up,I think it provided is promising results now.
abc@ubuntu:~/oe-core$ bitbake -k angstrom-qt-x11-imageLoading cache: 100% |############################################| Time: 0:00:03
DISTRO = "angstrom"
TARGET_FPU = "hard"
meta-oe
meta-filesystems
meta-gnome
meta-xfce
meta-initramfs
meta-networking
meta-multimedia
Initialising tasks: 100% |#######################################| Time: 0:00:49
WARNING: angstrom-qt-x11-image-2.8b1-r0 do_rootfs: The license listed SGI was not in the licenses collected for recipe tdx-nv-binaries
WARNING: angstrom-qt-x11-image-2.8b1-r0 do_rootfs: The license listed Khronos was not in the licenses collected for recipe tdx-nv-binaries
NOTE: Tasks Summary: Attempted 6938 tasks of which 6902 didn't need to be rerun and all succeeded.
Summary: There were 7 WARNING messages shown.
Thanks for letting us know. This seems like a successful build.
