How to setup splash screen on LVDS LCD ?
max,
Splash screen is working on VGA.
When i boot with the same kernel in LVDS, it showing blank screen.
How can i enable splash screen in LVDS.
hi siva
can you see the boot process on the lvds screen or is it always blank?
Yes I can see boot process.
After setting up splash screen it is show blank screen after some(seconds) time it directly showing the desktop.
max,
pls ignore this delay.
we have some other work in that time.
We didn’t hit by above issue.
On VGA splash scree image is not showing from left top corner,it shifting to right side.
Please find attached image.
When in connect LVDS LCD it showing black screen.
Can u please suggest on this issue.
Is the resolution in U-boot the same as the resolution of your screen?
no
splash image size is 800600
actual VGA screen resolution is 1152864
no
splash image size is 800*600
actual VGA screen resolution is 1152*864
Hi
I would test the uboot resolution, I would change it to your screen resolution and see if the problem persists
Regards
joao,
i dont want any u-boot splash.
i want splash on LVDS LCD
So it’s the Linux splash?
If it is, is your vidargs variable correct?
yes.
its is linux splash.
i have set below vidargs variable for VGA
setenv vidargs ‘video=mxcfb0:dev=vdac,1024x768M@60,if=RGB565 video=mxcbf1:off video=mxcbf2:off video=mxcbf3:off fbmem=32M’
for LVDS LCD
setenv vidargs ‘video=mxcfb0:dev=ldb,800x600,if=RGB888,video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off fbmem=32M’
need help to solve this
hi siva
which bsp version are you using?
2.7 toradex_4.1-2.0.x-imx
please give me reply ASAP.
Version 2.7
Thanks. Could you provide the datasheet of the lvds screen?
