We’ve been working out some pin assignments on our board and have attempted to use the alternative pin configuration on I2C4 consisting of pins of 162 and 154. Using these pins did not produce outputs on pins 162 and 154. We did attempt to use the default pins and observed outputs on pins 55 and 63 which is correct. In other words, we observed that the assignment to pins 162 and 154 did not take and output was only on 55 and 63.
We are using library version: 2.1b4327-20180226
/// @file I2c_Demo.c
/// @copyright Copyright (c) 2015 Toradex AG
/// $Author: germano.kern $
/// $Rev: 4310 $
/// $Date: 2018-02-06 13:29:45 +0530 (Tue, 06 Feb 2018) $
/// @brief Program to show how to use the I2C library
/// @target Colibri VFxx Modules
/// @test Tested on: VFxx
/// @caveats None
#include <windows.h>
//Uncomment the line below if you want to use TdxAllLibrariesDll.dll
//#define USE_DLL
#include "i2c_imx6.h"
#include "gpio.h"
/// Scan I2C Bus for available devices.
/// @param[in] i2c HANDLE to I2C port, retrieved from I2c_Init()
void i2cScan(HANDLE i2c)
int i, count = 0;
BOOL Success;
Success = I2c_Open(i2c);
if (!Success)
printf("I2c_Open failed. Exit Scan", count);
return;
printf("Scanning i2c bus...\r\n");
for (i = 8; i < 0x78; i++) // First and last 8 addresses are reserved
BYTE tmpBuf;
I2c_SetConfigInt(i2c, TEXT("SlaveAddr"), i, StoreVolatile);
Success = (I2c_Read(i2c, &tmpBuf, 1) == (DWORD)-1) ? FALSE : TRUE;
if (Success)
printf("- 0x%02x \n\r", i);
count++;
//Sleep(1);
I2c_Close(i2c);
printf("\r\n%d device(s) found.\r\n", count);
/// Main function
/// @param[in] instance Handle to program instance
/// @param[in] prevInstance Handle to previous program instance
/// @param[in] cmdLine Command line string pointer
/// @param[in] cmdShow Window state
/// @retval 1 Always returned
int wmain(int argc, wchar_t *argv[])
DWORD i;
DWORD returnValue;
HANDLE i2c = NULL;
BYTE data[8] = {0};
// Initialize I2Cx, without affecting hardware registers
i2c = I2c_Init(L"I2C3");
if (i2c == NULL)
printf("Error in I2c_Init()\r\n");
// ====== BusScan ======
i2cScan(i2c);
// ====== RTC Read and Write Example ======
// Override the default io which is defined by the portName "I2C1"..."I2C4"
// Io configurations need to be done *before* calling I2c_Open() !
{ /* Need to include gpio.h for uIo structure */
uIo ioScl = COLIBRI_PIN(162); /*Colibri Pin 74*/
uIo ioSda = COLIBRI_PIN(154); /*Colibri Pin 50*/
// /* or */
// uIo ioScl;
// uIo ioSda;
// ioScl.GenericDefinition = IOCOLIBRIPIN(74);
// ioSda.GenericDefinition = IOCOLIBRIPIN(50);
returnValue = I2c_SetConfigInt(i2c, L"ioScl", ioScl.GenericDefinition, StoreVolatile);
returnValue = I2c_SetConfigInt(i2c, L"ioSda", ioSda.GenericDefinition, StoreVolatile);
// Open the i2c port
I2c_Open(i2c);
// Change configuration as required
// Instead of calling this function, you can place default values in the registry
// [HKLM\SOFTWARE\Toradex\I2C1]
// BitRateHz = dword:00061a80 ; = decimal 400000
// SlaveAddrSize = dword:00000007 ; = decimal 7
// RegisterAddrSize = dword:00000000 ; = decimal 0
I2c_SetConfigInt(i2c, L"BitRateHz", 100000, StoreVolatile); // Set I2C speed to 400KHz
I2c_SetConfigInt(i2c, L"SlaveAddrSize", 7, StoreVolatile); // Set 7 bit Slave address
I2c_SetConfigInt(i2c, L"RegisterAddrSize", 0, StoreVolatile); // No Register address to send
// Set RTC address into handle, it will be valid for all future Read/Write calls
// 0x68 is the 7 bit address of the RTC present on Colibri Evaluation Board
I2c_SetConfigInt(i2c, L"SlaveAddr", 0x68, StoreVolatile);
// I2C Read
returnValue = I2c_Read(i2c, (DWORD*) data, 8);
printf("\nReading the RTC: %s\r\n", (returnValue == I2C_RW_FAILURE ? "failed." : "successful."));
// I2C Write
for (i = 0; i < 8; i++)
data[i] = 0;
returnValue = I2c_Write(i2c, (DWORD*) data, 8);
printf("\nResetting the RTC: %s\r\n", (returnValue == I2C_RW_FAILURE ? "failed." : "successful."));
// Close and deinit I2C port
I2c_Close(i2c);
I2c_Deinit(i2c);
// Finish demo application
printf("\nPress enter to exit");
fflush(stdin);
getchar();
return(TRUE);
