[Executing SetScene Tasks
ERROR: u-boot-toradex-2016.11+gitAUTOINC+30a1208727-2.8.1 do_deploy_setscene: Error executing a python function in exec_python_func() autogenerated:
The stack trace of python calls that resulted in this exception/failure was:
File: 'exec_python_func() autogenerated', lineno: 2, function: <module>
0001:
*** 0002:do_deploy_setscene(d)
0003:
File: '/home/abc/oe-core/build/../layers/openembedded-core/meta/classes/deploy.bbclass', lineno: 7, function: do_deploy_setscene
0003:do_deploy[sstate-inputdirs] = "${DEPLOYDIR}"
0004:do_deploy[sstate-outputdirs] = "${DEPLOY_DIR_IMAGE}"
0005:
0006:python do_deploy_setscene () {
*** 0007: sstate_setscene(d)
0008:}
0009:addtask do_deploy_setscene
0010:do_deploy[dirs] = "${DEPLOYDIR} ${B}"
0011:do_deploy[stamp-extra-info] = "${MACHINE}"
File: '/home/abc/oe-core/build/../layers/openembedded-core/meta/classes/sstate.bbclass', lineno: 681, function: sstate_setscene
0677: break
0678:
0679:def sstate_setscene(d):
0680: shared_state = sstate_state_fromvars(d)
*** 0681: accelerate = sstate_installpkg(shared_state, d)
0682: if not accelerate:
0683: bb.fatal("No suitable staging package found")
0684:
0685:python sstate_task_prefunc () {
File: '/home/abc/oe-core/build/../layers/openembedded-core/meta/classes/sstate.bbclass', lineno: 328, function: sstate_installpkg
0324: for f in (d.getVar('SSTATEPREINSTFUNCS') or '').split() + ['sstate_unpack_package']:
0325: # All hooks should run in the SSTATE_INSTDIR
0326: bb.build.exec_func(f, d, (sstateinst,))
0327:
*** 0328: return sstate_installpkgdir(ss, d)
0329:
0330:def sstate_installpkgdir(ss, d):
0331: import oe.path
0332: import subprocess
File: '/home/abc/oe-core/build/../layers/openembedded-core/meta/classes/sstate.bbclass', lineno: 351, function: sstate_installpkgdir
0347:
0348: for state in ss['dirs']:
0349: prepdir(state[1])
0350: os.rename(sstateinst + state[0], state[1])
*** 0351: sstate_install(ss, d)
0352:
0353: for plain in ss['plaindirs']:
0354: workdir = d.getVar('WORKDIR')
0355: src = sstateinst + "/" + plain.replace(workdir, '')
File: '/home/abc/oe-core/build/../layers/openembedded-core/meta/classes/sstate.bbclass', lineno: 280, function: sstate_install
0276:
0277: # Run the actual file install
0278: for state in ss['dirs']:
0279: if os.path.exists(state[1]):
*** 0280: oe.path.copyhardlinktree(state[1], state[2])
0281:
0282: for postinst in (d.getVar('SSTATEPOSTINSTFUNCS') or '').split():
0283: # All hooks should run in the SSTATE_INSTDIR
0284: bb.build.exec_func(postinst, d, (sstateinst,))
File: '/home/abc/oe-core/build/../layers/openembedded-core/meta/lib/oe/path.py', lineno: 102, function: copyhardlinktree
0098: if (os.stat(src).st_dev == os.stat(dst).st_dev):
0099: # Need to copy directories only with tar first since cp will error if two
0100: # writers try and create a directory at the same time
0101: cmd = "cd %s; find . -type d -print | tar --xattrs --xattrs-include='*' -cf - -C %s -p --no-recursion --files-from - | tar --xattrs --xattrs-include='*' -xhf - -C %s" % (src, src, dst)
*** 0102: subprocess.check_output(cmd, shell=True, stderr=subprocess.STDOUT)
0103: source = ''
0104: if os.path.isdir(src):
0105: if len(glob.glob('%s/.??*' % src)) > 0:
0106: source = './.??* '
File: '/usr/lib/python3.6/subprocess.py', lineno: 336, function: check_output
0332: # empty string. That is maintained here for backwards compatibility.
0333: kwargs['input'] = '' if kwargs.get('universal_newlines', False) else b''
0334:
0335: return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
*** 0336: **kwargs).stdout
0337:
0338:
0339:class CompletedProcess(object):
0340: """A process that has finished running.
File: '/usr/lib/python3.6/subprocess.py', lineno: 418, function: run
0414: raise
0415: retcode = process.poll()
0416: if check and retcode:
0417: raise CalledProcessError(retcode, process.args,
*** 0418: output=stdout, stderr=stderr)
0419: return CompletedProcess(process.args, retcode, stdout, stderr)
0420:
0421:
0422:def list2cmdline(seq):
Exception: subprocess.CalledProcessError: Command 'cd /home/abc/oe-core/build/tmp-glibc/work/colibri_t20-angstrom-linux-gnueabi/u-boot-toradex/2016.11+gitAUTOINC+30a1208727-2.8.1/deploy-u-boot-toradex; find . -type d -print | tar --xattrs --xattrs-include='*' -cf - -C /home/abc/oe-core/build/tmp-glibc/work/colibri_t20-angstrom-linux-gnueabi/u-boot-toradex/2016.11+gitAUTOINC+30a1208727-2.8.1/deploy-u-boot-toradex -p --no-recursion --files-from - | tar --xattrs --xattrs-include='*' -xhf - -C /home/abc/oe-core/deploy/images/colibri-t20' returned non-zero exit status 2.
Subprocess output:
tar: .: Cannot utime: Operation not permitted
tar: Exiting with failure status due to previous errors
WARNING: Logfile for failed setscene task is /home/abc/oe-core/build/tmp-glibc/work/colibri_t20-angstrom-linux-gnueabi/u-boot-toradex/2016.11+gitAUTOINC+30a1208727-2.8.1/temp/log.do_deploy_setscene.47960
WARNING: Setscene task (/home/abc/oe-core/build/../layers/meta-toradex-tegra/recipes-bsp/u-boot/u-boot-toradex_git.bb:do_deploy_setscene) failed with exit code '1' - real task will be run instead
ERROR: linux-toradex-3.1.10+gitrAUTOINC+8e1745b5e5-2.8.1 do_deploy_setscene: Error executing a python function in exec_python_func() autogenerated:
0001:
0003:
0005:
0008:}
0677: break
0678:
0684:
0327:
0329:
0347:
0352:
0276:
0281:
0103: source = ''
0334:
0337:
0338:
0414: raise
0420:
0421:
Exception: subprocess.CalledProcessError: Command 'cd /home/abc/oe-core/build/tmp-glibc/work/colibri_t20-angstrom-linux-gnueabi/linux-toradex/3.1.10+gitrAUTOINC+8e1745b5e5-2.8.1/deploy-linux-toradex; find . -type d -print | tar --xattrs --xattrs-include='*' -cf - -C /home/abc/oe-core/build/tmp-glibc/work/colibri_t20-angstrom-linux-gnueabi/linux-toradex/3.1.10+gitrAUTOINC+8e1745b5e5-2.8.1/deploy-linux-toradex -p --no-recursion --files-from - | tar --xattrs --xattrs-include='*' -xhf - -C /home/abc/oe-core/deploy/images/colibri-t20' returned non-zero exit status 2.
Subprocess output:
WARNING: Logfile for failed setscene task is /home/abc/oe-core/build/tmp-glibc/work/colibri_t20-angstrom-linux-gnueabi/linux-toradex/3.1.10+gitrAUTOINC+8e1745b5e5-2.8.1/temp/log.do_deploy_setscene.47959
WARNING: Setscene task (/home/abc/oe-core/build/../layers/meta-toradex-tegra/recipes-kernel/linux/linux-toradex_git.bb:do_deploy_setscene) failed with exit code '1' - real task will be run instead
NOTE: Executing RunQueue Tasks
ERROR: u-boot-toradex-2016.11+gitAUTOINC+30a1208727-2.8.1 do_deploy: Error executing a python function in exec_python_func() autogenerated:
0001:
*** 0002:sstate_task_postfunc(d)
0003:
File: '/home/abc/oe-core/build/../layers/openembedded-core/meta/classes/sstate.bbclass', lineno: 706, function: sstate_task_postfunc
0702:
0703: sstateinst = d.getVar("SSTATE_INSTDIR")
0704: d.setVar('SSTATE_FIXMEDIR', shared_state['fixmedir'])
0705:
*** 0706: sstate_installpkgdir(shared_state, d)
0707:
0708: bb.utils.remove(d.getVar("SSTATE_BUILDDIR"), recurse=True)
0709:}
0710:sstate_task_postfunc[dirs] = "${WORKDIR}"
0347:
0352:
0276:
0281:
0103: source = ''
0334:
0337:
0338:
0414: raise
0420:
0421:
Subprocess output:
ERROR: u-boot-toradex-2016.11+gitAUTOINC+30a1208727-2.8.1 do_deploy: Function failed: sstate_task_postfunc
ERROR: Logfile of failure stored in: /home/abc/oe-core/build/tmp-glibc/work/colibri_t20-angstrom-linux-gnueabi/u-boot-toradex/2016.11+gitAUTOINC+30a1208727-2.8.1/temp/log.do_deploy.48169
ERROR: Task (/home/abc/oe-core/build/../layers/meta-toradex-tegra/recipes-bsp/u-boot/u-boot-toradex_git.bb:do_deploy) failed with exit code '1'
ERROR: linux-toradex-3.1.10+gitrAUTOINC+8e1745b5e5-2.8.1 do_deploy: Error executing a python function in exec_python_func() autogenerated:
0001:
0003:
0702:
0705:
0707:
0709:}
0347:
0352:
0276:
0281:
0103: source = ''
0334:
0337:
0338:
0414: raise
0420:
0421:
Subprocess output:
ERROR: linux-toradex-3.1.10+gitrAUTOINC+8e1745b5e5-2.8.1 do_deploy: Function failed: sstate_task_postfunc
ERROR: Logfile of failure stored in: /home/abc/oe-core/build/tmp-glibc/work/colibri_t20-angstrom-linux-gnueabi/linux-toradex/3.1.10+gitrAUTOINC+8e1745b5e5-2.8.1/temp/log.do_deploy.72729
ERROR: Task (/home/abc/oe-core/build/../layers/meta-toradex-tegra/recipes-kernel/linux/linux-toradex_git.bb:do_deploy) failed with exit code '1'
WARNING: angstrom-qt5-x11-image-2.8b1-r0 do_rootfs: The license listed SGI was not in the licenses collected for recipe tdx-nv-binaries
WARNING: angstrom-qt5-x11-image-2.8b1-r0 do_rootfs: The license listed Khronos was not in the licenses collected for recipe tdx-nv-binaries
ERROR: angstrom-qt5-x11-image-2.8b1-r0 do_rootfs: Error executing a python function in exec_python_func() autogenerated:
0001:
*** 0002:write_image_test_data(d)
0003:
File: '/home/abc/oe-core/build/../layers/openembedded-core/meta/classes/rootfs-postcommands.bbclass', lineno: 303, function: write_image_test_data
0299: testdata_link = "%s/%s.testdata.json" % (d.getVar('DEPLOY_DIR_IMAGE'), d.getVar('IMAGE_LINK_NAME'))
0300:
0301: bb.utils.mkdirhier(os.path.dirname(testdata))
0302: searchString = "%s/"%(d.getVar("TOPDIR")).replace("//","/")
*** 0303: export2json(d, testdata,searchString=searchString,replaceString="")
0304:
0305: if testdata_link != testdata:
0306: if os.path.lexists(testdata_link):
0307: os.remove(testdata_link)
File: '/home/abc/oe-core/build/../layers/openembedded-core/meta/lib/oe/data.py', lineno: 46, function: export2json
0042: data2export[key] = ''
0043: except AttributeError:
0044: pass
0045:
*** 0046: with open(json_file, "w") as f:
0047: json.dump(data2export, f, skipkeys=True, indent=4, sort_keys=True)
Exception: PermissionError: [Errno 13] Permission denied: '/home/abc/oe-core/build/../deploy/images/colibri-t20/Colibri-T20_Qt5-X11-Image.testdata.json'
ERROR: angstrom-qt5-x11-image-2.8b1-r0 do_rootfs: Function failed: write_image_test_data
ERROR: Logfile of failure stored in: /home/abc/oe-core/build/tmp-glibc/work/colibri_t20-angstrom-linux-gnueabi/angstrom-qt5-x11-image/2.8b1-r0/temp/log.do_rootfs.72730
ERROR: Task (/home/abc/oe-core/build/../layers/meta-toradex-demos/recipes-images/images/angstrom-qt5-x11-image.bb:do_rootfs) failed with exit code '1']
log.do_rootfs.72730
Linux Toradex do_deploy
