I have Setup the VMWare With Ubuntu 16.04 LTS and stup the wohole environment according to the specified procedure provided by toradex,But I am unable to get the Angstrom Qt5 x11 Image Build for the same. Following are the output from the terminal,I have even used the Cleanall /clean Commands but these errors doesnt go away.
abc@ubuntu:~/oe-core/build$ bitbake -k angstrom-qt5-x11-image
Loading cache: 100% |############################################| Time: 0:00:25
Loaded 3479 entries from dependency cache.
WARNING: No recipes available for:
/home/abc/oe-core/build/../layers/meta-freescale/dynamic-layers/browser-layer/recipes-browser/chromium/chromium-wayland_48.0.2548.0.bbappend
/home/abc/oe-core/build/../layers/meta-freescale/dynamic-layers/browser-layer/recipes-browser/chromium/chromium_52.0.2743.76.bbappend
/home/abc/oe-core/build/../layers/meta-jetson-tk1/recipes-graphics/mesa/mesa_11.1.1.bbappend
/home/abc/oe-core/build/../layers/meta-angstrom/recipes-tweaks/opkg/opkg_0.3.4.bbappend
/home/abc/oe-core/build/../layers/meta-toradex-demos/recipes-support/icu/icu_57%.bbappend
/home/abc/oe-core/build/../layers/meta-toradex-demos/recipes-support/opencv/opencv_2.4.bbappend
Build Configuration:
BB_VERSION = "1.36.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "ubuntu-16.04"
TARGET_SYS = "arm-angstrom-linux-gnueabi"
MACHINE = "colibri-t20"
DISTRO = "angstrom"
DISTRO_VERSION = "v2017.12"
TUNE_FEATURES = "arm armv7a vfp thumb callconvention-hard"
TARGET_FPU = "hard"
meta-angstrom = "HEAD:2a246b9f26126a662caef79a99845ff8379145b9"
meta-toradex-nxp = "HEAD:53fdf58e0a31c94ef446fe7c9e20585dad763099"
meta-freescale = "HEAD:bf7fd9cfe0788fe2f819a4ae2cc7db8327fe161a"
meta-freescale-3rdparty = "HEAD:37c79046d13d10ab16561dddc764c0164ee5deaa"
meta-toradex-tegra = "HEAD:4931a667e17a72819331265ca8b3b0f176ef6293"
meta-jetson-tk1 = "HEAD:e8b87fe8da7c6fcffa37ab245f50082953cc1ee1"
meta-toradex-bsp-common = "HEAD:eb87aec937ab520da8162c89e69d33faf9bc29a2"
meta-snappy = "HEAD:a0432dcff49e35af9175c5bdd57d6b5871062ecf"
meta-oe
meta-filesystems
meta-gnome
meta-xfce
meta-initramfs
meta-networking
meta-multimedia
meta-python = "HEAD:6e3fc5b8d904d06e3aa77e9ec9968ab37a798188"
meta-lxde = "HEAD:dbcbbfd9539a9a017bb6c9b7fd67c3ca22c4cacf"
meta-browser = "HEAD:8cc24caa56f254e09ccb2311b59d054d1f016014"
meta-qt4 = "HEAD:f313dbee2ac3d5fcc9801407947d3cb6cfb90b5d"
meta-qt5 = "HEAD:d87335a50a9dd35d890786edbd79b8953fdaa11a"
meta-freescale-distro = "HEAD:3f958b6a9a4c4120f241e431fec8e5ba616fcc73"
meta-toradex-demos = "HEAD:51cb154f4219a918590994bcbe0e14f9545120cc"
meta = "HEAD:39fc1150e74173fc6d73c464c141dba0b7ac2930"
Initialising tasks: 100% |#######################################| Time: 0:03:22
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: gobject-introspection-1.52.1-r0 do_compile: oe_runmake failed
ERROR: gobject-introspection-1.52.1-r0 do_compile: Function failed: do_compile (log file is located at /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/temp/log.do_compile.3541)
ERROR: Logfile of failure stored in: /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/temp/log.do_compile.3541
Log data follows:
| DEBUG: SITE files ['endian-little', 'bit-32', 'arm-common', 'arm-32', 'common-linux', 'common-glibc', 'arm-linux', 'arm-linux-gnueabi', 'common']
| DEBUG: Executing shell function do_compile
| NOTE: make
| make all-recursive
| make[1]: Entering directory '/home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/build'
| Making all in .
| make[2]: Entering directory '/home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/build'
| CPPFLAGS="" CFLAGS="-fno-strict-aliasing -Wsign-compare -Wcast-align -Wpointer-arith -Wnested-externs -Wmissing-prototypes -Wmissing-declarations -Wchar-subscripts -Wall -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0=/usr/src/debug/gobject-introspection/1.52.1-r0 -fdebug-prefix-map=/home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot=" LDFLAGS="-Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed" CC="arm-angstrom-linux-gnueabi-gcc -mfpu=vfpv3-d16 -march=armv7-a -mthumb -mfpu=vfp -mfloat-abi=hard --sysroot=/home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot" PKG_CONFIG="/home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot-native/usr/bin/pkg-config" DLLTOOL="false" env PATH="/home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot-native/usr/bin/python3-native:/home/abc/oe-core/layers/openembedded-core/scripts:/home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi:/home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/bin/crossscripts:/home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot-native/usr/sbin:/home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot-native/usr/bin:/home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot-native/sbin:/home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot-native/bin:/home/abc/oe-core/layers/openembedded-core/bitbake/bin:/home/abc/oe-core/build/tmp-glibc/hosttools" LPATH=.libs CC="arm-angstrom-linux-gnueabi-gcc -mfpu=vfpv3-d16 -march=armv7-a -mthumb -mfpu=vfp -mfloat-abi=hard --sysroot=/home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot" PYTHONPATH=.:../gobject-introspection-1.52.1 UNINSTALLED_INTROSPECTION_BUILDDIR=. g-ir-scanner --verbose --use-binary-wrapper=/home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/build/g-ir-scanner-qemuwrapper --use-ldd-wrapper=/home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/build/g-ir-scanner-lddwrapper -I../gobject-introspection-1.52.1 --add-include-path=../gobject-introspection-1.52.1 --add-include-path=../gobject-introspection-1.52.1/gir --add-include-path=. --add-include-path=. --add-include-path=./gir --namespace=GLib --nsversion=2.0 --libtool="./arm-angstrom-linux-gnueabi-libtool" --pkg=glib-2.0 --library=glib-2.0 --library=gobject-2.0 --external-library --reparse-validate --identifier-prefix=G --symbol-prefix=g --symbol-prefix=glib --c-include="glib.h" --cflags-begin -I/home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0 -I/home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/lib/glib-2.0/include -DGETTEXT_PACKAGE=Dummy -DGLIB_COMPILATION -D__G_I18N_LIB_H__ --cflags-end /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/lib/glib-2.0/include/glibconfig.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gshell.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/giochannel.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gprintf.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gmem.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/genviron.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/ghook.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gvariant.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/garray.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gdatetime.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gmappedfile.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gdir.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gtestutils.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gi18n-lib.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gregex.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gsequence.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gnode.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gprimes.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gstringchunk.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gscanner.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gdataset.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gbase64.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gmacros.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/ghmac.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gslice.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gthread.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gquark.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/ggettext.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gmain.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/ghostutils.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gbytes.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gi18n.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gqueue.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gtimezone.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/glist.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gmessages.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gcharset.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gfileutils.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gdate.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/galloca.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gwin32.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gurifuncs.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gbitlock.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gbookmarkfile.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gstring.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gbacktrace.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gmarkup.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gqsort.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gslist.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gstrfuncs.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gutils.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gconvert.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gpattern.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gtimer.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gthreadpool.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gstdio.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gatomic.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gversion.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gunicode.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/ghash.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gkeyfile.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/goption.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gvarianttype.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gchecksum.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/grand.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gerror.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gasyncqueue.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gpoll.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gtypes.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/guuid.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gtree.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gtrashstack.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gspawn.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib/gversionmacros.h /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/gobject/glib-types.h ../gobject-introspection-1.52.1/gir/glib-2.0.c /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot/usr/include/glib-2.0/glib-unix.h g-ir-scanner g-ir-compiler --output GLib-2.0.gir
| g-ir-scanner: link: ./arm-angstrom-linux-gnueabi-libtool --mode=link --tag=CC arm-angstrom-linux-gnueabi-gcc -mfpu=vfpv3-d16 -march=armv7-a -mthumb -mfpu=vfp -mfloat-abi=hard --sysroot=/home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot -o /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/build/tmp-introspectnxq1l707/GLib-2.0 -export-dynamic -fno-strict-aliasing -Wsign-compare -Wcast-align -Wpointer-arith -Wnested-externs -Wmissing-prototypes -Wmissing-declarations -Wchar-subscripts -Wall -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0=/usr/src/debug/gobject-introspection/1.52.1-r0 -fdebug-prefix-map=/home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot= tmp-introspectnxq1l707/home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/build/tmp-introspectnxq1l707/GLib-2.0.o -lgio-2.0 -lgobject-2.0 -Wl,--export-dynamic -lgmodule-2.0 -pthread -lglib-2.0 -lglib-2.0 -lgobject-2.0 -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed
| arm-angstrom-linux-gnueabi-libtool: link: arm-angstrom-linux-gnueabi-gcc -mfpu=vfpv3-d16 -march=armv7-a -mthumb -mfpu=vfp -mfloat-abi=hard --sysroot=/home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot -o /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/build/tmp-introspectnxq1l707/GLib-2.0 -fno-strict-aliasing -Wsign-compare -Wcast-align -Wpointer-arith -Wnested-externs -Wmissing-prototypes -Wmissing-declarations -Wchar-subscripts -Wall -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0=/usr/src/debug/gobject-introspection/1.52.1-r0 -fdebug-prefix-map=/home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/recipe-sysroot= tmp-introspectnxq1l707/home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/build/tmp-introspectnxq1l707/GLib-2.0.o -Wl,--export-dynamic -pthread -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -Wl,--export-dynamic -lgio-2.0 -lgmodule-2.0 -lglib-2.0 -lgobject-2.0 -pthread
| /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/build/g-ir-scanner-qemuwrapper: 6: /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/build/g-ir-scanner-qemuwrapper: qemu-arm: not found
| If the above error message is about missing .so libraries, then setting up GIR_EXTRA_LIBS_PATH in the recipe should help.
| (typically like this: GIR_EXTRA_LIBS_PATH="${B}/something/.libs" )
| Command '['/home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/build/g-ir-scanner-qemuwrapper', '/home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/build/tmp-introspectnxq1l707/GLib-2.0', '--introspect-dump=/home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/build/tmp-introspectnxq1l707/functions.txt,/home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/build/tmp-introspectnxq1l707/dump.xml']' returned non-zero exit status 1
| Makefile:3563: recipe for target 'GLib-2.0.gir' failed
| make[2]: *** [GLib-2.0.gir] Error 1
| make[2]: Leaving directory '/home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/build'
| Makefile:2850: recipe for target 'all-recursive' failed
| make[1]: *** [all-recursive] Error 1
| make[1]: Leaving directory '/home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/build'
| Makefile:1610: recipe for target 'all' failed
| make: *** [all] Error 2
| ERROR: oe_runmake failed
| ERROR: Function failed: do_compile (log file is located at /home/abc/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gobject-introspection/1.52.1-r0/temp/log.do_compile.3541)
ERROR: Task (/home/abc/oe-core/build/../layers/openembedded-core/meta/recipes-gnome/gobject-introspection/gobject-introspection_1.52.1.bb:do_compile) failed with exit code '1'
ERROR: nativesdk-cmake-3.8.2-r0 do_compile: Function failed: do_compile (log file is located at /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/temp/log.do_compile.3747)
ERROR: Logfile of failure stored in: /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/temp/log.do_compile.3747
Log data follows:
| NOTE: VERBOSE=1 cmake --build /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build --
| /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/recipe-sysroot-native/usr/bin/cmake -H/home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/cmake-3.8.2 -B/home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build --check-build-system CMakeFiles/Makefile.cmake 0
| /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/recipe-sysroot-native/usr/bin/cmake -E cmake_progress_start /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/CMakeFiles /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/CMakeFiles/progress.marks
| make -f CMakeFiles/Makefile2 all
| make[1]: Entering directory '/home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build'
| make -f Source/kwsys/CMakeFiles/cmsys_c.dir/build.make Source/kwsys/CMakeFiles/cmsys_c.dir/depend
| make[2]: Entering directory '/home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build'
| cd /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build && /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/recipe-sysroot-native/usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/cmake-3.8.2 /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/cmake-3.8.2/Source/kwsys /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/Source/kwsys /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/Source/kwsys/CMakeFiles/cmsys_c.dir/DependInfo.cmake --color=
| make[2]: Leaving directory '/home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build'
| make -f Source/kwsys/CMakeFiles/cmsys_c.dir/build.make Source/kwsys/CMakeFiles/cmsys_c.dir/build
| make[2]: Nothing to be done for 'Source/kwsys/CMakeFiles/cmsys_c.dir/build'.
| [ 2%] Built target cmsys_c
| make -f Source/kwsys/CMakeFiles/cmsysTestsC.dir/build.make Source/kwsys/CMakeFiles/cmsysTestsC.dir/depend
| cd /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build && /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/recipe-sysroot-native/usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/cmake-3.8.2 /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/cmake-3.8.2/Source/kwsys /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/Source/kwsys /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/Source/kwsys/CMakeFiles/cmsysTestsC.dir/DependInfo.cmake --color=
| make -f Source/kwsys/CMakeFiles/cmsysTestsC.dir/build.make Source/kwsys/CMakeFiles/cmsysTestsC.dir/build
| make[2]: Nothing to be done for 'Source/kwsys/CMakeFiles/cmsysTestsC.dir/build'.
| [ 3%] Built target cmsysTestsC
| make -f Source/kwsys/CMakeFiles/cmsys.dir/build.make Source/kwsys/CMakeFiles/cmsys.dir/depend
| cd /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build && /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/recipe-sysroot-native/usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/cmake-3.8.2 /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/cmake-3.8.2/Source/kwsys /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/Source/kwsys /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/Source/kwsys/CMakeFiles/cmsys.dir/DependInfo.cmake --color=
| make -f Source/kwsys/CMakeFiles/cmsys.dir/build.make Source/kwsys/CMakeFiles/cmsys.dir/build
| make[2]: Nothing to be done for 'Source/kwsys/CMakeFiles/cmsys.dir/build'.
| [ 7%] Built target cmsys
| make -f Source/kwsys/CMakeFiles/testConsoleBufChild.dir/build.make Source/kwsys/CMakeFiles/testConsoleBufChild.dir/depend
| cd /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build && /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/recipe-sysroot-native/usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/cmake-3.8.2 /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/cmake-3.8.2/Source/kwsys /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/Source/kwsys /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/Source/kwsys/CMakeFiles/testConsoleBufChild.dir/DependInfo.cmake --color=
| make -f Source/kwsys/CMakeFiles/testConsoleBufChild.dir/build.make Source/kwsys/CMakeFiles/testConsoleBufChild.dir/build
| make[2]: Nothing to be done for 'Source/kwsys/CMakeFiles/testConsoleBufChild.dir/build'.
| [ 8%] Built target testConsoleBufChild
| make -f Source/kwsys/CMakeFiles/cmsysTestDynload.dir/build.make Source/kwsys/CMakeFiles/cmsysTestDynload.dir/depend
| cd /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build && /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/recipe-sysroot-native/usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/cmake-3.8.2 /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/cmake-3.8.2/Source/kwsys /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/Source/kwsys /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/Source/kwsys/CMakeFiles/cmsysTestDynload.dir/DependInfo.cmake --color=
| make -f Source/kwsys/CMakeFiles/cmsysTestDynload.dir/build.make Source/kwsys/CMakeFiles/cmsysTestDynload.dir/build
| make[2]: Nothing to be done for 'Source/kwsys/CMakeFiles/cmsysTestDynload.dir/build'.
| [ 8%] Built target cmsysTestDynload
| make -f Source/kwsys/CMakeFiles/cmsysTestProcess.dir/build.make Source/kwsys/CMakeFiles/cmsysTestProcess.dir/depend
| cd /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build && /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/recipe-sysroot-native/usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/cmake-3.8.2 /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/cmake-3.8.2/Source/kwsys /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/Source/kwsys /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/Source/kwsys/CMakeFiles/cmsysTestProcess.dir/DependInfo.cmake --color=
| make -f Source/kwsys/CMakeFiles/cmsysTestProcess.dir/build.make Source/kwsys/CMakeFiles/cmsysTestProcess.dir/build
| make[2]: Nothing to be done for 'Source/kwsys/CMakeFiles/cmsysTestProcess.dir/build'.
| [ 8%] Built target cmsysTestProcess
| make -f Source/kwsys/CMakeFiles/cmsysTestsCxx.dir/build.make Source/kwsys/CMakeFiles/cmsysTestsCxx.dir/depend
| cd /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build && /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/recipe-sysroot-native/usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/cmake-3.8.2 /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/cmake-3.8.2/Source/kwsys /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/Source/kwsys /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/Source/kwsys/CMakeFiles/cmsysTestsCxx.dir/DependInfo.cmake --color=
| make -f Source/kwsys/CMakeFiles/cmsysTestsCxx.dir/build.make Source/kwsys/CMakeFiles/cmsysTestsCxx.dir/build
| make[2]: Nothing to be done for 'Source/kwsys/CMakeFiles/cmsysTestsCxx.dir/build'.
| [ 10%] Built target cmsysTestsCxx
| make -f Source/kwsys/CMakeFiles/cmsysTestSharedForward.dir/build.make Source/kwsys/CMakeFiles/cmsysTestSharedForward.dir/depend
| cd /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build && /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/recipe-sysroot-native/usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/cmake-3.8.2 /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/cmake-3.8.2/Source/kwsys /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/Source/kwsys /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/Source/kwsys/CMakeFiles/cmsysTestSharedForward.dir/DependInfo.cmake --color=
| make -f Source/kwsys/CMakeFiles/cmsysTestSharedForward.dir/build.make Source/kwsys/CMakeFiles/cmsysTestSharedForward.dir/build
| make[2]: Nothing to be done for 'Source/kwsys/CMakeFiles/cmsysTestSharedForward.dir/build'.
| [ 11%] Built target cmsysTestSharedForward
| make -f Utilities/KWIML/test/CMakeFiles/kwiml_test.dir/build.make Utilities/KWIML/test/CMakeFiles/kwiml_test.dir/depend
| cd /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build && /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/recipe-sysroot-native/usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/cmake-3.8.2 /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/cmake-3.8.2/Utilities/KWIML/test /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/Utilities/KWIML/test /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/Utilities/KWIML/test/CMakeFiles/kwiml_test.dir/DependInfo.cmake --color=
| make -f Utilities/KWIML/test/CMakeFiles/kwiml_test.dir/build.make Utilities/KWIML/test/CMakeFiles/kwiml_test.dir/build
| make[2]: Nothing to be done for 'Utilities/KWIML/test/CMakeFiles/kwiml_test.dir/build'.
| [ 13%] Built target kwiml_test
| make -f Utilities/cmlibrhash/CMakeFiles/cmlibrhash.dir/build.make Utilities/cmlibrhash/CMakeFiles/cmlibrhash.dir/depend
| cd /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build && /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/recipe-sysroot-native/usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/cmake-3.8.2 /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/cmake-3.8.2/Utilities/cmlibrhash /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/Utilities/cmlibrhash /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/Utilities/cmlibrhash/CMakeFiles/cmlibrhash.dir/DependInfo.cmake --color=
| make -f Utilities/cmlibrhash/CMakeFiles/cmlibrhash.dir/build.make Utilities/cmlibrhash/CMakeFiles/cmlibrhash.dir/build
| make[2]: Nothing to be done for 'Utilities/cmlibrhash/CMakeFiles/cmlibrhash.dir/build'.
| [ 15%] Built target cmlibrhash
| make -f Utilities/cmcompress/CMakeFiles/cmcompress.dir/build.make Utilities/cmcompress/CMakeFiles/cmcompress.dir/depend
| cd /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build && /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/recipe-sysroot-native/usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/cmake-3.8.2 /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/cmake-3.8.2/Utilities/cmcompress /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/Utilities/cmcompress /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/Utilities/cmcompress/CMakeFiles/cmcompress.dir/DependInfo.cmake --color=
| make -f Utilities/cmcompress/CMakeFiles/cmcompress.dir/build.make Utilities/cmcompress/CMakeFiles/cmcompress.dir/build
| make[2]: Nothing to be done for 'Utilities/cmcompress/CMakeFiles/cmcompress.dir/build'.
| [ 16%] Built target cmcompress
| make -f Utilities/cmjsoncpp/CMakeFiles/cmjsoncpp.dir/build.make Utilities/cmjsoncpp/CMakeFiles/cmjsoncpp.dir/depend
| cd /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build && /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/recipe-sysroot-native/usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/cmake-3.8.2 /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/cmake-3.8.2/Utilities/cmjsoncpp /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/Utilities/cmjsoncpp /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/Utilities/cmjsoncpp/CMakeFiles/cmjsoncpp.dir/DependInfo.cmake --color=
| make -f Utilities/cmjsoncpp/CMakeFiles/cmjsoncpp.dir/build.make Utilities/cmjsoncpp/CMakeFiles/cmjsoncpp.dir/build
| make[2]: Nothing to be done for 'Utilities/cmjsoncpp/CMakeFiles/cmjsoncpp.dir/build'.
| [ 17%] Built target cmjsoncpp
| make -f Utilities/cmlibuv/CMakeFiles/cmlibuv.dir/build.make Utilities/cmlibuv/CMakeFiles/cmlibuv.dir/depend
| cd /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build && /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/recipe-sysroot-native/usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/cmake-3.8.2 /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/cmake-3.8.2/Utilities/cmlibuv /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/Utilities/cmlibuv /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/Utilities/cmlibuv/CMakeFiles/cmlibuv.dir/DependInfo.cmake --color=
| make -f Utilities/cmlibuv/CMakeFiles/cmlibuv.dir/build.make Utilities/cmlibuv/CMakeFiles/cmlibuv.dir/build
| make[2]: Nothing to be done for 'Utilities/cmlibuv/CMakeFiles/cmlibuv.dir/build'.
| [ 23%] Built target cmlibuv
| make -f Source/CMakeFiles/CMakeLib.dir/build.make Source/CMakeFiles/CMakeLib.dir/depend
| cd /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build && /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/recipe-sysroot-native/usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/cmake-3.8.2 /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/cmake-3.8.2/Source /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/Source /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/Source/CMakeFiles/CMakeLib.dir/DependInfo.cmake --color=
| make -f Source/CMakeFiles/CMakeLib.dir/build.make Source/CMakeFiles/CMakeLib.dir/build
| make[2]: Nothing to be done for 'Source/CMakeFiles/CMakeLib.dir/build'.
| [ 75%] Built target CMakeLib
| make -f Source/CMakeFiles/CPackLib.dir/build.make Source/CMakeFiles/CPackLib.dir/depend
| cd /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build && /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/recipe-sysroot-native/usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/cmake-3.8.2 /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/cmake-3.8.2/Source /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/Source /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/Source/CMakeFiles/CPackLib.dir/DependInfo.cmake --color=
| make -f Source/CMakeFiles/CPackLib.dir/build.make Source/CMakeFiles/CPackLib.dir/build
| make[2]: Nothing to be done for 'Source/CMakeFiles/CPackLib.dir/build'.
| [ 79%] Built target CPackLib
| make -f Source/CMakeFiles/CTestLib.dir/build.make Source/CMakeFiles/CTestLib.dir/depend
| cd /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build && /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/recipe-sysroot-native/usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/cmake-3.8.2 /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/cmake-3.8.2/Source /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/Source /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/Source/CMakeFiles/CTestLib.dir/DependInfo.cmake --color=
| make -f Source/CMakeFiles/CTestLib.dir/build.make Source/CMakeFiles/CTestLib.dir/build
| make[2]: Nothing to be done for 'Source/CMakeFiles/CTestLib.dir/build'.
| [ 90%] Built target CTestLib
| make -f Source/CMakeFiles/CMakeServerLib.dir/build.make Source/CMakeFiles/CMakeServerLib.dir/depend
| cd /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build && /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/recipe-sysroot-native/usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/cmake-3.8.2 /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/cmake-3.8.2/Source /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/Source /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/Source/CMakeFiles/CMakeServerLib.dir/DependInfo.cmake --color=
| make -f Source/CMakeFiles/CMakeServerLib.dir/build.make Source/CMakeFiles/CMakeServerLib.dir/build
| make[2]: Nothing to be done for 'Source/CMakeFiles/CMakeServerLib.dir/build'.
| [ 91%] Built target CMakeServerLib
| make -f Source/CMakeFiles/cmake.dir/build.make Source/CMakeFiles/cmake.dir/depend
| cd /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build && /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/recipe-sysroot-native/usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/cmake-3.8.2 /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/cmake-3.8.2/Source /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/Source /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/Source/CMakeFiles/cmake.dir/DependInfo.cmake --color=
| make -f Source/CMakeFiles/cmake.dir/build.make Source/CMakeFiles/cmake.dir/build
| [ 91%] Linking CXX executable ../bin/cmake
| cd /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build/Source && /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/recipe-sysroot-native/usr/bin/cmake -E cmake_link_script CMakeFiles/cmake.dir/link.txt --verbose=1
| /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/recipe-sysroot-native/usr/bin/x86_64-angstromsdk-linux/x86_64-angstromsdk-linux-g++ --sysroot=/home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/recipe-sysroot -O2 -pipe --sysroot=/home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/recipe-sysroot -O2 -pipe -Wl,-O1 -Wl,-O1 -rdynamic CMakeFiles/cmake.dir/cmakemain.cxx.o CMakeFiles/cmake.dir/cmcmd.cxx.o -o ../bin/cmake libCMakeLib.a libCMakeServerLib.a libCMakeLib.a kwsys/libcmsys.a -lexpat -lz -larchive ../Utilities/cmcompress/libcmcompress.a -lcurl ../Utilities/cmjsoncpp/libcmjsoncpp.a ../Utilities/cmlibuv/libcmlibuv.a -lpthread -ldl -lrt ../Utilities/cmlibrhash/libcmlibrhash.a
| libCMakeLib.a(cmCommands.cxx.o): In function `GetPredefinedCommands()':
| cmCommands.cxx:(.text+0xddb): undefined reference to `vtable for cmInstallCommand'
| cmCommands.cxx:(.text+0xf3d): undefined reference to `vtable for cmLinkDirectoriesCommand'
| cmCommands.cxx:(.text+0xf94): undefined reference to `vtable for cmListCommand'
| cmCommands.cxx:(.text+0x1351): undefined reference to `vtable for cmSetCommand'
| cmCommands.cxx:(.text+0x13a8): undefined reference to `vtable for cmSetDirectoryPropertiesCommand'
| cmCommands.cxx:(.text+0x13c7): undefined reference to `cmSetPropertyCommand::cmSetPropertyCommand()'
| cmCommands.cxx:(.text+0x1426): undefined reference to `vtable for cmSetSourceFilesPropertiesCommand'
| cmCommands.cxx:(.text+0x21a6): undefined reference to `vtable for cmLinkLibrariesCommand'
| collect2: error: ld returned 1 exit status
| Source/CMakeFiles/cmake.dir/build.make:135: recipe for target 'bin/cmake' failed
| make[2]: *** [bin/cmake] Error 1
| CMakeFiles/Makefile2:1739: recipe for target 'Source/CMakeFiles/cmake.dir/all' failed
| make[1]: *** [Source/CMakeFiles/cmake.dir/all] Error 2
| make[1]: Leaving directory '/home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/build'
| Makefile:165: recipe for target 'all' failed
| WARNING: exit code 2 from a shell command.
| ERROR: Function failed: do_compile (log file is located at /home/abc/oe-core/build/tmp-glibc/work/x86_64-nativesdk-angstromsdk-linux/nativesdk-cmake/3.8.2-r0/temp/log.do_compile.3747)
ERROR: Task (virtual:nativesdk:/home/abc/oe-core/build/../layers/openembedded-core/meta/recipes-devtools/cmake/cmake_3.8.2.bb:do_compile) failed with exit code '1'
ERROR: qt3d-native-5.9.2+gitAUTOINC+143b721249-r0 do_compile: oe_runmake failed
ERROR: qt3d-native-5.9.2+gitAUTOINC+143b721249-r0 do_compile: Function failed: do_compile (log file is located at /home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.2+gitAUTOINC+143b721249-r0/temp/log.do_compile.3874)
ERROR: Logfile of failure stored in: /home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.2+gitAUTOINC+143b721249-r0/temp/log.do_compile.3874
Log data follows:
| NOTE: make MAKEFLAGS= OE_QMAKE_COMPILER=gcc OE_QMAKE_CC=gcc OE_QMAKE_CXX=g++ OE_QMAKE_CFLAGS=-isystem/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.2+gitAUTOINC+143b721249-r0/recipe-sysroot-native/usr/include -O2 -pipe OE_QMAKE_CXXFLAGS=-isystem/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.2+gitAUTOINC+143b721249-r0/recipe-sysroot-native/usr/include -O2 -pipe OE_QMAKE_LINK=g++ OE_QMAKE_LDFLAGS=-L/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.2+gitAUTOINC+143b721249-r0/recipe-sysroot-native/usr/lib -L/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.2+gitAUTOINC+143b721249-r0/recipe-sysroot-native/lib -Wl,-rpath-link,/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.2+gitAUTOINC+143b721249-r0/recipe-sysroot-native/usr/lib -Wl,-rpath-link,/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.2+gitAUTOINC+143b721249-r0/recipe-sysroot-native/lib -Wl,-rpath,/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.2+gitAUTOINC+143b721249-r0/recipe-sysroot-native/usr/lib -Wl,-rpath,/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.2+gitAUTOINC+143b721249-r0/recipe-sysroot-native/lib -Wl,-O1 OE_QMAKE_AR=ar OE_QMAKE_STRIP=echo OE_QMAKE_WAYLAND_SCANNER=/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.2+gitAUTOINC+143b721249-r0/recipe-sysroot-native/usr/bin/wayland-scanner OE_QMAKE_INCDIR_QT=//home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.2+gitAUTOINC+143b721249-r0/recipe-sysroot-native/usr/include/qt5
| cd tools/ && ( test -e Makefile || /home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.2+gitAUTOINC+143b721249-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.2+gitAUTOINC+143b721249-r0/git/tools/tools.pro CONFIG+=tools-only QMAKE_USE_PRIVATE+=zlib ) && make -f Makefile
| make[1]: Entering directory '/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.2+gitAUTOINC+143b721249-r0/build/tools'
| cd qgltf/ && ( test -e Makefile || /home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.2+gitAUTOINC+143b721249-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.2+gitAUTOINC+143b721249-r0/git/tools/qgltf/qgltf.pro CONFIG+=tools-only QMAKE_USE_PRIVATE+=zlib ) && make -f Makefile
| make[2]: Entering directory '/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.2+gitAUTOINC+143b721249-r0/build/tools/qgltf'
| linking ../../bin/qgltf
| .obj/BlenderLoader.o: file not recognized: File truncated
| Makefile:875: recipe for target '../../bin/qgltf' failed
| make[2]: *** [../../bin/qgltf] Error 1
| make[2]: Leaving directory '/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.2+gitAUTOINC+143b721249-r0/build/tools/qgltf'
| Makefile:44: recipe for target 'sub-qgltf-make_first' failed
| make[1]: *** [sub-qgltf-make_first] Error 2
| make[1]: Leaving directory '/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.2+gitAUTOINC+143b721249-r0/build/tools'
| Makefile:44: recipe for target 'sub-tools-make_first' failed
| make: *** [sub-tools-make_first] Error 2
| ERROR: Function failed: do_compile (log file is located at /home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.2+gitAUTOINC+143b721249-r0/temp/log.do_compile.3874)
ERROR: Task (virtual:native:/home/abc/oe-core/build/../layers/meta-qt5/recipes-qt/qt5/qt3d_git.bb:do_compile) failed with exit code '1'
ERROR: qttools-native-5.9.2+gitAUTOINC+90a701032e-r0 do_compile: oe_runmake failed
ERROR: qttools-native-5.9.2+gitAUTOINC+90a701032e-r0 do_compile: Function failed: do_compile (log file is located at /home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qttools-native/5.9.2+gitAUTOINC+90a701032e-r0/temp/log.do_compile.3890)
ERROR: Logfile of failure stored in: /home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qttools-native/5.9.2+gitAUTOINC+90a701032e-r0/temp/log.do_compile.3890
Log data follows:
| NOTE: make MAKEFLAGS= OE_QMAKE_COMPILER=gcc OE_QMAKE_CC=gcc OE_QMAKE_CXX=g++ OE_QMAKE_CFLAGS=-isystem/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qttools-native/5.9.2+gitAUTOINC+90a701032e-r0/recipe-sysroot-native/usr/include -O2 -pipe OE_QMAKE_CXXFLAGS=-isystem/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qttools-native/5.9.2+gitAUTOINC+90a701032e-r0/recipe-sysroot-native/usr/include -O2 -pipe OE_QMAKE_LINK=g++ OE_QMAKE_LDFLAGS=-L/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qttools-native/5.9.2+gitAUTOINC+90a701032e-r0/recipe-sysroot-native/usr/lib -L/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qttools-native/5.9.2+gitAUTOINC+90a701032e-r0/recipe-sysroot-native/lib -Wl,-rpath-link,/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qttools-native/5.9.2+gitAUTOINC+90a701032e-r0/recipe-sysroot-native/usr/lib -Wl,-rpath-link,/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qttools-native/5.9.2+gitAUTOINC+90a701032e-r0/recipe-sysroot-native/lib -Wl,-rpath,/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qttools-native/5.9.2+gitAUTOINC+90a701032e-r0/recipe-sysroot-native/usr/lib -Wl,-rpath,/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qttools-native/5.9.2+gitAUTOINC+90a701032e-r0/recipe-sysroot-native/lib -Wl,-O1 OE_QMAKE_AR=ar OE_QMAKE_STRIP=echo OE_QMAKE_WAYLAND_SCANNER=/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qttools-native/5.9.2+gitAUTOINC+90a701032e-r0/recipe-sysroot-native/usr/bin/wayland-scanner OE_QMAKE_INCDIR_QT=//home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qttools-native/5.9.2+gitAUTOINC+90a701032e-r0/recipe-sysroot-native/usr/include/qt5
| cd src/ && ( test -e Makefile || /home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qttools-native/5.9.2+gitAUTOINC+90a701032e-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qttools-native/5.9.2+gitAUTOINC+90a701032e-r0/git/src/src.pro CONFIG+=noqtwebkit ) && make -f Makefile
| make[1]: Entering directory '/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qttools-native/5.9.2+gitAUTOINC+90a701032e-r0/build/src'
| cd linguist/ && ( test -e Makefile || /home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qttools-native/5.9.2+gitAUTOINC+90a701032e-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qttools-native/5.9.2+gitAUTOINC+90a701032e-r0/git/src/linguist/linguist.pro CONFIG+=noqtwebkit ) && make -f Makefile
| make[2]: Entering directory '/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qttools-native/5.9.2+gitAUTOINC+90a701032e-r0/build/src/linguist'
| cd lrelease/ && ( test -e Makefile || /home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qttools-native/5.9.2+gitAUTOINC+90a701032e-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qttools-native/5.9.2+gitAUTOINC+90a701032e-r0/git/src/linguist/lrelease/lrelease.pro CONFIG+=noqtwebkit ) && make -f Makefile
| make[3]: Entering directory '/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qttools-native/5.9.2+gitAUTOINC+90a701032e-r0/build/src/linguist/lrelease'
| linking ../../../bin/lrelease
| .obj/main.o: file not recognized: File truncated
| Makefile:126: recipe for target '../../../bin/lrelease' failed
| make[3]: *** [../../../bin/lrelease] Error 1
| make[3]: Leaving directory '/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qttools-native/5.9.2+gitAUTOINC+90a701032e-r0/build/src/linguist/lrelease'
| Makefile:46: recipe for target 'sub-lrelease-make_first' failed
| make[2]: *** [sub-lrelease-make_first] Error 2
| make[2]: Leaving directory '/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qttools-native/5.9.2+gitAUTOINC+90a701032e-r0/build/src/linguist'
| Makefile:49: recipe for target 'sub-linguist-make_first' failed
| make[1]: *** [sub-linguist-make_first] Error 2
| make[1]: Leaving directory '/home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qttools-native/5.9.2+gitAUTOINC+90a701032e-r0/build/src'
| Makefile:46: recipe for target 'sub-src-make_first' failed
| make: *** [sub-src-make_first] Error 2
| ERROR: Function failed: do_compile (log file is located at /home/abc/oe-core/build/tmp-glibc/work/x86_64-linux/qttools-native/5.9.2+gitAUTOINC+90a701032e-r0/temp/log.do_compile.3890)
ERROR: Task (virtual:native:/home/abc/oe-core/build/../layers/meta-qt5/recipes-qt/qt5/qttools_git.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 8839 tasks of which 8835 didn't need to be rerun and 4 failed.
NOTE: Writing buildhistory
Summary: 4 tasks failed:
Summary: There was 1 WARNING message shown.
Summary: There were 7 ERROR messages shown, returning a non-zero exit code.
