is it possible to clone the meta information of a previous beta branch, for example LinuxImageV2.7.3 ?
When doing:
repo init -u http://git.toradex.com/toradex-bsp-platform.git -b LinuxImageV2.7
repo sync
will clone 2.7.5.
What should I do if I need to use OE 2.7.3 ? Is it possible ?
Doing:
repo init -u http://git.toradex.com/toradex-bsp-platform.git -b LinuxImageV2.7.3
of course is not working.
Thank you,
Nicola
Darion
2
Hey Nicola,
You can choose any branch of the OpenEmbedded with the following syntax:
repo init -u http://git.toradex.com/toradex-bsp-platform.git -b refs/tags/BRANCH_NAME
where BRANCH_NAME can be any available tags can be found in the manifest repository: toradex-bsp-platform.git - oe-core repo manifest.
In your case for Apalis iMX6 - Linux 2.7.3 will be
repo init -u http://git.toradex.com/toradex-bsp-platform.git -b refs/tags/Apalis-iMX6_LXDE-Image_2.7b3-20170630
You can find the documentation here
Hello Darion,
thank you for your answer !
All clear now.
Nicola
