I tryed to connect the colibri to a microcontroller via spi. Messages over 4096 bit length are not successfully transfered. Below this limit all works fine. How can I change the set “max value” to 8192 or more? I am programming with c.
struct spi_ioc_transfer tr =
.tx_buf = (unsigned long)tx,
.rx_buf = (unsigned long)rx,
.len = ARRAY_SIZE(tx), // limited to 4096 bytes!
.delay_usecs = delay,
.speed_hz = speed,
.bits_per_word = bits,
retVal = ioctl(fd_SPI, SPI_IOC_MESSAGE(1), &tr);
