I’m trying to recover two modules VF50.
I use the image version 2.5 to recovery.
When I do this, I always follows the topic of recovery mode from scratch:
Follow my log:
$ sudo ./update.sh -n -d /dev/ttyUSB0
Colibri VF rootfs detected
Put the module in recovery mode and press [ENTER]...
config file <vf_flash/vybrid_usb_work.conf>
parse vf_flash/vybrid_usb_work.conf
starting associating phase
association phase succeeded, response was 0x23454523
HAB security state: development mode (0x56787856)
== work item
filename colibri-vf_bin/u-boot.imx
load_size 0 bytes
load_addr 0x00000000
dcd 1
clear_dcd 0
plug 1
jump_mode 2
jump_addr 0x00000000
== end work item
main dcd length 8
sub dcd length 4
loading binary file(colibri-vf_bin/u-boot.imx) to 3f4078e8, skip=0, fsize=67718 type=aa
<<<423704, 423704 bytes>>>
succeeded (status 0x88888888)
jumping to 0x3f4078e8
After that, I’m able to access the console again.
Colibri VFxx # nand erase.chip
NAND erase.chip: device 0 whole chip
Skipping bad block at 0x013c0000
Skipping bad block at 0x07f80000
Skipping bad block at 0x07fa0000
Skipping bad block at 0x07fc0000
Skipping bad block at 0x07fe0000
OK
Colibri VFxx # run setupdate
reading flash_blk.img
1719 bytes read in 13 ms (128.9 KiB/s)
## Executing script at 80008000
enter "run update" to update the entire module
Colibri VFxx # run create_bcb
NAND erase.part: device 0 offset 0x0, size 0x20000
Erasing at 0x0 -- 100% complete.
OK
Write FCB...
FCB 2048 bytes written to 0x0: OK
Colibri VFxx # cfgblock create
Is the module an IT version? [y/N] y
Enter the module version (e.g. V1.1B): V1.2A
Enter module serial number: 04887763
Toradex config block successfully written
Colibri VFxx # run update
reading u-boot-nand.imx
453400 bytes read in 47 ms (9.2 MiB/s)
NAND erase.part: device 0 offset 0x20000, size 0x160000
Erasing at 0x160000 -- 100% complete.
OK
NAND erase.part: device 0 offset 0x180000, size 0x80000
Erasing at 0x1e0000 -- 100% complete.
OK
NAND write: device 0 offset 0x20000, size 0x160000
1441792 bytes written: OK
reading ubifs.img
47108096 bytes read in 3063 ms (14.7 MiB/s)
UBI: default fastmap pool size: 50
UBI: default fastmap WL pool size: 25
UBI: attaching mtd1 to ubi0
UBI: scanning is finished
UBI: empty MTD device detected
UBI: attached mtd1 (name "mtd=3", size 126 MiB) to ubi0
UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
UBI: good PEBs: 1003, bad PEBs: 5, corrupted PEBs: 0
UBI: user volume: 0, internal volumes: 1, max. volumes count: 128
UBI: max/mean erase counter: 1/0, WL threshold: 4096, image sequence number: 0
UBI: available PEBs: 982, total reserved PEBs: 21, PEBs reserved for bad PEB ha5
No size specified -> Using max size (124690432)
Creating dynamic volume rootfs of size 124690432
47108096 bytes written to volume rootfs
resetting ...
This is my problem, I receive the message “resetting…”, but nothing happens.
In this point I’m not able to type any command. If I try reset the module by hardware I need to run the recovery mode again. The same happens if I try to turn OFF and ON the evaluation board.
What I’m doing wrong? It’s always works to me.
Thank you very much!
