How to add custom device tree to deploy/images/colibri-imx6 and update.sh using OpenEmbedded recipes
I added my custom openembedded layer containing a patch which adds my custom device tree and drivers to the kernel sources. The kernel and drivers seems to be build, is available under deploy/images/… and is installed onto the internal flash memory of Toradex modules by the update.sh script.
However, my custom kernel device tree is not installed.
  • I think I have to patch the update.sh script to contain the name of my dtb file in the KERNEL_DEVICETREE variable. But where do I have to add this patch and how I can make bitbake apply it?
  • And how can I tell bitbake to include the dtb file in Colibri-iMX6_pe-LXDE-image_2.7b4-20180424.tar.bz2?
Hi
You could append in local.conf to the KERNEL_DEVICETREE variable which gets set in the machine configuration file.
KERNEL_DEVICETREE_append_colibri-imx6 = " imx6dl-your_version.dtb "
This should make sure that you have your device tree in deploy/images. The legacy image will then put all deploy/images/machine/*.dtb files into the Colibri-iMX6_pe-LXDE-image_2.7b4-20180424.tar.bz2
There is no easy way to change update.sh with a patch. You could add something like the following to add your device tree to the list of device tree files that the legacy update procedure deploys during ‘run update’:
imagedeploytools_append_colibri-imx6 () {
    sed -i 's/\(KERNEL_DEVICETREE\=\"\)/\1imx6dl-your_version.dtb /' ${IMAGE_DIR}/update.sh
Note that you additionally need to set the fdt_file U-Boot environment variable to actually use your new device tree.
Max
This works. I wonder if there is a way to append this to a *.conf within my custom BSP layer instead of local.conf which is not under version control. Appending to meta-pe-bsp/conf/machine/colibri-imx6.conf had no effect.
This works if put into meta-pe-software/recipes-images/images/pe-angstrom-lxde-image.bb
device tree.
For the record here is how I did it:
I added meta-pe-bsp/recipes-bsp/u-boot/files/colibri-imx6/colibri_imx6.h-FDT_FILE_imx6dl-colibri-pe641t-1.dtb.patch:
diff --git a/include/configs/colibri_imx6.h b/include/configs/colibri_imx6.h
index f1fd5b422e..21f4723199 100644
--- a/include/configs/colibri_imx6.h
+++ b/include/configs/colibri_imx6.h
@@ -228,7 +228,7 @@
 	"usbdtbload=setenv dtbparam; load usb 0:1 ${fdt_addr_r} " \
 		"${fdt_file} && setenv dtbparam \" - ${fdt_addr_r}\" && true\0"
-#define FDT_FILE "imx6dl-colibri-eval-v3.dtb"
+#define FDT_FILE "imx6dl-colibri-pe641t-1.dtb"
 #define CONFIG_EXTRA_ENV_SETTINGS \
 	BOOTENV \
 	"bootcmd=run emmcboot ; echo ; echo emmcboot failed ; " \
and meta-pe-bsp/recipes-bsp/u-boot/u-boot-toradex_2016.11.bbappend:
# the _mx6 suffix restricts the validity to iMX6 modules
# see ELPUYPC p.105
SRC_URI_append_mx6 = " file://colibri_imx6.h-FDT_FILE_imx6dl-colibri-pe641t-1.dtb.patch"
FILESEXTRAPATHS_prepend := "${THISDIR}/files/colibri-imx6/:"
This the layer structure:
meta-pe-bsp/
├── conf
│   ├── layer.conf
│   └── machine
│       ├── colibri-imx6.conf
│       └── colibri-t30-pe.conf
├── recipes-bsp
│   └── u-boot
│       ├── files
│       │   └── colibri-imx6
│       │       └── colibri_imx6.h-FDT_FILE_imx6dl-colibri-pe641t-1.dtb.patch
│       └── u-boot-toradex_2016.11.bbappend
└── recipes-kernel
    └── linux
After flashing the new environment variables can be loaded with:
env default -a
saveenv
Hi
You cannot append to *.conf files.
One not intutive way is to misuse the layer.conf file of your layer. As an aid to your uninitiated coworker I think a comment in the bbappend to the linux kernel pointing to conf/layer.conf could be beneficial.
Max
Well then the cleaner way seems to stick to local.conf and add a local.conf.example to our docs.
