Here some clarifications I need to you.
Not sure what you mean by that.
If I setenv fdt_addr_r 0x01700000 according to your suggestion run update_roofs
performs regularly with no crash, but the boot fails according what I showed you.
I followed the suggestion from: Answer by dominik.tx · Apr 27 at 10:41 AM.
*** I also noticed that u-boot build with bitbake…
You mean according to our regular OE-core build instructions?***
No, I mean u-boot image available in:
/opt/oe-core/deploy/images/colibri-t20/Colibri-T20_LXDE-Image_2.8b2-20180508.tar.bz2
according to:
bitbake -k angstrom-lxde-image
bitbake angstrom-lxde-image -c populate_sdk
What exactly do you mean by “directly for Toradex binary repository”?
I followed dominik.tx suggestion six days later:
https://developer.toradex.com/files/toradex-dev/uploads/media/Colibri/Linux/Images/Colibri-T20_LXDE-Image_2.8b2.97-20180331.tar.bz2
What exact (U-boot) parameters are you talking about?
I cannot replay my findings, probably some temporary parameters were saved inadvertently.
I checked brand new U-boot environments for the two cases: the number and name of parameters appear to be the same, even if some values can obviously change according to the target.
For your reference:
This is the U-boot printout for a T20 512M (not 256M !) safely and completely updated according to:
Colibri-T20_LXDE-Image_2.8b2-20180508.tar.bz2 from bitbake.
Please note that its rootfs is even larger due to Qt libraries in /usr/lib.
U-Boot SPL 2016.11-2.8.2+g087e95a2dc (May 04 2018 - 16:07:57)
Trying to boot from RAM
U-Boot 2016.11-2.8.2+g087e95a2dc (May 04 2018 - 16:07:57 +0200)
TEGRA20
DRAM: 512 MiB
NAND: 1024 MiB
MMC: Tegra SD/MMC: 0
In: serial
Out: vidconsole
Err: vidconsole
Model: Toradex Colibri T20 512MB V1.2A, Serial# 04867023
Net: No ethernet found.
Colibri T20 # printenv
arch=arm
baudrate=115200
board=colibri_t20
board_name=colibri_t20
boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr}
boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}extlinux/extlinux.conf
boot_file=zImage
boot_net_usb_start=usb start
boot_prefixes=/ /boot/
boot_script_dhcp=boot.scr.uimg
boot_scripts=boot.scr.uimg boot.scr
boot_targets=mmc1 mmc0 usb0 pxe dhcp
bootcmd=run ubiboot; setenv fdtfile ${soc}-colibri-${fdt_board}.dtb && run distro_bootcmd
bootcmd_dhcp=run boot_net_usb_start; if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi;
bootcmd_mmc0=setenv devnum 0; run mmc_boot
bootcmd_mmc1=setenv devnum 1; run mmc_boot
bootcmd_pxe=run boot_net_usb_start; dhcp; if pxe get; then pxe boot; fi
bootcmd_usb0=setenv devnum 0; run usb_boot
bootdelay=1
console=ttyS0
cpu=armv7
defargs=vmalloc=128M usb_high_speed=1 user_debug=30
dfu_alt_info=u-boot part 0,0;ubi part 0,3
distro_bootcmd=for target in ${boot_targets}; do run bootcmd_${target}; done
ethaddr=00:14:2d:4a:43:cf
fdt_addr_r=0x02000000
fdt_board=eval-v3
fdt_fixup=;
fdt_high=ffffffff
fdtcontroladdr=1d711d80
gatewayip=192.168.1.253
hw-version=v12
initrd_high=ffffffff
ipaddr=192.168.1.79
kernel_addr_r=0x01000000
leb-size=248KiB
loadaddr=0x01000000
memargs=mem=372M@0M fbmem=12M@372M nvmem=128M@384M
mmc_boot=if mmc dev ${devnum}; then setenv devtype mmc; run scan_dev_for_boot_part; fi
mtdparts=mtdparts=tegra_nand:2m(u-boot)ro,1m(u-boot-env),1m(cfgblock)ro,-(ubi)
netmask=255.255.255.0
nfsargs=ip=:::::eth0:on root=/dev/nfs rw
nfsboot=usb start; run setup; setenv bootargs ${defargs} ${mtdparts} ${nfsargs} ${setupargs} ${vidargs}; echo Booting via DHCP/TFTP/NFS…; run nfsdtbload; dhcp ${kernel_addr_r} && run fdt_fixup && bootz ${kernel_addr_r} - ${dtbparam}
nfsdtbload=setenv dtbparam; tftp ${fdt_addr_r} ${soc}-colibri-${fdt_board}.dtb && setenv dtbparam ${fdt_addr_r}
pxefile_addr_r=0x10100000
ram-size=512
ramdisk_addr_r=0x02100000
scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}…; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run scan_dev_for_scripts; done;
scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devplist}; do if fstype ${devtype} ${devnum}:${distro_bootpart} bootfstype; then run scan_dev_for_boot; fi; done
scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}extlinux/extlinux.conf; then echo Found ${prefix}extlinux/extlinux.conf; run boot_extlinux; echo SCRIPT FAILED: continuing…; fi
scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; echo SCRIPT FAILED: continuing…; fi; done
scriptaddr=0x10000000
sdargs=ip=off root=/dev/mmcblk0p2 ro rootfstype=ext3 rootwait
sdboot=run setup; setenv bootargs ${defargs} ${mtdparts} ${sdargs} ${setupargs} ${vidargs}; echo Booting from SD card…; run sddtbload; load mmc 1:1 ${kernel_addr_r} ${boot_file} && run fdt_fixup && bootz ${kernel_addr_r} - ${dtbparam}
sddtbload=setenv dtbparam; load mmc 1:1 ${fdt_addr_r} ${soc}-colibri-${fdt_board}.dtb && setenv dtbparam ${fdt_addr_r}
serial#=04867023
serverip=192.168.1.67
setethupdate=if env exists ethaddr; then; else setenv ethaddr 00:14:2d:00:00:00; fi; usb start && tftpboot ${loadaddr} flash_eth.img && source ${loadaddr}
setsdupdate=setenv interface mmc; setenv drive 0; mmc rescan; load ${interface} ${drive}:1 ${loadaddr} flash_blk.img && source ${loadaddr}
setup=setenv setupargs asix_mac=${ethaddr} consoleblank=0 no_console_suspend=1 console=tty1 console=${console},${baudrate}n8 debug_uartport=lsport,0 ${memargs}
setupdate=run setsdupdate || run setusbupdate || run setethupdate
setusbupdate=usb start && setenv interface usb; setenv drive 0; load ${interface} ${drive}:1 ${loadaddr} flash_blk.img && source ${loadaddr}
soc=tegra20
stderr=serial,vidconsole
stdin=serial
stdout=serial,vidconsole
ubiargs=ubi.mtd=ubi root=ubi0:rootfs rw rootfstype=ubifs ubi.fm_autoconvert=1
ubiboot=run setup; setenv bootargs ${defargs} ${ubiargs} ${mtdparts} ${setupargs} ${vidargs}; echo Booting from NAND…; ubi part ubi && ubi read ${kernel_addr_r} kernel &&run ubidtbload && run fdt_fixup; bootz ${kernel_addr_r} - ${dtbparam}; bootz ${kernel_addr_r} -
ubidtbload=setenv dtbparam; ubi read ${fdt_addr_r} dtb && setenv dtbparam ${fdt_addr_r}
ubifs_boot=if ubi part UBI && ubifsmount ubi${devnum}:boot; then setenv devtype ubi; setenv bootpart 0; run scan_dev_for_boot; fi
usb_boot=usb start; if usb dev ${devnum}; then setenv devtype usb; run scan_dev_for_boot_part; fi
usbargs=ip=off root=/dev/sda2 ro rootfstype=ext3 rootwait
usbboot=run setup; setenv bootargs ${defargs} ${mtdparts} ${setupargs} ${usbargs} ${vidargs}; echo Booting from USB stick…; usb start && run usbdtbload; load usb 0:1 ${kernel_addr_r} ${boot_file} && run fdt_fixup && bootz ${kernel_addr_r} - ${dtbparam}
usbdtbload=setenv dtbparam; load usb 0:1 ${fdt_addr_r} ${soc}-colibri-${fdt_board}.dtb && setenv dtbparam ${fdt_addr_r}
vendor=toradex
ver=U-Boot 2016.11-2.8.2+g087e95a2dc (May 04 2018 - 16:07:57 +0200)
vidargs=video=tegrafb0:640x480-16@60
Environment size: 5489/65532 bytes
Colibri T20 #
This is the output from a 256M T20 with u-boot (only) updated according to
U-Boot 2016.11-2.8.2+g087e95a (Mar 31 2018 - 08:15:50 +0000)
TEGRA20
DRAM: 256 MiB
NAND: 512 MiB
*** Warning - bad CRC, using default environment
In: serial
Out: vidconsole
Err: vidconsole
Model: Toradex Colibri T20 256MB V1.2A, Serial# 04845442
arch=arm
baudrate=115200
board=colibri_t20
boot_file=zImage
bootdelay=1
console=ttyS0
cpu=armv7
ethaddr=00:14:2d:49:ef:82
fdt_board=eval-v3
fdt_fixup=;
fdt_high=ffffffff
fdtcontroladdr=d711d80
hw-version=v12
ipaddr=192.168.10.2
leb-size=248KiB
loadaddr=0x01000000
memargs=mem=148M@0M fbmem=12M@148M nvmem=96M@160M
ram-size=256
serial#=04845442
serverip=192.168.10.1
soc=tegra20
stdin=serial
vendor=toradex
ver=U-Boot 2016.11-2.8.2+g087e95a (Mar 31 2018 - 08:15:50 +0000)
Environment size: 5458/65532 bytes
Colibri T20 #
Many thanks for your attention.
