Hi
I would like to know when the release of V2.2 of the Toradex CE Libraries is planned. Is it also needed to update the BSP to a newer version than 1.3 with CE Libs V2.2?
Thanks and BR
Hi
Thanks and BR
Dear @christian.s
The Libs V2.2 release is planned in about one week.
The OS requirements depend on the module you use (please update the tags for this post), as well as on the features you use.
Minimum OS requirements are documented for each function in the *.chm help file which is part of the library download package.
Regards, Andy
