When building the angstrom-qt5-x11-image with PREFERRED_PROVIDER_virtual/kernel = “linux-toradex-rt” enabled, it does not apply the rt patch correctly. When running ‘uname -a’ it gives:
Linux colibri-imx7-emmc 4.9.84-rt62-2.8.2+gb2a7f2f #1 SMP
Hm, that sounds as if the defconfig has not been applied.
Can you check zcat /proc/config.gz | grep PREEMPT and make sure that the defconfig for preemt RT was present during build (in meta-toradex-nxp/recipes-kernel/linux/linux-toradex-rt-4.9-1.0.x/mx7/defconfig).
CONFIG_HAVE_PREEMPT_LAZY=y
# CONFIG_PREEMPT_NONE is not set
CONFIG_PREEMPT_VOLUNTARY=y
# CONFIG_PREEMPT__LL is not set
# CONFIG_PREEMPT_RTB is not set
# CONFIG_PREEMPT_RT_FULL is not set
It looks like the defconfig is indeed not applied for some reason. I checked and the defconfig is present in the correct folder, and contains the line: CONFIG_PREEMPT_RT_FULL=y
Could it be a problem that i’m using colibri-imx7-emmc as machine?
There is a bug in the current linux-toradex-rt recipe which prevents bitbake to pickup the correct defconfig. I fixed the recipe and pushed the fix to the rocko-next tree of the meta-toradex-nxp layer. Updating the layer and rebuilding the image should solve the issue.
