I am using Apalis IMX6 and Apalis Evaluation Board. Console with USB UART.
It is booting every time in emergency mode.
Please help me.
Below is Boot log:
U-Boot 2015.04 (May 18 2015 - 13:08:28)
CPU: Freescale i.MX6D rev1.5 at 792 MHz
Reset cause: WDOG
I2C: ready
DRAM: 512 MiB
*** Warning - bad CRC, using default environment
auto-detected panel vga-rgb
Display: vga-rgb (640x480)
In: serial
Out: serial
Err: serial
Model: Toradex Apalis iMX6 Dual 512MB V1.1A, Serial# 04861823
Net: using phy at 7
FEC [PRIME]
Booting from internal eMMC chip...
reading imx6q-apalis-eval.dtb
53049 bytes read in 18 ms (2.8 MiB/s)
reading uImage
4687216 bytes read in 127 ms (35.2 MiB/s)
## Booting kernel from Legacy Image at 10800000 ...
Image Name: Linux-3.10.17
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 4687152 Bytes = 4.5 MiB
Load Address: 10008000
Entry Point: 10008000
Verifying Checksum ... OK
## Flattened Device Tree blob at 12000000
Booting using the fdt blob at 0x12000000
Loading Kernel Image ... OK
Using Device Tree in place at 12000000, end 1200ff38
Starting kernel ...
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.10.17 (linuxdev@linuxdev.toradex.int) (gcc version 4.9.3 20141031 (prerelease) (Linaro GCC 4.9-2014.11) ) #1 SMP Mon May 18 13:10:16 CEST 2015
[ 0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: Freescale i.MX6 Quad/DualLite (Device Tree), model: Toradex Apalis iMX6Q on Apalis Evaluation Board
[ 0.000000] cma: CMA: reserved 256 MiB at 20000000
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] PERCPU: Embedded 8 pages/cpu @80cd6000 s8768 r8192 d15808 u32768
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048
[ 0.000000] Kernel command line: enable_wait_mode=off vmalloc=400M ip=off root=/dev/mmcblk0p2 rw,noatime rootfstype=ext3 rootwait fec_mac=00:14:2d:4a:2f:7f consoleblank=0 no_console_suspend=1 console=tty1 console=ttymxc0,115200n8 mxc_hdmi.only_cea=1 video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24 video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off fbmem=32M
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 512MB = 512MB total
[ 0.000000] Memory: 247952k/247952k available, 276336k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xa0800000 - 0xff000000 (1512 MB)
[ 0.000000] lowmem : 0x80000000 - 0xa0000000 ( 512 MB)
[ 0.000000] pkmap : 0x7fe00000 - 0x80000000 ( 2 MB)
[ 0.000000] modules : 0x7f000000 - 0x7fe00000 ( 14 MB)
[ 0.000000] .text : 0x80008000 - 0x807d1024 (7973 kB)
[ 0.000000] .init : 0x807d2000 - 0x80819240 ( 285 kB)
[ 0.000000] .data : 0x8081a000 - 0x80857ba0 ( 247 kB)
[ 0.000000] .bss : 0x80857ba0 - 0x808becd4 ( 413 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] L310 cache controller enabled
[ 0.000000] l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x32070000, Cache size: 1048576 B
[ 0.000000] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms
[ 0.000000] CPU identified as i.MX6Q, silicon rev 1.5
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty1] enabled
[ 0.001102] Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
[ 0.090133] pid_max: default: 32768 minimum: 301
[ 0.090291] Mount-cache hash table entries: 512
[ 0.098326] Initializing cgroup subsys debug
[ 0.098349] Initializing cgroup subsys freezer
[ 0.098386] CPU: Testing write buffer coherency: ok
[ 0.098638] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.098727] Setting up static identity map for 0x805f17b0 - 0x805f1808
[ 0.100000] CPU1: Booted secondary processor
[ 0.188696] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.188804] Brought up 2 CPUs
[ 0.188847] SMP: Total of 2 processors activated (3162.11 BogoMIPS).
[ 0.188861] CPU: All CPU(s) started in SVC mode.
[ 0.189467] devtmpfs: initialized
[ 0.193380] pinctrl core: initialized pinctrl subsystem
[ 0.193666] regulator-dummy: no parameters
[ 0.209940] NET: Registered protocol family 16
[ 0.218866] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.219677] Use WDOG1 as reset source
[ 0.227696] syscon 20c8000.anatop: regmap [mem 0x020c8000-0x020c8fff] registered
[ 0.227945] vdd1p1: 800 <--> 1375 mV at 1125 mV
[ 0.228244] vdd3p0: 2800 <--> 3150 mV at 3000 mV
[ 0.228523] vdd2p5: 2000 <--> 2750 mV at 2425 mV
[ 0.228820] cpu: 725 <--> 1450 mV at 1150 mV
[ 0.229089] vddpu: 725 <--> 1450 mV at 1150 mV
[ 0.229365] vddsoc: 725 <--> 1450 mV at 1175 mV
[ 0.230989] syscon 20e0000.iomuxc-gpr: regmap [mem 0x020e0000-0x020e0037] registered
[ 0.233500] syscon 21bc000.ocotp-ctrl: regmap [mem 0x021bc000-0x021bffff] registered
[ 0.237974] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[ 0.238003] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.239381] imx6q-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
[ 0.246836] bio: create slab <bio-0> at 0
[ 0.247499] 1P8V: 1800 mV
[ 0.247689] 2P5V: 2500 mV
[ 0.247876] 3P3V: 3300 mV
[ 0.248131] usb_otg_vbus: 5000 mV
[ 0.248391] usb_host_vbus_hub: 5000 mV
[ 0.248665] usb_host_vbus: 5000 mV
[ 0.248748] usb_host_vbus: supplied by usb_host_vbus_hub
[ 0.249038] vgaarb: loaded
[ 0.249711] SCSI subsystem initialized
[ 0.250061] usbcore: registered new interface driver usbfs
[ 0.250122] usbcore: registered new interface driver hub
[ 0.250221] usbcore: registered new device driver usb
[ 0.251101] i2c-gpio i2c.19: using pins 80 (SDA) and 62 (SCL)
[ 0.252328] i2c i2c-1: IMX I2C adapter registered
[ 0.253946] stmpe-i2c 2-0041: stmpe811 detected, chip id: 0x811
[ 0.255836] i2c i2c-2: IMX I2C adapter registered
[ 0.256621] i2c i2c-3: IMX I2C adapter registered
[ 0.256756] Linux video capture interface: v2.00
[ 0.256817] pps_core: LinuxPPS API ver. 1 registered
[ 0.256833] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.256866] PTP clock support registered
[ 0.268771] imx-ipuv3 2400000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
[ 0.288841] imx-ipuv3 2800000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
[ 0.289642] MIPI CSI2 driver module loaded
[ 0.289770] Advanced Linux Sound Architecture Driver Initialized.
[ 0.291212] Switching to clocksource mxc_timer1
[ 0.444558] imx6q-pcie 1ffc000.pcie: Configuration forces GEN1
[ 0.444722] PCI host bridge to bus 0000:00
[ 0.444749] pci_bus 0000:00: root bus resource [io 0x1000-0x10000]
[ 0.444770] pci_bus 0000:00: root bus resource [mem 0x01000000-0x01efffff]
[ 0.444792] pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff]
[ 0.445178] PCI: bus0: Fast back to back transfers disabled
[ 0.446100] PCI: bus1: Fast back to back transfers disabled
[ 0.446129] pci 0000:01:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.448964] PCI: bus2: Fast back to back transfers disabled
[ 0.448992] pci 0000:02:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.449043] pci 0000:02:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.449094] pci 0000:02:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.449462] PCI: bus3: Fast back to back transfers enabled
[ 0.449834] PCI: bus4: Fast back to back transfers enabled
[ 0.450215] PCI: bus5: Fast back to back transfers enabled
[ 0.450538] pci 0000:00:00.0: BAR 0: assigned [mem 0x01000000-0x010fffff]
[ 0.450566] pci 0000:00:00.0: BAR 8: assigned [mem 0x01100000-0x013fffff]
[ 0.450589] pci 0000:00:00.0: BAR 9: assigned [mem 0x01400000-0x015fffff pref]
[ 0.450614] pci 0000:00:00.0: BAR 6: assigned [mem 0x01600000-0x0160ffff pref]
[ 0.450638] pci 0000:00:00.0: BAR 7: assigned [io 0x1000-0x1fff]
[ 0.450664] pci 0000:01:00.0: BAR 8: assigned [mem 0x01100000-0x012fffff]
[ 0.450684] pci 0000:01:00.0: BAR 9: assigned [mem 0x01400000-0x015fffff 64bit pref]
[ 0.450708] pci 0000:01:00.0: BAR 0: assigned [mem 0x01300000-0x01303fff]
[ 0.450740] pci 0000:01:00.0: BAR 7: assigned [io 0x1000-0x1fff]
[ 0.450764] pci 0000:02:01.0: BAR 8: assigned [mem 0x01100000-0x012fffff]
[ 0.450784] pci 0000:02:01.0: BAR 9: assigned [mem 0x01400000-0x015fffff 64bit pref]
[ 0.450807] pci 0000:02:01.0: BAR 7: assigned [io 0x1000-0x1fff]
[ 0.450828] pci 0000:02:01.0: PCI bridge to [bus 03]
[ 0.450854] pci 0000:02:01.0: bridge window [io 0x1000-0x1fff]
[ 0.450888] pci 0000:02:01.0: bridge window [mem 0x01100000-0x012fffff]
[ 0.450919] pci 0000:02:01.0: bridge window [mem 0x01400000-0x015fffff 64bit pref]
[ 0.450961] pci 0000:02:02.0: PCI bridge to [bus 04]
[ 0.451025] pci 0000:02:03.0: PCI bridge to [bus 05]
[ 0.451089] pci 0000:01:00.0: PCI bridge to [bus 02-05]
[ 0.451115] pci 0000:01:00.0: bridge window [io 0x1000-0x1fff]
[ 0.451148] pci 0000:01:00.0: bridge window [mem 0x01100000-0x012fffff]
[ 0.451178] pci 0000:01:00.0: bridge window [mem 0x01400000-0x015fffff 64bit pref]
[ 0.451219] pci 0000:00:00.0: PCI bridge to [bus 01-05]
[ 0.451238] pci 0000:00:00.0: bridge window [io 0x1000-0x1fff]
[ 0.451287] pci 0000:00:00.0: bridge window [mem 0x01100000-0x013fffff]
[ 0.451311] pci 0000:00:00.0: bridge window [mem 0x01400000-0x015fffff pref]
[ 0.451353] PCI: enabling device 0000:01:00.0 (0140 -> 0143)
[ 0.451396] PCI: enabling device 0000:02:01.0 (0140 -> 0143)
[ 0.451439] PCI: enabling device 0000:02:02.0 (0140 -> 0143)
[ 0.451480] PCI: enabling device 0000:02:03.0 (0140 -> 0143)
[ 0.460688] NET: Registered protocol family 2
[ 0.461224] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.461339] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.461416] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.461473] TCP: reno registered
[ 0.461496] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.461534] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.461770] NET: Registered protocol family 1
[ 0.462076] RPC: Registered named UNIX socket transport module.
[ 0.462097] RPC: Registered udp transport module.
[ 0.462112] RPC: Registered tcp transport module.
[ 0.462126] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.462779] hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
[ 0.463683] pureg-dummy: no parameters
[ 0.464756] imx6_busfreq busfreq.15: DDR medium rate not supported.
[ 0.465175] Bus freq driver module loaded
[ 0.470735] VFS: Disk quotas dquot_6.5.2
[ 0.470969] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.472397] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.473104] NFS: Registering the id_resolver key type
[ 0.473177] Key type id_resolver registered
[ 0.473194] Key type id_legacy registered
[ 0.473778] fuse init (API version 7.22)
[ 0.474272] msgmni has been set to 996
[ 0.477151] io scheduler noop registered
[ 0.477175] io scheduler deadline registered
[ 0.477339] io scheduler cfq registered (default)
[ 0.477677] imx-weim 21b8000.weim: physical start addr for CS0 must be 8000000
[ 0.477723] imx-weim: probe of 21b8000.weim failed with error -22
[ 0.479898] MIPI DSI driver module loaded
[ 0.481715] mxc_vdacif vdac.35: mxc_vdacif_probe enter
[ 0.481992] mxc_sdc_fb fb.21: register mxc display driver hdmi
[ 0.482070] mxc_hdmi 20e0000.hdmi_video: Detected HDMI controller 0x13:0xa:0xa0:0xc1
[ 0.482115] fbcvt: 1920x1080@60: CVT Name - 2.073M9
[ 0.494121] mxc_sdc_fb fb.21: 1920x1080 h_sync,r,l: 44,88,148 v_sync,l,u: 5,4,36 pixclock=148500000 Hz
[ 0.511362] imx-ipuv3 2400000.ipu: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
[ 0.545249] mxc_sdc_fb fb.21: 1920x1080 h_sync,r,l: 44,88,148 v_sync,l,u: 5,4,36 pixclock=148500000 Hz
[ 0.580304] Console: switching to colour frame buffer device 240x67
[ 0.615619] mxc_sdc_fb fb.22: mxcfb1 is turned off!
[ 0.615756] mxc_sdc_fb fb.23: mxcfb2 is turned off!
[ 0.615883] mxc_sdc_fb fb.24: mxcfb3 is turned off!
[ 0.616806] imx-sdma 20ec000.sdma: no iram assigned, using external mem
[ 0.617882] imx-sdma 20ec000.sdma: loaded firmware 1.1
[ 0.620064] imx-sdma 20ec000.sdma: initialized
[ 0.620445] Serial: IMX driver
[ 0.620856] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX
[ 1.711139] console [ttymxc0] enabled
[ 1.711775] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 59) is a IMX
[ 1.712152] 21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 61) is a IMX
[ 1.712517] 21f4000.serial: ttymxc4 at MMIO 0x21f4000 (irq = 62) is a IMX
[ 1.712802] serial: Freescale lpuart driver
[ 1.713132] [drm] Initialized drm 1.1.0 20060810
[ 1.713453] [drm] Initialized vivante 1.0.0 20120216 on minor 0
[ 1.719245] brd: module loaded
[ 1.722372] loop: module loaded
[ 1.744438] Wait for CR ACK error!
[ 1.744867] sata phy RX_PLL is stable!
[ 1.744896] ahci: SSS flag set, parallel bus scan disabled
[ 1.744929] ahci ahci: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[ 1.744941] ahci ahci: flags: ncq sntf stag pm led clo only pmp pio slum part ccc apst
[ 1.786833] scsi0 : ahci_platform
[ 1.790441] ata1: SATA max UDMA/133 mmio [mem 0x02200000-0x02203fff] port 0x100 irq 71
[ 1.800808] spi_imx 2008000.ecspi: probed
[ 1.805718] spi_imx 200c000.ecspi: probed
[ 1.810550] vcan: Virtual CAN interface driver
[ 1.815132] CAN device driver interface
[ 1.819703] flexcan 2090000.can: device registered (reg_base=a09f0000, irq=142)
[ 1.827698] flexcan 2094000.can: device registered (reg_base=a09f8000, irq=143)
[ 1.836038] phyirq=190
[ 1.846640] libphy: fec_enet_mii_bus: probed
[ 1.855490] fec 2188000.ethernet eth0: registered PHC device 0
[ 1.865813] usbcore: registered new interface driver asix
[ 1.875464] usbcore: registered new interface driver ax88179_178a
[ 1.885748] usbcore: registered new interface driver cdc_ether
[ 1.895752] usbcore: registered new interface driver net1080
[ 1.905519] usbcore: registered new interface driver cdc_subset
[ 1.915506] usbcore: registered new interface driver zaurus
[ 1.925137] usbcore: registered new interface driver cdc_ncm
[ 1.934750] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.945271] ehci-pci: EHCI PCI platform driver
[ 1.953823] usbcore: registered new interface driver usb-storage
[ 1.964001] usbcore: registered new interface driver usbserial
[ 1.973906] usbcore: registered new interface driver usbserial_generic
[ 1.984502] usbserial: USB Serial support registered for generic
[ 1.994611] usbcore: registered new interface driver option
[ 2.004249] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.015291] usbcore: registered new interface driver pl2303
[ 2.024916] usbserial: USB Serial support registered for pl2303
[ 2.034899] usbcore: registered new interface driver qcserial
[ 2.044709] usbserial: USB Serial support registered for Qualcomm USB modem
[ 2.056750] setup_reset_gpio:-2
[ 2.067791] setup_reset_gpio:-2
[ 2.078135] ci_hdrc ci_hdrc.1: doesn't support gadget
[ 2.089165] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 2.097965] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
[ 2.121294] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 2.131058] hub 1-0:1.0: USB hub found
[ 2.138650] hub 1-0:1.0: 1 port detected
[ 2.141311] ata1: SATA link down (SStatus 0 SControl 300)
[ 2.155987] mousedev: PS/2 mouse device common for all mice
[ 2.173950] input: stmpe-ts as /devices/soc0/soc.1/2100000.aips-bus/21a4000.i2c/i2c-2/2-0041/stmpe-ts/input/input0
[ 2.191484] rtc-ds1307 1-0068: rtc core: registered m41t00 as rtc0
[ 2.201817] check_alarm_past: alarm in the past
[ 2.210360] snvs_rtc 20cc034.snvs-rtc-lp: rtc core: registered 20cc034.snvs-rtc-lp as rtc1
[ 2.222723] i2c /dev entries driver
[ 2.231333] mxc_v4l2_output v4l2_out.36: V4L2 device registered as video16
[ 2.242402] mxc_v4l2_output v4l2_out.36: V4L2 device registered as video17
[ 2.253373] i2c-core: driver [mag3110] using legacy suspend method
[ 2.263522] i2c-core: driver [mag3110] using legacy resume method
[ 2.274596] imx2-wdt 20bc000.wdog: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=0)
[ 2.287071] cpuidle: using governor ladder
[ 2.295234] cpuidle: using governor menu
[ 2.303181] sdhci: Secure Digital Host Controller Interface driver
[ 2.313410] sdhci: Copyright(c) Pierre Ossman
[ 2.321798] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.333563] mmc1: no vqmmc regulator found
[ 2.381292] mmc1: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
[ 2.394226] mmc2: no vqmmc regulator found
[ 2.451295] mmc2: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
[ 2.463247] mmc0: no vqmmc regulator found
[ 2.471567] usb 1-1: new high-speed USB device number 2 using ci_hdrc
[ 2.521295] mmc0: SDHCI controller on 2198000.usdhc [2198000.usdhc] using ADMA
[ 2.626191] mmc0: BKOPS_EN bit is not set
[ 2.646912] hub 1-1:1.0: USB hub found
[ 2.661023] hub 1-1:1.0: 4 ports detected
[ 2.686648] mmc0: new high speed DDR MMC card at address 0001
[ 2.711337] mmcblk0: mmc0:0001 004GE0 3.68 GiB
[ 2.725568] mmcblk0boot0: mmc0:0001 004GE0 partition 1 2.00 MiB
[ 2.741229] mmcblk0boot1: mmc0:0001 004GE0 partition 2 2.00 MiB
[ 2.765262] mmcblk0: p1 p2
[ 2.779941] mmcblk0boot1: unknown partition table
[ 2.796404] mmcblk0boot0: unknown partition table
[ 2.819823] Galcore version 4.6.9.9754
[ 2.851319] mxc_vdoa 21e4000.vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
[ 2.863708] mxc_asrc 2034000.asrc: mxc_asrc registered
[ 2.873726] mxc_vpu 2040000.vpu: VPU initialized
[ 2.971513] usb 1-1.1: new high-speed USB device number 3 using ci_hdrc
[ 3.009469] caam 2100000.caam: device ID = 0x0a16010000000000 (Era -524)
[ 3.020521] caam 2100000.caam: job rings = 2, qi = 0
[ 3.030359] caam 2100000.caam: authenc-hmac-md5-cbc-aes-caam
[ 3.040473] caam 2100000.caam: authencesn-hmac-md5-cbc-aes-caam
[ 3.050811] caam 2100000.caam: authenc-hmac-sha1-cbc-aes-caam
[ 3.060961] caam 2100000.caam: authencesn-hmac-sha1-cbc-aes-caam
[ 3.071405] caam 2100000.caam: authenc-hmac-sha224-cbc-aes-caam
[ 3.081792] caam 2100000.caam: authencesn-hmac-sha224-cbc-aes-caam
[ 3.092414] caam 2100000.caam: authenc-hmac-sha256-cbc-aes-caam
[ 3.102721] caam 2100000.caam: authencesn-hmac-sha256-cbc-aes-caam
[ 3.113236] caam 2100000.caam: authenc-hmac-md5-cbc-des3_ede-caam
[ 3.123654] caam 2100000.caam: authencesn-hmac-md5-cbc-des3_ede-caam
[ 3.134407] caam 2100000.caam: authenc-hmac-sha1-cbc-des3_ede-caam
[ 3.145199] caam 2100000.caam: authencesn-hmac-sha1-cbc-des3_ede-caam
[ 3.155957] hub 1-1.1:1.0: USB hub found
[ 3.164109] caam 2100000.caam: authenc-hmac-sha224-cbc-des3_ede-caam
[ 3.174687] hub 1-1.1:1.0: 4 ports detected
[ 3.183167] caam 2100000.caam: authencesn-hmac-sha224-cbc-des3_ede-caam
[ 3.194318] caam 2100000.caam: authenc-hmac-sha256-cbc-des3_ede-caam
[ 3.205219] caam 2100000.caam: authencesn-hmac-sha256-cbc-des3_ede-caam
[ 3.216216] caam 2100000.caam: authenc-hmac-md5-cbc-des-caam
[ 3.226212] caam 2100000.caam: authencesn-hmac-md5-cbc-des-caam
[ 3.236620] caam 2100000.caam: authenc-hmac-sha1-cbc-des-caam
[ 3.246693] caam 2100000.caam: authencesn-hmac-sha1-cbc-des-caam
[ 3.257000] caam 2100000.caam: authenc-hmac-sha224-cbc-des-caam
[ 3.267123] caam 2100000.caam: authencesn-hmac-sha224-cbc-des-caam
[ 3.277445] caam 2100000.caam: authenc-hmac-sha256-cbc-des-caam
[ 3.287461] caam 2100000.caam: authencesn-hmac-sha256-cbc-des-caam
[ 3.297672] caam 2100000.caam: ecb-des-caam
[ 3.305820] caam 2100000.caam: ecb-arc4-caam
[ 3.314012] caam 2100000.caam: ecb-aes-caam
[ 3.322120] caam 2100000.caam: ctr-aes-caam
[ 3.330114] caam 2100000.caam: cbc-aes-caam
[ 3.338134] caam 2100000.caam: ecb-des3-caam
[ 3.346184] caam 2100000.caam: cbc-3des-caam
[ 3.354198] caam 2100000.caam: cbc-des-caam
[ 3.361984] caam 2100000.caam: fsl,sec-v4.0 algorithms registered in /proc/crypto
[ 3.376697] platform 2101000.jr0: registering rng-caam
[ 3.386459] platform caam_sm: caam_sm_test: 8-byte key test match OK
[ 3.396595] platform caam_sm: caam_sm_test: 16-byte key test match OK
[ 3.406780] platform caam_sm: caam_sm_test: 32-byte key test match OK
[ 3.417233] platform caam_secvio.40: security violation service handlers armed
[ 3.428089] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.437111] usbcore: registered new interface driver usbhid
[ 3.446187] usbhid: USB HID core driver
[ 3.459155] stmpe-adc stmpe-adc: Initialized
[ 3.468413] sgtl5000 2-000a: sgtl5000 revision 0x11
[ 3.503515] sgtl5000 2-000a: Failed to get supply 'VDDD': -19
[ 3.512874] 2-000a: 1200 mV normal
[ 3.519960] sgtl5000 2-000a: Using internal LDO instead of VDDD
[ 3.541415] imx-sgtl5000 sound.32: sgtl5000 <-> 2028000.ssi mapping ok
[ 3.554504] imx-spdif sound-spdif.34: dit-hifi <-> 2004000.spdif mapping ok
[ 3.565941] imx-spdif sound-spdif.34: dir-hifi <-> 2004000.spdif mapping ok
[ 3.579744] imx-audio-hdmi sound-hdmi.33: hdmi-hifi <-> hdmi_audio.16 mapping ok
[ 3.591600] TCP: cubic registered
[ 3.598825] NET: Registered protocol family 10
[ 3.607547] sit: IPv6 over IPv4 tunneling driver
[ 3.616198] NET: Registered protocol family 17
[ 3.624168] can: controller area network core (rev 20120528 abi 9)
[ 3.633913] NET: Registered protocol family 29
[ 3.641891] can: raw protocol (rev 20120528)
[ 3.649613] can: broadcast manager protocol (rev 20120528 t)
[ 3.658743] can: netlink gateway (rev 20130117) max_hops=1
[ 3.668135] Key type dns_resolver registered
[ 3.676170] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 3.688499] Registering SWP/SWPB emulation handler
[ 3.698490] input: gpio-keys.37 as /devices/soc0/gpio-keys.37/input/input1
[ 3.710583] rtc-ds1307 1-0068: hctosys: unable to read the hardware clock
[ 3.728090] ALSA device list:
[ 3.734818] #0: imx6q-apalis-sgtl5000
[ 3.742349] #1: imx-spdif
[ 3.748783] #2: imx-hdmi-soc
[ 3.768481] kjournald starting. Commit interval 5 seconds
[ 3.768666] EXT3-fs (mmcblk0p2): mounted filesystem with ordered data mode
[ 3.768700] VFS: Mounted root (ext3 filesystem) readonly on device 179:2.
[ 3.799767] devtmpfs: mounted
[ 3.807188] Freeing unused kernel memory: 284K (807d2000 - 80819000)
[ 3.906224] systemd[1]: Failed to insert module 'ip_tables': Function not implemented
[ 3.924263] systemd[1]: systemd 226 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD +IDN)
[ 3.945874] systemd[1]: Detected architecture arm.
Welcome to The Ångström Distribution v2014.12!
[ 3.982604] systemd[1]: Set hostname to <apalis-imx6>.
[ 4.187664] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 4.211562] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 4.241528] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 4.261559] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ 4.292060] systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
[ 4.324423] systemd[1]: Mounting /sys/kernel/debug...
[ 4.354882] systemd[1]: Starting (null)...
Starting (null)...
[ 4.382427] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 4.413042] systemd[1]: Starting Create list of required static device nodes for the current kernel...
Starting Create list of required st... nodes for the current kernel...
[ 4.454555] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 4.481714] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 4.511748] systemd[1]: proc-bus-usb.mount: Failed to check directory /proc/bus/usb: No such file or directory
[ 4.533560] systemd[1]: Mounting /proc/bus/usb...
[ 4.564698] systemd[1]: Starting Setup Virtual Console...
[ 4.605210] systemd[1]: Starting Apply Kernel Variables...
[ 4.645883] systemd[1]: Mounting Temporary Directory...
[ 4.681921] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 4.721883] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ 4.764403] systemd[1]: Mounting FUSE Control File System...
[ 4.805114] systemd[1]: Starting Journal Service...
[ 4.841780] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 4.874622] systemd[1]: Starting File System Check on Root Device...
[ 4.911458] systemd[1]: Reached target Paths.
[ OK ] Reached target Paths.
[ 4.921585] systemd[1]: Starting Export GPIOs to user space...
[ 4.942072] systemd[1]: Listening on udev Kernel Socket.
[ OK [ 4.961116] systemd[1]: Listening on networkd rtnetlink socket.
] Listening on udev Kernel Socket[ 4.972133] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on networkd rtnetlink socket.
[ 4.987944] systemd[1]: Mounted FUSE Control File System.
2m OK ] Listening on udev C[ 4.999350] systemd[1]: Mounted Temporary Directory.
ontrol Socket.
[ OK ][ 5.010864] systemd[1]: Mounted /sys/kernel/debug.
Mounted FUSE Control File System[ 5.022378] systemd[1]: Started Journal Service.
[ OK ] Mounted Temporary Directory.
[ OK ] Mounted /sys/kernel/debug.
[ OK ] Started Journal Service.
[ OK ] Started (null).
[ OK ] Started Create list of required sta...ce nodes for the current kernel.
[FAILED] Failed to mount /proc/bus/usb.
See 'systemctl status proc-bus-usb.mount' for details.
[DEPEND] Dependency failed for Local File Systems.
[ OK ] Started Setup Virtual Console.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Export GPIOs to user space.
[ OK ] Started File System Check on Root Device.
Starting Remount Root and Kernel File Systems...
[ OK ] Stopped target Graphical Interface.
[ OK ] Stopped target Multi-User Syst[ 5.244747] EXT3-fs (mmcblk0p2): using internal journal
em.
[ OK ] Stopped Connection service.
[ OK ] Stopped D-Bus System Message Bus.
[ OK ] Stopped LXDE Display Manager.
[ OK ] Stopped Network Name Resolution.
[ OK ] Closed Network Name Resolution Service Bus Name.
[ OK ] Closed RPCbind Server Activation Socket.
[ OK ] Stopped Timestamping service.
[ OK ] Closed sshd.socket.
[ OK ] Stopped Serial Getty on ttymxc0.
[ OK ] Reached target Login Prompts.
[ OK ] Stopped Login Service.
[ OK ] Closed D-Bus System Message Bus Socket.
[ OK ] Closed Network Service Bus Name.
[ OK ] Stopped Avahi mDNS/DNS-SD Stack.
[ OK ] Closed Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Stopped Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ OK ] Stopped Permit User Sessions.
[ OK ] Stopped target Basic System.
[ OK ] Stopped target System Initialization.
Starting Restore Sound Card State...
[ OK ] Started Emergency Shell.
[ OK ] Reached target Emergency Mode.
[ OK ] Reached target Sockets.
[ OK ] Reached target Remote File Systems.
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Started Restore Sound Card State.
Starting Flush Journal to Persistent Storage...
Starting udev Coldplug all Devices...
Starting Create Static Device Nodes in /dev...
[ OK ] Started Create Static Device Nodes in /dev.
[ 5.983989] systemd-journald[183]: Received request to flush runtime journal from PID 1
[ OK ] Reached target Local File Systems (Pre).
Mounting /media/ram...
Mounting /var/volatile...
Starting udev Kernel Device Manager...
[ OK ] Mounted /var/volatile.
[ OK ] Mounted /media/ram.
Starting Load/Save Random Seed...
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started udev Coldplug all Devices.
[ OK ] Started Load/Save Random Seed.
[ OK ] Started udev Kernel Device Manager.
Starting Network Service...
Starting Create Volatile Files and Directories...
[ OK ] Started Create Volatile Files and Directories.
[ OK ] Started Network Service.
[ OK ] Reached target Network.
Starting Network Time Synchronization...
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Time Synchronized.
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Created slice system-systemd\x2dbacklight.slice.
Starting Load/Save Screen Backlight...ess of backlight:backlight.18...
Starting Update UTMP about System Runlevel Changes...
[ OK ] Started Load/Save Screen Backlight ...tness of backlight:backlight.18.
[ OK ] Found device /dev/ttymxc0.
[ OK ] Started Update UTMP about System Runlevel Changes.
Welcome to emergency mode! After logging in, type "journalctl -xb" to view
system logs, "systemctl reboot" to reboot, "systemctl default" or ^D to
try again to boot into default mode.
Give root password for maintenance
(or press Control-D to continue): [ 6.957527] DBG sensor data is at 7f0097a8
[ 6.979880] adv7180 3-0021: no sensor pwdn pin available
[ 7.053496] DBG sensor data is at 7f00e370
[ 7.116018] max9526 3-0020: Device seems not to be a MAX9526
[ 7.778416] mxc_v4l_open: Mxc Camera no sensor ipu0/csi0
[ 7.803552] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
