Just started with i.MX6 on Apalis carrier and tried to install some Toradex images via Easy Installer. Easy installer itself and embedded Linux Demo 2.8b2.97 work fine, but the stable version 2.7 will not start after programming. Also other images will be programmed, but after reboot I only see the Toradex Logo and the following output on the console (minicom on host computer):
U-Boot 2016.11-2.7.4+g1b121c6 (Oct 04 2017 - 22:34:15 +0000)
CPU: Freescale i.MX6Q rev1.5 at 792 MHz
Reset cause: POR
I2C: ready
DRAM: 2 GiB
PMIC: device id: 0x10, revision id: 0x21, programmed
auto-detected panel HDMI
Display: HDMI (1024x768)
In: serial
Out: serial
Err: serial
Model: Toradex Apalis iMX6 Quad 2GB IT V1.1C, Serial# 05184610
Net: using PHY at 7
FEC [PRIME]
Booting from internal eMMC chip...
reading imx6q-apalis-eval.dtb
50345 bytes read in 17 ms (2.8 MiB/s)
reading zImage
** Unable to read file zImage **
emmcboot failed
MMC: no card present
starting USB...
After programming I were asked to reboot or power down. Reboot will not restart, I always have to press the power button to start the new programmed image
