running “bitbake -k angstrom-lxde-image” (previous: bitbake virtual/kernel -c menuconfig and removing from compilation the vivante gpu …), I obtain this error:
CC [M] /home/mane/Toradex/iMX6/build/tmp-glibc/work/colibri_imx6-angstrom-linux-gnueabi/kernel-module-imx-gpu-viv/6.2.2.p0-r0/kernel-module-imx-gpu-viv-6.2.2.p0/kernel-module-imx-gpu-viv-src/hal/os/linux/kernel/gc_hal_kernel_driver.o
In file included from /home/mane/Toradex/iMX6/build/tmp-glibc/work-shared/colibri-imx6/kernel-source/include/linux/spinlock.h:290:0,
from /home/mane/Toradex/iMX6/build/tmp-glibc/work-shared/colibri-imx6/kernel-source/include/linux/seqlock.h:35,
from /home/mane/Toradex/iMX6/build/tmp-glibc/work-shared/colibri-imx6/kernel-source/include/linux/time.h:5,
from /home/mane/Toradex/iMX6/build/tmp-glibc/work-shared/colibri-imx6/kernel-source/include/linux/stat.h:18,
from /home/mane/Toradex/iMX6/build/tmp-glibc/work-shared/colibri-imx6/kernel-source/include/linux/module.h:10,
from /home/mane/Toradex/iMX6/build/tmp-glibc/work/colibri_imx6-angstrom-linux-gnueabi/kernel-module-imx-gpu-viv/6.2.2.p0-r0/kernel-module-imx-gpu-viv-6.2.2.p0/kernel-module-imx-gpu-viv-src/hal/os/linux/kernel/gc_hal_kernel_linux.h:63,
from /home/mane/Toradex/iMX6/build/tmp-glibc/work/colibri_imx6-angstrom-linux-gnueabi/kernel-module-imx-gpu-viv/6.2.2.p0-r0/kernel-module-imx-gpu-viv-6.2.2.p0/kernel-module-imx-gpu-viv-src/hal/os/linux/kernel/gc_hal_kernel_os.c:56:
/home/mane/Toradex/iMX6/build/tmp-glibc/work/colibri_imx6-angstrom-linux-gnueabi/kernel-module-imx-gpu-viv/6.2.2.p0-r0/kernel-module-imx-gpu-viv-6.2.2.p0/kernel-module-imx-gpu-viv-src/hal/os/linux/kernel/gc_hal_kernel_os.c: In function 'gckOS_WaitSignal':
/home/mane/Toradex/iMX6/build/tmp-glibc/work/colibri_imx6-angstrom-linux-gnueabi/kernel-module-imx-gpu-viv/6.2.2.p0-r0/kernel-module-imx-gpu-viv-6.2.2.p0/kernel-module-imx-gpu-viv-src/hal/os/linux/kernel/gc_hal_kernel_os.c:6043:19: error: passing argument 1 of 'rt_spin_lock' from incompatible pointer type [-Werror=incompatible-pointer-types]
spin_lock_irq(&signal->obj.wait.lock);
/home/mane/Toradex/iMX6/build/tmp-glibc/work-shared/colibri-imx6/kernel-source/include/linux/spinlock_rt.h:43:40: note: in definition of macro 'spin_lock'
#define spin_lock(lock) rt_spin_lock(lock)
/home/mane/Toradex/iMX6/build/tmp-glibc/work/colibri_imx6-angstrom-linux-gnueabi/kernel-module-imx-gpu-viv/6.2.2.p0-r0/kernel-module-imx-gpu-viv-6.2.2.p0/kernel-module-imx-gpu-viv-src/hal/os/linux/kernel/gc_hal_kernel_os.c:6043:5: note: in expansion of macro 'spin_lock_irq'
/home/mane/Toradex/iMX6/build/tmp-glibc/work-shared/colibri-imx6/kernel-source/include/linux/spinlock_rt.h:25:24: note: expected 'spinlock_t * {aka struct spinlock *}' but argument is of type 'raw_spinlock_t * {aka struct raw_spinlock *}'
extern void __lockfunc rt_spin_lock(spinlock_t *lock);
/home/mane/Toradex/iMX6/build/tmp-glibc/work/colibri_imx6-angstrom-linux-gnueabi/kernel-module-imx-gpu-viv/6.2.2.p0-r0/kernel-module-imx-gpu-viv-6.2.2.p0/kernel-module-imx-gpu-viv-src/hal/os/linux/kernel/gc_hal_kernel_os.c:6079:31: error: passing argument 1 of '__add_wait_queue_tail' from incompatible pointer type [-Werror=incompatible-pointer-types]
__add_wait_queue_tail(&signal->obj.wait, &wait);
[ ... MEGA - CUT ... ]
CC [M] /home/mane/Toradex/iMX6/build/tmp-glibc/work/colibri_imx6-angstrom-linux-gnueabi/kernel-module-imx-gpu-viv/6.2.2.p0-r0/kernel-module-imx-gpu-viv-6.2.2.p0/kernel-module-imx-gpu-viv-src/hal/kernel/arch/gc_hal_kernel_context.o
cc1: all warnings being treated as errors
/home/mane/Toradex/iMX6/build/tmp-glibc/work-shared/colibri-imx6/kernel-source/scripts/Makefile.build:293: recipe for target '/home/mane/Toradex/iMX6/build/tmp-glibc/work/colibri_imx6-angstrom-linux-gnueabi/kernel-module-imx-gpu-viv/6.2.2.p0-r0/kernel-module-imx-gpu-viv-6.2.2.p0/kernel-module-imx-gpu-viv-src/hal/os/linux/kernel/gc_hal_kernel_os.o' failed
make[3]: *** [/home/mane/Toradex/iMX6/build/tmp-glibc/work/colibri_imx6-angstrom-linux-gnueabi/kernel-module-imx-gpu-viv/6.2.2.p0-r0/kernel-module-imx-gpu-viv-6.2.2.p0/kernel-module-imx-gpu-viv-src/hal/os/linux/kernel/gc_hal_kernel_os.o] Error 1
make[3]: *** Waiting for unfinished jobs....
/home/mane/Toradex/iMX6/build/tmp-glibc/work-shared/colibri-imx6/kernel-source/Makefile:1499: recipe for target '_module_/home/mane/Toradex/iMX6/build/tmp-glibc/work/colibri_imx6-angstrom-linux-gnueabi/kernel-module-imx-gpu-viv/6.2.2.p0-r0/kernel-module-imx-gpu-viv-6.2.2.p0/kernel-module-imx-gpu-viv-src' failed
make[2]: *** [_module_/home/mane/Toradex/iMX6/build/tmp-glibc/work/colibri_imx6-angstrom-linux-gnueabi/kernel-module-imx-gpu-viv/6.2.2.p0-r0/kernel-module-imx-gpu-viv-6.2.2.p0/kernel-module-imx-gpu-viv-src] Error 2
make[2]: Leaving directory '/home/mane/Toradex/iMX6/build/tmp-glibc/work-shared/colibri-imx6/kernel-build-artifacts'
Makefile:152: recipe for target 'sub-make' failed
make[1]: *** [sub-make] Error 2
make[1]: Leaving directory '/home/mane/Toradex/iMX6/build/tmp-glibc/work-shared/colibri-imx6/kernel-source'
Makefile:6: recipe for target 'all' failed
make: *** [all] Error 2
ERROR: oe_runmake failed
WARNING: exit code 1 from a shell command.
ERROR: Function failed: do_compile (log file is located at /home/mane/Toradex/iMX6/build/tmp-glibc/work/colibri_imx6-angstrom-linux-gnueabi/kernel-module-imx-gpu-viv/6.2.2.p0-r0/temp/log.do_compile.21428)
Some ideas ?
Thank You …
