- I have downloaded openembedded-(core) source code form the below link
I have build the source code for the apalis-t30. I have used “bitbake -k angstrom-lxde-image” , “bitbake samba” & “bitbake angstrom-lxde-image -c populate_sdk” command for compling the source code.
After the compilation i can see the binary “Apalis-T30_LXDE-Image_2.8b2-20180613.tar.bz2” inside “oe-core/deploy/images/apalis-t30” directory. But in this directory i can see only zImage has been created. But before 4 month once i have downloaded the same sourcecode and after building i was able to see the uImage
logs:
deepaksingh@dexsys171:/oe-core/deploy/images/apalis-t30$ ls -l
total 393052
-rw-r--r-- 1 deepaksingh deepaksingh 197915299 Jun 13 12:47 Apalis-T30_LXDE-Image_2.8b2-20180613.tar.bz2
-rw-r--r-- 1 deepaksingh deepaksingh 29724 Jun 13 12:46 Apalis-T30_LXDE-Image.rootfs.manifest
-rw-r--r-- 1 deepaksingh deepaksingh 191892157 Jun 13 12:46 Apalis-T30_LXDE-Image.rootfs.tar.bz2
-rw-r--r-- 1 deepaksingh deepaksingh 148330 Jun 13 12:46 Apalis-T30_LXDE-Image.testdata.json
lrwxrwxrwx 1 deepaksingh deepaksingh 37 Jun 13 12:46 LXDE-Image-apalis-t30.manifest -> Apalis-T30_LXDE-Image.rootfs.manifest
lrwxrwxrwx 1 deepaksingh deepaksingh 36 Jun 13 12:48 LXDE-Image-apalis-t30.tar.bz2 -> Apalis-T30_LXDE-Image.rootfs.tar.bz2
lrwxrwxrwx 1 deepaksingh deepaksingh 35 Jun 13 12:46 LXDE-Image-apalis-t30.testdata.json -> Apalis-T30_LXDE-Image.testdata.json
-rw-rw-r-- 2 deepaksingh deepaksingh 7642167 Jun 12 01:54 modules--3.1.10+gitr0+b63ee2039e-2.8.2-apalis-t30-20180611121400.tgz
lrwxrwxrwx 2 deepaksingh deepaksingh 68 Jun 12 01:54 modules-apalis-t30.tgz -> modules--3.1.10+gitr0+b63ee2039e-2.8.2-apalis-t30-20180611121400.tgz
-rw-r--r-- 1 deepaksingh deepaksingh 553218 Jun 12 01:50 u-boot-dtb-tegra-apalis-t30-2016.11+gitAUTOINC+087e95a2dc-2.8.2.bin
lrwxrwxrwx 1 deepaksingh deepaksingh 67 Jun 12 01:50 u-boot-dtb-tegra-apalis-t30.bin -> u-boot-dtb-tegra-apalis-t30-2016.11+gitAUTOINC+087e95a2dc-2.8.2.bin
lrwxrwxrwx 1 deepaksingh deepaksingh 67 Jun 12 01:50 u-boot-dtb-tegra.bin -> u-boot-dtb-tegra-apalis-t30-2016.11+gitAUTOINC+087e95a2dc-2.8.2.bin
-rw-r--r-- 1 deepaksingh deepaksingh 5134 Jun 12 01:50 uEnv-apalis-t30-2016.11+gitAUTOINC+087e95a2dc-2.8.2.txt
lrwxrwxrwx 1 deepaksingh deepaksingh 55 Jun 12 01:50 uEnv.txt -> uEnv-apalis-t30-2016.11+gitAUTOINC+087e95a2dc-2.8.2.txt
lrwxrwxrwx 2 deepaksingh deepaksingh 67 Jun 12 01:54 zImage -> zImage--3.1.10+gitr0+b63ee2039e-2.8.2-apalis-t30-20180611121400.bin
-rw-r--r-- 2 deepaksingh deepaksingh 4248088 Jun 12 01:54 zImage--3.1.10+gitr0+b63ee2039e-2.8.2-apalis-t30-20180611121400.bin
lrwxrwxrwx 2 deepaksingh deepaksingh 67 Jun 12 01:54 zImage-apalis-t30.bin -> zImage--3.1.10+gitr0+b63ee2039e-2.8.2-apalis-t30-20180611121400.bin
- After building the i have followed steps from the below link for flashing images to apalis-T30
For flashing fist i have extracted the image “Apalis-T30_LXDE-Image_2.8b2-20180613.tar.bz2”. After extracting the image i have used below command to make the USB as a bootable.
./update.sh -o /media/deepaksingh/3351-0F5F
logs:
root@dexsys171:/media/deepaksingh/3351-0F5F# ls -l
total 32
drwx------ 2 deepaksingh deepaksingh 8192 Jun 14 18:17 apalis_t30
-rw-r--r-- 1 deepaksingh deepaksingh 710 Jun 14 18:16 flash_blk.img
-rw-r--r-- 1 deepaksingh deepaksingh 444 Jun 14 18:16 flash_eth.img
-rw-r--r-- 1 deepaksingh deepaksingh 307 Jun 14 18:16 flash_mmc.img
root@dexsys171:/media/deepaksingh/3351-0F5F/apalis_t30# ls -l
total 859784
-rw-r--r-- 1 deepaksingh deepaksingh 569856 Jun 14 18:16 apalis_t30.img
-rw-r--r-- 1 deepaksingh deepaksingh 16777216 Jun 14 18:16 boot.vfat
-rw-r--r-- 1 deepaksingh deepaksingh 5080 Jun 14 18:16 flash_blk.img
-rw-r--r-- 1 deepaksingh deepaksingh 4860 Jun 14 18:16 flash_eth.img
-rw-r--r-- 1 deepaksingh deepaksingh 512 Jun 14 18:16 mbr.bin
-rw-r--r-- 1 deepaksingh deepaksingh 67108864 Jun 14 18:16 root.ext3-100
-rw-r--r-- 1 deepaksingh deepaksingh 67108864 Jun 14 18:16 root.ext3-101
-rw-r--r-- 1 deepaksingh deepaksingh 67108864 Jun 14 18:16 root.ext3-102
-rw-r--r-- 1 deepaksingh deepaksingh 67108864 Jun 14 18:16 root.ext3-103
-rw-r--r-- 1 deepaksingh deepaksingh 67108864 Jun 14 18:16 root.ext3-104
-rw-r--r-- 1 deepaksingh deepaksingh 67108864 Jun 14 18:16 root.ext3-105
-rw-r--r-- 1 deepaksingh deepaksingh 67108864 Jun 14 18:16 root.ext3-106
-rw-r--r-- 1 deepaksingh deepaksingh 67108864 Jun 14 18:17 root.ext3-107
-rw-r--r-- 1 deepaksingh deepaksingh 67108864 Jun 14 18:17 root.ext3-108
-rw-r--r-- 1 deepaksingh deepaksingh 67108864 Jun 14 18:17 root.ext3-109
-rw-r--r-- 1 deepaksingh deepaksingh 67108864 Jun 14 18:17 root.ext3-110
-rw-r--r-- 1 deepaksingh deepaksingh 67108864 Jun 14 18:17 root.ext3-111
-rw-r--r-- 1 deepaksingh deepaksingh 53477376 Jun 14 18:17 root.ext3-112
-rw-r--r-- 1 deepaksingh deepaksingh 199 Jun 14 18:16 versions.txt
-rw-r--r-- 1 deepaksingh deepaksingh 4248088 Jun 14 18:16 zImage
After making USB as a bootable once i am trying to flash the images to the apalis-T30, getting the error messages(oe-core_flash_error_logs) and system is not booting properly.
Below mentioned command i have used for the flashing
Apalis T30 # run setupdate
Apalis T30 # run update
So can any one please help me to resolve this issue ASAP?
