I’m going to buy Splash Screen Customizer tool to customize the splash screen for VF61 as described here.
But I need that the splash screen image stays on screen until my application has started.
I double checked your configuration and mine and I found the difference.
The behavior is the one you described (and I can keep the splash screen until the application has started) only if registry key UseSplashSettings is set to 1.
If UseSplashSettings is set to 0, the behavior is what I described in my first message, and I didn’t found a way to avoid black screen between the boot and the application start.
If this is “by design” I suggest you to add this information to the KB.
Thank you for pointing this out. This is indeed by design:
With UseSplashSettings = 0 the WinCe display driver does re-initialize the display controller. This leads to a temporary black screen.
I will update the KB.
