I tried to use the new Update Tool v6.0.2. When I use it with my custom made splashscreen, the target doesn.t boot up anymore.
I did the following tests:
- Load a brand new Image to the Target, make a backup and update with this backup → works
- Load a brand new Image and customize with my custom bootscreen, touchdriver, etc… Make a backup and update with this backup → Module doesn’t start anymore
- Replace the Splashscreenfile of the backup that did work with the one failing-> works
I also connect the Debug Output over RS232. In case 2 there is no Output at all.
I attached the following file:
- BootscreenRotated.bmz is the Custom Splashscreen file.
- FlashBackup_splash_screen.bmz is the file made by the update tool.
Can you help me with this?
