In Debug Using Eclipse section of getting started Step 1 is not as per the details given.
After opening perspective window I am not getting the Remote System Explorer option in the list. See below screen.
What could be the reason?
Hello
Which Eclipse version are you using? If the Remote System Explorer is not already installed with the standard installation, you can do it following the link on this page.
