I have used High performance, low power Embedded Computing Systems | Toradex Developer Center and High performance, low power Embedded Computing Systems | Toradex Developer Center and poweroff is happening. when i initiate shutdown it shutdowns immediately but the complete power off it is taking 45 seconds to one minute. Is there any settings regarding reducing the power-off time
I would assume there being some issue in a service shutting down. Can you post complete serial console boot resp. shutdown log plus journalctl -b -1
output once you re-booted.
Hi marcel
i don’t know how to get the shutdown log
i am attaching two files one is the output of journalctl -b -1 link text
i am attaching the serial console link text
It could be that snapd is the culprit. Can you try disable snapd?
systemctl disable snapd
systemctl stop snapd
Thanks stefan
It is working and now it is taking less than 3 seconds to poweroff.
can you brief on snapd and what is its significance ?
You are welcome. You can read here about snapd.
Best regards
