On Ixora board we connected the USBO1_ID pin to GND (JP2) to use the USB port in host mode.
If a device (pen drive, mouse,…) is connected during startup, everything works fine.
If the device is disconnected, some seconds later the USB power is switched off and it’s not possible to get it running again without disconnect + reconnect of JP2.
How can we get stable power on the USB? Is this a driver issue?
I use the bottom connector of X8, but that’s not really relevant because the problem occurs when nothing is connected.
The LED3 (next to the connector) is switched on during boot (or after reconnect of JP2) and then off again.
It also happens with an unmodified CPU module (with the easy installer system).
In the appended video it’s an Apalis iMX6 Dual 512MB
It also happens with other images. In the video above I use a completely unmodified SOM (easy installer running).
Also the current logs are from this device:
The Ixora board is a V1.1A, the SOM is an iMX2D 512MB V1,1B.
The same happens on the Apalis Evaluation Board Rev. 1.1.
I connected a cable with ID pin to the OTG port and after some seconds, the power is switched off if there is no device connected.
I could reproduce the issue with the 4.1 kernel you use.
This seems to be expected behaviour when the kernel is compiled with CONFIG_USB_OTG_FSM and the USB port is set in its otg role.
Note that in the latest kernel (4.9, as used in the 2.8 Beta xx images) we by default to not compile with that options.
So besides updating to 2.8 Beta 3 you could do either of:
Unselect CONFIG_USB_OTG_FSM in ‘make menuconfig’ (Drivers->USB) but keep CONFIG_USB_OTG selected and then recompile and deploy the kernel.
Change the device tree, so that the usbotg node defines the property dr_mode = "host";.
The first keeps the ability to change between the host / device role by the ID-pin / JP2 state. The second will use the port in host mode independent of the ID-pin signal.
