Colibri T30 hast an Ethernet module. Is more than one IP address possibel to use for a T30?
We used two IPs and two Subnet masks, but only first IP was possible to ping to.
Is ti generally thought to use dual IP address inside an Adapter?
How do you use two IPs? Did you add an additional ethernet adapter? If you have two ethernet adpaters attached, I don’t think there is an issue in case you set up your network configuration properly (different subnes, gateway settings, …).
I am also interested in this topic. We have a case where we would like to assign multiple IP addresses (up to 4) to one network interface (NIC) under WinCE 2013.
Microsoft documentation isn’t clear if I can add two IP addresses on one interface:
IPAddress : REG_MULTI_SZ : This value is not set by default. This value specifies the IP addresses of the IP interfaces…
Did a quick test and added two IP addresses to the registry and two subnet but didn’t worked.
